Question about Refrigerators
Circleware beverage dispensers
I wanted to know if I could purchase a replacement Portofino 2.5 gallon glass dispenser only. The dispenser is broken, but I have the stand.
HVACRH20
  • 237 Answers
SOURCE: Warm Water out of water dispenser
Usually the coolness comes from a large coil of plastic tubing in the refer compartment that stores the water. Check that the refer compartment is cool enough. Also see if running a large glass or two becomes cool again and stays cool for a while. Usually the very first 1/2 glass may be warm until the "cool" water that is stored in the coil of tubing finally makes its way to the dispensor.
Posted on Nov 09, 2006
SOURCE: broken water dispenser in door
I was able to replace it without taking the door apart. There are clips on either side held in place with screws.
Posted on Nov 24, 2008
SOURCE: LG LRSC26925TT ice dispensing funnel broken
Yes. But LG came out with a new frame for the funnel. So you have to order the funnel and the frame which is installed through your front control panel. Good Luck I just did it.
Posted on Jan 05, 2010
SOURCE: Water dispenser lever on door broken off.
Yes, the levers are easily ordered and replaced.
get manual, obtain part number, order part, replace part. use these websites for help http://www.retrevo.com/samples/Frigidaire-manuals.html#Refrigerator
https://www.appliancezone.com/
Posted on Dec 02, 2010
  • 1417 Answers
SOURCE: How do I replace the
Ice makers and water dispensers are convenient to have on your refrigerator, but can also cause a lot of aggravation if they are not functioning properly.
If your water valves are not defective and you are still experiencing water or ice delays, you may have a clog in your refrigerator hose line.
Instructions and material needed to fix it up.
  • Towel,Flathead screwdriver,New water hose
  1. Turn off the water supply to the refrigerator and place a towel under the line to soak up any residual water that leaks from the hose when you remove it. Unplug the refrigerator.
  2. Disconnect the hose from the back of the refrigerator by pushing in on the collar while pulling the water tube out. If you have a model with an ice and water dispenser, you will need to disassemble the dispenser on the front of the freezer in order to completely remove the water hose.
  3. Remove the water drip tray from beneath the ice/water dispenser and locate the screws at the bottom of the cover (if any). Remove screws and pop off the panel that houses the dispenser. If the unit does not have screws, you will need to pry the cover off with a flat-nosed screwdriver.
  4. Once the cover is removed, you should be able to see the screws that hold the dispenser unit in place. Remove these screws and reposition the unit so you can free the water hose, by pulling it through the dispenser.
  5. Thread the new water line through the freezer door and reassemble dispenser unit. Push the new water hose into the fitting on the back panel, making sure it is properly seated. Turn on water supply and check for any leaks before moving the refrigerator unit back against the wall.
Good Luck and thanks for using fixya.
Posted on Jan 16, 2011
I have water in the bottom of my Beverage air kegerator
Water in the bottom of Kegerator - Dispense Forum ' Discuss Keg ...
www.micromatic.com/...kegerator.../kegerators-kegerator.../5907-water-i...
Jul 18, 2009 - I have a Beverage Air 2 with front ventilating compressor. When I .....Also I do refrain from opening my kegerator door between kegs. I have ... need some help with BM23 - Dispense Forum ' Discuss Keg Beer ...
Aug 1, 2013
New To Me Bev Air BM23
Jul 16, 2012
Beverage-air condenser / thermo
Dec 31, 2009
Beverage Air BM23 Door Not Sealing
Aug 3, 2009
More results from www.micromatic.com
Kegerator leaking water inside - Home Brew Forums
Dec 28, 2015 | Beverage Air Refrigeration DD58C-1-B - 59...
I misplaced directions on how to tighten the spigot. Need to know, please
Looking at close-ups of the picture, it has a standard type spigot assembly for a glass-walled beverage vessel. There's a spigot on the outside, with a threaded hollow shaft behind it, a soft compliant gasket between it and the glass, the glass, another gasket, and an internal screw. Looking closely at a picture, such as the one here (
Shangri La 320 oz Beverage Dispenser ), you can even see the hex-head on the internal nut. With the container (hopefully) empty, get a medium sized crescent wrench or slip joint pliers, reach in and grab the nut. With the other hand, hold the spigot and make sure it's square (spigot pointing down and not off to the side). Turn the nut until it's firm. Don't over-tighten it - both the pliers and the threads multiply the force on the wall. If it's really loose, tighten first by hand, then another half to 3/4 turn, at most, with the pliers. Add some water and check it doesn't leak, and you're good.
Good Luck!
Nov 06, 2015 | CIRCLEWARE Shangri La Beverage Dispenser
Need a new wire harness for dispensing buttons
Sorry we have no wiring harnesses or any parts for anything.
Mar 20, 2014 | Maytag SkyBox MBV1976A Beverage Dispenser
Problem with Doppio dispenser
2 weeks, i would return to kohls. your other option is to call circleware and have them ship you replacement spouts.
Dec 03, 2013 | CIRCLEWARE Doppio Double Beverage...
I have a Beverage Air Beer Dispenser Model # DD235-GC I fill with condensation when running. Don't see any way to deal with the water. Machine was purchased in 1960
it is just condensation,so if it aint got a drain hole you will need to put silica gel cristals in a cloth bag to soak up condensate.and dry them in the oven as normal.....
Jun 14, 2010 | Beverage-Air BEVBM23 Commercial Beverage...
Maytag skybox-2 problems
maybe bad fans and a dispenser motor post your email and iwill send you the svc manul so we can look into it deeper
Mar 03, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Rack Not Dispensing, Looking For a Replacement Motor
Let me tall you what we have just learned...
1. When Whirlpool bought Maytag, they dumped the Skybox and all parts associated with it. The parts are no longer being manufactured from what they tell us.
2. We have had our unit less than 3 years and replaced the two center motors and have the bottom one going out now.
3. We are having cooling and icing up issues.
4. When you speak with Whirlpool they are unwilling to help.
5. We have gone to electrical supply and repair folks and since the motors are not marked, they say it could be one of about 1000!.
6. We are ordering parts from parts select so we have some.
I think we should find a way to rally together and get some cooperation form Whirlpool. $600+ is a bit much to spend for a couple of years use.
Jan 12, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Refrigerators Logo
41 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
