Question about Garden
1040 will start after change plug and putting in new gas.
2 Suggested Answers
  • 36 Answers
SOURCE: Troy Bilt Rear tine tiller model 643 Bronco, won't
did it run out of gas when you added gas it could be that the fuel line has plugged up with something from the bottom of the tank take the fuel line off and try blowing threw it and take a air hose and blow out the carb and carb cleaner
Posted on Jun 05, 2010
Can't start my 2008 yamaha 540 was cold that day ran out gas put gas. Didn't start
Try lots of gas line antifreeze and change the fuel filter. Spark plugs should be dry, you may have plugged filter or water in the gas or both
Jan 28, 2015 | Yamaha 2005 VK 540 III Base
What is the piece protruding out the bottom of the carburetor bowl on a Cub Cadet LTX 1040 lawn tractor
Fuel shut-off solenoid (anti backfire device). Check it for proper operation by removing from bowl, plugging it in, ground it against the crankcase, and turn the key on with the brake pedal depressed. You should see the plunger suck in. Turn the key off and the plunger will poke back out. Be sure you have good fuel flow to the carb through the fuel line, clean/ rebuild the carb, and test the solenoid.
Sep 02, 2014 | Garden
Need help starting a gx340 honda with new ring kit ,honed cylander,lapped valves,adjusted valves with new ex valve seal.started warmed up and changed throttle level from low for 10 min to med for 10 min...
If there is air in the tanks, it will be harder to crank, drain air out before starting, Also check spark plug. Sometimes i put gas where the plug goes, just a little pinch of gas though. put spark plug back and give it a few cranks.
Oct 02, 2013 | Honda Jenny GT8HGB-30P 8hp 30 Gallon GX...
My leaf blower doesn't start, I put new gas in it & put new sparkplg but doesn't start. Please help me
you list it as an electric vac if it s gas ans you have changed gas and plug if its older you gase lines could be brittle I had to change them on mine to get it to work
Sep 17, 2010 | Craftsman 225 Mph Electric Blower Vac
Troy Bilt Rear tine tiller model 643 Bronco, won't start,it ran out of gas, put in new gas and it started but wouldn't stay running. Put in new spark plugs, cleaned filters, changed out gas,still won't...
Jun 05, 2010 | Troy-Bilt Pony Garden Tiller
Briggs and Stratton 6.5 hp won't start- not sure gas is getting to the spark plug, just overhauled the carb, changed oil and new spark plug
First you could make sure you have spark. Take the plug out and then plug it into the black wire. Set the end of the spark plug near the frame of the lawn mower. Pull the cord one time to see if there is an arc from the plug to the mower. If you have spark, I would put the plug back in. Before putting the plug back in I would spray a little bit of starting fluid. See if it will fire up with the starting fluid in there. If you have a true good spark, it should fire up. This may be enough to get some gas going in there as long as you have the lines hooked up correctly.
Aug 03, 2009 | Craftsman Garden
Wont start with new plug. I can smell gas, but none on plug
Check the start stop switch, sometimes they can get dirty causing the saw not to get spark. Also maybe check Your air cleaner. if it's clogged it may be flooding itself out?
Jan 26, 2009 | Makita DCS6401 20 20",64cc Chainsaw 2...
Garden Logo
32 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
