Question about Konica Office Equipment & Supplies
I have a Konica c450 and It is telling me section not closed properly when paper is put in top section but it is closed.
  • Konica Master
  • 6,680 Answers
Which section the cover on the right or the left of the doc feeder? if so check that some did not brake the tab that tells the copier that the cover is closed or that the senor that the tab acturates is not dirt or broken or bad
Posted on Feb 18, 2018
Patrillica
  • 141 Answers
SOURCE: door close message
Witch section are you talking about ????
Posted on Apr 02, 2008
oranous_comp
SOURCE: proplem with KONICA MINOLTA bizhub C450
c-3451
Posted on Nov 10, 2008
  • 12 Answers
SOURCE: Imaging Unit Problem with bizhub C450
On the end of the image unit you will find a white bit of plastic with a small screw in the middle, make sure this screw is tight and then reinstall the units(give the units a bit of a shake too)
Posted on Apr 06, 2009
taminol
  • 62 Answers
SOURCE: Printing labels on bizhub C450
Hi nwillett,
Yes and no, sorry if that doesn't make much sense.
For years Minolta recommended Avery labels, but these days they recomment labels manufactured by Howard Smith Papers, their website is http://www.hspg.com/
The thing with labels is always to use the one your copier service company suggests. Otherwise they'll invalidate you contract and you'll be liable for callouts and repairs caused by using Avery labels.
However, Avery labels are good and I have experienced very few problems with them I pressume you using the lables in the correct orientation and also using the manual bypass to feed them.
Regards
Taminol
Posted on May 26, 2009
  • 158 Answers
SOURCE: KONICA Minolta c450 in Windows Vista
go to the printers and faxes page and in the driver properties click on printing preferences click on authentcation/account track and you should be able to enter you name and password from there unless you may have to be logged on as the administrator on your computer to make these changes
Posted on Oct 23, 2009
Hi, Bizhub c450: i have a problem on scanning over the rear tray if i put paper inside message will appears close section properly but there is no other error code appearing on the screen.
When you say the rear tray what do you mean, ON the document feeder tray or raising the document feeder up placing the document on the big glass. Never heard of a rear tray?????
Feb 04, 2015 | Konica Minolta bizhub C450P Laser Printer
KONICA MINOLTA C450 DEVELOPER
Sir/Mam you do not need developer for the C450 it already comes inside the image unit the copier tells you to replace.
Sep 05, 2014 | Konica Minolta bizhub C450P Laser Printer
When I scan a white or Blu or green line on my paper scan show
It might be that you need to clean the printer heads. Your manual should tell you how to do that; also you might be able to Google an online manual for you printer model.
Jul 04, 2014 | Konica Minolta bizhub C450 Scanner
C450 c-0204
Remove the 2nd draw and ensure no paper behind it, THEN REMOVE ALL PAPER IN THE DRAW ON THE LEFT SIDE IT IS NOT A STORAGE AREA!!!! IT is use for 11 x 17 paper, or you have a burned out motor worse case a burned out motor that took the main control board that controls the motor also.
Feb 24, 2014 | Konica Minolta Office Equipment & Supplies
C450 c-0204
Pull out the cassette and check the paper capacity not to exceed the maximium level. Clear any irregular or untidy paper if any.
ADF of Minolta C450 is not working
the sensor switch were you put the paper in detects the paper is there if the switch is working the adf board is fualty or the cable between the machine and adf broke from all the open and closeing after that the board in the copier were the cable plug in may be faulty swop the around with annother machine if avalible.
Mar 14, 2012 | Konica Minolta bizhub C450P Laser Printer
Bizhub 500
There is another cover at the down right side of machine.Below the side door.Open it and then close it.Then bring out the tray and close it.Machine will start working.if not then tell me...
Nov 15, 2011 | Konica Minolta Office Equipment & Supplies
In the lcd indicate close section properly, ; the sections is wher are the synchronizing roller, duplex unit transport, manual feed paper. I have cheking all sensors in this section they are oK, the ...
you might disconnect all power and reconnect to perform a power on reset. Then if the switch that detects the section is open or closed is working properly, then the circuit board that reads the switch is defective. Replace components as needed. the switch should be checked with a volt/ohm meter.
Dec 23, 2017 | Konica Minolta bizhub 250 All-In-One Laser...
Bizhub C450 error (C-0212)
C0212 is a LCT (large capacity tray) shift motor, or lock release failure (they both use the same code)
Open the lower paper tray, and look for anything unusual.
Sounds like the paper was loaded incorrectly, and the tray tried to lift.
Feb 04, 2008 | Konica Minolta bizhub C450P Laser Printer
Top Konica Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
NOEL
NOEL
Andrew Taylor
Andrew Taylor
Are you a Konica Office Equipment and Supply Expert? Answer questions, earn points and help others
