Question about The Watches
Does watch light up in the dark? - The Watches
My casio protrek 2500t watch is in power saving mode but even after keeping in dark for hours between 10pm and 6 am the display does not go off.Please help.
I own the same PRW-2500-1A (all black).Check if under the hours reading, PS appears.If yes,power saving function is activated.
Normally, Power Saving Function is enabled automatically (if activated) if the watch stays in complete dark for sometime.If after a couple of hours in the dark the watch comes suddenly under bright light,the display goes on immediately.Hour interval (10pm-6am) has nothing to do with Power Saver.
Try the following:
a)Deactivate and reactivate (or vice versa) the PS.
b)Leave the watch in the dark for a couple of hours .Then,still in the dark,try,using a very low power light (just that you can,barely read) to check if display is blank.If not you may have a problem with the light sensor found at the bottom of the display.Will be a very rare case but you have to take the watch to a CASIO authorized service.
Apr 29, 2016 | Casio Watches
How do brighten the dial so I can see the time in the dark. The watch was in direct sunlight 3 days & I still cannot see thedial in the dark!
At one time luminescent dials were made with Radium Luminous paint with a half-life of 1600 years so the "glow" didn't go away soon. And getting enough of the material to cause it to glow sufficiently was dangerous to the wearer. Since then Tritium mixed with zinc sulfide was substituted. Please see: http://wornandwound.com/2013/08/23/seeing-in-the-dark-luminescence-in-watches/
Later, non-radioactive materials were used. Unfortunately, all these materials decay and are less efficient. If you have a small flashlight you can hold it to the face of the watch and it will then get brighter...for a while. But, soon it will fade again. Holding the watch under a light for a long time won't help. The reason is that the material can't hold a "charge" and the excited materials have lost much of their ability to luminesce.
Dec 27, 2014 | Citizen Watches Citizen Eco-Drive Black...
Why my watch not display or blank after keep for long time
As this is a solar powered watch,there is the PS (Power Saver) function.
If PS is ON (which is by default) display will become blank if watch stays in the dark for sometime.As you bring it back in light,display will be activated automatically.You can switch PS to OFF and have display activated all the time even in dark (not recommended) but in this case battery will run short quickly.And this watch needs power as it is a multifunction watch + atomic time setting.
Nov 10, 2013 | Casio PRG-130T-7VDR PRG-130-7 Protrek...
The background light comes on when placed in the vertical. I need to turn it off to save battery life
The Auto Light feature of your watch has been turned on. To turn it off, press and hold the button that is on the bottom right of your watch for about 2 seconds. In the upper right of the face of your watch is a circle with some text on it. There should be a down pointing triangle in the upper right of that circle. Below that triangle there should be a dark mark before you turn off the auto light. After you hold the lower right button down for the 2 seconds that dark mark should turn off. The Auto Light feature will also turn itself off after six hours to help you to conserve your battery life.
Mar 25, 2011 | Casio Sport Watch White Resin Watch for...
Watch does not glow in the dark
Is it suppose to glow in the dark? You don't give any information about the watch, make, model, age. If it was suppose to glow in the dark and it is old, that function may have deteriorated beyond normal limits.
Have yo sat your watch in strong sunlight for several hours then checked the glow in the dark feature? Is this a watch that glows as the result of a light in the watch powered by a battery that may be weak?
I suggest you take your watch to a jeweler in your area and have it gone over to assure proper operation.
Thank you for your interest in FixYa.com
Feb 25, 2011 | Watches
Watch runs ok in the light but stops in the dark.The watch is 14 years old
the battery is not holding a charge. replace the battery or sleep with the lights on
Jan 14, 2011 | Citizen Eco-Drive BL006056H Wrist Watch
U.S. Polo Watch (US8170 on back)trying to keep the light on
All watches are preprogrammed for all the functions, so, there is no possibility to make it glow for longer or continuously unless you press and hold the light button or just repeatedly push it again and again. Do not forget that prolonged use of light function will shorten watche's battery life significantly.
Jul 31, 2010 | Bulova Watch
I bought an AM3695 watch from America.The booklet that came with it appears to belong to a different watch. i wanted to know if my watch has any sort of back light or aid for telling the time in the dark....
Use this link and browse through my TIPS AND TRICKS: http://www.fixya.com/MyProfile/tips.aspx?usrid=1700524. You will find manual for your watch here.
Apr 24, 2010 | Fossil AM3695 Wrist Watch
Watches Logo
14 people viewed this question
Top The Watches Experts
D. E. Hev
vince
gbob59
Are you a The Watch Expert? Answer questions, earn points and help others
