Question about Toro Garden
Toro recycler front wheel drive stopped working then squealing.
  • Toro Master
  • 11,695 Answers
The belt is probably broken. replace it
Posted on May 15, 2017
Testimonial: "Thanks to all for your help. Found a small acorn between the belt & the wheel. Self -propel worked after removing the acorn. Belt is pretty beat up though so will replace."
How to replace drive belt on toro recycler
First thing you need to do remove spark plug wire.. Then I would go to the website for Toro have the serial number ready there you will see the full picture of the way it is then go from there that's the best way with out seeing it. Good luck
Sep 15, 2012 | Toro Lawn Mower With Toro Power Tools
Toro 22" recycler Mod
Got the same problem with mine, replaced the drive belt, removed the wheels and checked for rocks and pebbles, greased, checked also bottom of gearbox. grease was present no broken teeth, top pulley has excive side to side play. Have not disaasembled yet. Hope someone would have had a solution here.
Apr 11, 2011 | Toro Lawn Mower With Toro Power Tools
Front drive wheels won't engage
Is it possible that the belt has either broken or come off the pulleys? Next step would be to remove the cover and see if there is something preventing engagement or if you see any broken parts. May even be as simple as lubricating the cable/levers.
Apr 10, 2010 | Toro Lawn Mower With Toro Power Tools
My toro recyclers self propel drive wont engage. belt and pully run and turn but wheels wont.is it the gearbox itself??
most likley it is the gear box has failed but first take one of the wheels of to make sure that the plastic teeth on the weels didnt go bad (unlikley but wishfull thinking)
Jul 11, 2009 | Toro Lawn Mower With Toro Power Tools
How to remove plastic front wheel drive cover on Toro Recycler
On my Toro recycler, I also had the front drive stop working -- and fixed it after reading the solutions here.
First, the plastic cover on the top deck that goes over the front drive mechanism must be loosened enough to pull it up. Before you can do that, on the underside there is one screw to take out.
Once that's done, all you have to do is pry the plastic cover up enough to see the belt and pulley that make up the front drive assembly. On mine, the belt had simply come off the pulley. Putting the belt back on, then tightening things back up is all it took to put the Toro back in sel-propelled happiness. Good luck!
Mar 07, 2009 | Toro Garden
3 blinking lights and no picture
The whine or squealing you hear is either the color wheel or fan. To determine which, when the noise is heard from the set, turn it off and listen carefully. If squealing stops immediately then Tthe fault is the color wheel, not the fan. And sounds like that are generally the color wheel. A new color wheel is Samsung p/n# BP96-00250A for this model. Vance Baldwin carries them for $97.20 plus shipping. https://www.vancebaldwin.com Logon as guest, select parts and copy past the above part number in without any dashes. Good luck... Bill
Jun 08, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Garden Logo
57 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
