JD stainless steel garden pull type fertilizer spreader settings manual
Material settings page
SOURCE: I have a Scott Rotary Fertilizer Spreader. When I
If the wheels turn( that is you can push the spreader easily) but the vertical shaft that spins the broadcasting plate doesn't, seems like the gears connecting the axle to that vertical shaft are worn; but if the wheels just slide along the gropund without turning then it would seem something right under the bin is keeping the verical shaft from turning. But I'm NOT an expert; I'm looking for an answer myself,
Posted on Mar 16, 2009
SOURCE: Need a quick way to convert Scott's settings to Earthway setting
add 10 - scotts turfbuilder spread at 4 on a scotts spreader should be on setting # 14 on an earthway spreader. happy yardening !
Posted on Jun 11, 2009
  • 125 Answers
SOURCE: need to apply lawn fertilizer at a rate of 5 lbs,
http://www.gardentech.com/spreadersettings.asp
this is a link which will help you. Your setting should be on 7-8 using a criss-cross distribution pattern
Posted on Sep 07, 2009
Testimonial: "thanks pal, worked great"
SOURCE: repair parts for a Republic EZ Broadcast Fertilizer Spreader
I have a problem with a broken handle it looks like there is no parts for the EZ Broadcast Spreader. The sad part is the rest of the unit is in great condition.
Looks like plan obsolescent!
Posted on Dec 16, 2009
  • 8 Answers
SOURCE: As the cyclone brand spreader is
CYCLONE ROTARY
2.0
EARTHWAY ROTARY
6.0
EV-N-SPREAD
6.0
K-GRO ROTARY
.75
ORTHO ROTARY
.75
PRECISION ROTARY SB50
1.50
RED DEVIL ROTARY
1.50
REPUBLIC EZ ROATRY
.75
SCOTTS SPEEDYGREEN 1000,2000,3000
2.12
SCOTTS BASIC BROADCAST
2.12
SCOTTS EDGEGUARD BROADCAST
2.12
SEARS ROTARY
.75
TRUE TEMPER ROTARY
1.5
VIGORO ROTARY
1.50
SCOTTS STANDARD ROTARY
2.12
CRAFTSMAN
6.0
SCOTT’S EASY GREEN
25
SCOTT’S HANDYGREEN
__________________________________________
Drop Spreaders:
K-GRO DROP
2.25
ORTHO DROP
2.25
REPUBLIC EZ DROP
2.25
SCOTTS ACCUGREEN 1000
3.0
SCOTTS ACCUGREEN 2000
3.0
SCOTTS ACCUGREEN 3000
3.0
SCOTTS DROP PF1, PF2, PF3, PF4
3.0
SEARS DROP 2.25
Posted on May 01, 2010
I have scott drop spreader and I want how it will setting for fertilizer
Check the fertilizer bag for instructions. It will tell you the number to set it at for a drop spreader and a broadcast spreader.
Aug 14, 2011 | Scotts Company Garden
I have lost my instructions for my hand held spreader. The numbers on the side that control the outlet of whatever is in the spreader--do these indicate the number of pounds per 100 sq. ft?
Below is a list of spreader settings. You may want to call Scotts at 800-543-8873 and verify the product you are using is able to be used in a hand held spreader.
  • For fine grass seed (blue, rye, fescue) use setting 1
  • For coarser seed (tall fescue) use setting 2
  • For light fertilizer (Scotts fertilizers at a regular rate) use setting 3
  • For heavy fertilizer (Scotts fertilizers at a heavy setting) use setting 4
  • For pelletized fertilizer and ice melt products use setting 5
Hilary @Scotts
May 16, 2011 | Scotts 71133 Handgreen II Hand Held...
I want to convert scotts spreader settings to a sears broadcast spreader
I worked for Scotts years ago and as far as I know there is no conversion. Best idea is to look at the pattern the fertilizer granules make with a Scotts spreader. Then try to duplicate it with the Sears. If you err, go lighter.
Rob
Apr 18, 2011 | Garden
Speedy Green Parts
Replacement parts for your model can be found at amazon, click here and take a look: Amazon com scotts lawn parts. I hope this was helpful. Cheers
Mar 18, 2010 | Scotts Lawn 73740 SPDY GREEN 3000 B/C S 3...
Model 300 runs out of fertilizer
Since I didn't have a manul, I downloaded one from Scott's and used that to calibrate the spreader which was out of calibration.
Apr 08, 2009 | Scotts Company Scotts& Accugreeen 2000...
Flow control lever doesn't open hopper door
your fertilizer is got clumps in it. I have experienced the same when using TSC fertilizer (cheap and wet).
Mar 22, 2009 | Agri-Fab 175lb Agri - Fab Tow Broadcast...
How to use Spreaders
Follow the specific spreading instructions that come with your spreader. When working with spreaders, always load a spreader on a surface where an accidental spill can be cleaned up and won't matter (driveway, walkway, etc). Common practice is to first run the spreader around the periphery of the area you are treating; this ensures a consistent application around the edge of your lawn. Next, you run the spreader back and forth within the area bounded by your first perimeter run. Always allow on overlap to avoid missed streaks or "holidays". Ideally, apply your material at half the recommended rate and make two sets of runs, first back and forth in one direction, then again another set of runs at 90 degrees to the first set. This ensures a good consistent coverage and it compensates for any uneven patches.
Aug 27, 2008 | Scotts Company Scotts& Accugreeen 3000...
26 people viewed this question
jasbo
jasbo
