Question about Refrigerators
I wanted to know if I could purchase a replacement Portofino 2.5 gallon glass dispenser only.
Have a ge profile refrigerator went completely dead,repair man replaced mother board and control panel still not working, fridge is only 14 months
If there is no power after the repair man replaced the board and panel, the repair job is not complete. Have the repair man finish the job.
May 03, 2016 | GE PFE29PSDSS 29 cu. ft. French Door...
Ge profile refrigerator temperature setting
Sounds like the damper controller is stuck due to obstruction or isn't working at all and needs replaced.
Jul 31, 2014 | GE PFE29PSDSS 29 cu. ft. French Door...
Are plastic condiment dispensers better than ceramic or glass ones?
Plastic condiment dispensers are less delicate than ceramic or glass ones, but plastic is a material that absorbs odors and tastes after time. Therefore, for restaurants and fast foods who need many dispensers and want them to be more resistant over time, plastic is definitely a better choice.
However, for homes, where the dispensers sit in the kitchen and the condiment stays in the dispenser for longer periods of time, i would suggest buying prettier ceramic or glass dispensers.
Aug 14, 2013 | Home
Are all aquariums made out of glass? We want to buy an aquarium for our home but I don't know much about what to look for.
No. Although many aquariums are made of glass, some are made from acrylic plastic. While glass aquariums are cheaper per gallon and harder to scratch, acrylic versions weigh less and are harder to break. You need to consider all of the advantages and disadvantages of each and then make your decision.
Jul 31, 2012 | Fish
Ecomax 400 400-17 Glasswasher is not drying glasses completely. Streaks left on glasses
It sounds like the rinse aid has run out or is not dispensing. streaks on glassware is the usual symptom of this. Check and refil the dispenser. On the final rinse, open the door and you should see soap foam , which will let you know the rinse aid has ejected, or alternatively, if you havent had to fill the dispenser in a long time, I would say its not ejecting. these are not usually repairable and you will have to purchase a new rinse aid dispenser from the manufacturer. I always suggest usung " finish" rinse aid, its the best.
Jul 31, 2011 | Hobart Dishwashers
Our Ice and water has a awful taste now. It wasn't used for about 2 months, now it taste awful, do i need to have some one come look at it.
You need to replace your filter, but first run about 5 gallons (the more the merrier) of water through the dispenser. After you do so, then replace the filter and run another gallon of water through the dispenser. The idea is that you will want to clear all of the water through the reservoir inside the fridge compartment and give your water a "fresh start". IF after you try this you still have a foul taste, you can call a servicer and have the reservoir replaced but you should be all set with this method.
Good luck with this!
Aug 19, 2010 | KitchenAid KSRI25FN Side by Side...
Water leaking out of bottom of fridge....
brand new??? if so this is quite normal, youll need to "purge" the holding tank andthe water lines of any air in the lines, generally pulling 1-2 gallons of waterthrough system is addequate
Jan 15, 2009 | Whirlpool Refrigerators
GE Stainless Steel side by side fridge GS425JSRF - 2 ys old
Make sure there is no obstructions from the time the ice leaves the chute until it drops into the glass. make sure the motor that moves ice and out to the area for the cup is stuck or seized up let us know thanks
Aug 25, 2007 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
