Question about Baby Lock Sewing Machines
I have a Baby Lock ellangeo plus Model BLL2 - I am trying to use outdoor thread and the bobbin is messing up - can anyone help?
SOURCE: bobbin tangles up thread and jams machine
Hi, Is it your bobbin thread or the top thread wrapping around the bobbin. I just got a used PE150. The top thread keeps wrapping around the bobbin. It is not picking up the bobbin thread. Did you find a solution for your problem?
katfou
Posted on Feb 08, 2008
  • 27 Answers
SOURCE: Threading three thread Baby Lock Overlocker EF 405
Ther should be a color coded threading chart on the front inside cover.
Posted on Feb 23, 2008
SOURCE: Adjusting Bobbin Tension
I looked forever to find this darn green bobbin screw. Around the opening for your bobbin is a plastic cover. If you slide it forward it will pop right off. Once you remove this, the bobbin case will lift right out. On the front you will see your green screw for adjusting your bobbin tension.
Posted on Sep 25, 2008
yeroc
  • 397 Answers
SOURCE: Baby Lock BL3-406 tension setting messed up.
set all to 3-4
Posted on Nov 27, 2009
SOURCE: baby lock quest, blq2 bobbin problem
Concerning the Babylock Quest when using the reverse option I seem to be reading a few somplaits what is the best way to reverse without causing and adverse problems?
thanks
sewingcindy
Posted on Jun 13, 2010
How to thread my baby lock b15 machine
Something here may be helpful. Although they may not be your particular model, sewing machines tend to thread the same from model to model.
Be sure to ALWAYS RAISE the presser foot when threading the top thread!
Baby Lock b15 threading Google Search
Apr 24, 2018 | Baby Lock Sewing Machines
Baby lock quest plus and the bobbin thread is all loopy. I have done everything. I believe it is in tension discs. When I move it to 8 or 9 it sews ok. When I sew faster it seems to start looping.
Is it really the bobbin thread that is loopy--not the top thread looping under the fabric? If this is the case, it is called bird nesting. (problems appearing under the fabric are usually a top thread issue, problems on top of the fabric usually indicate a bobbin issue)
Remove the top thread from the machine.
ALWAYS RAISE the presser foot and rethread from the beginning. You may need to loosen the top tension to get it where it should be. The two threads should meet in the middle of the fabric.
If the bobbin thread is still too loose, then an adjustment may be needed to its tension.
Understanding Thread Tension Threads
Feb 10, 2018 | Baby Lock Sewing Machines
I have a Baby Lock Audrey. The bobbin thread is "nesting". I have tried rewinding the bobbin and rethreading the needle and bobbin thread but that hasn't helped.
Check that it is actually the bobbin thread that is nesting. Generally, bobbin thread issues appear on the top of the fabric and upper thread issues appear on the underside of the fabric.
If it is in fact the bobbin thread, the bobbin thread tension may be off or malfunctioning.
If it is the upper thread nesting under the fabric:
1. Remove the thread
2. Install a brand new needle
3. ALWAYS RAISE the presser foot. This releases the thread tension so the thread will seat properly.
4. Rethread from the beginning and check the thread path is correct.
5. Set the upper tension at the midway point.
6. Check that the bobbin thread is loaded properly
7. Retest the machine.
If it continues to create thread nests under the fabric, tighten the upper tension.
Jun 22, 2016 | Baby Lock Sewing Machines
Bobbin jam babylock 1506
Ooo ouch! sounds like you have a pretty bad timing problem and or a damaged bobbin case. Since it is a baby lock I would suggest taking it in for repair.
Sep 08, 2012 | Baby Lock Sewing Machines
Sewing serge it wont sew after i thread it it just keeps breaking the bottom thread I dont have the manual i lost it
change the needle--flat side to the back of the machine
check to see if
1. bobbin is inserted correctly
2. are there any burrs on the needle plate or bobbin area
3. change thread--use every thread guide
name of machine & model number is not shown
if this is a baby lock machine then go to the website & contact customer service about a manual
Mar 28, 2012 | Baby Lock Sewing Machines
Bobbin not even
buckmanfamil....I use my finger to keep tension on thread when i fill my bobbin.i also pusu thread slightly up & dwn to even it out on bobbin.works for mine ! I luv my Baby Lock !!
May 29, 2009 | Baby Lock Sewing Machines
Upper thread keeps breaking bobbin thread grtting cut on bobbin,
you need to change your needle first. then if that does not work you may have a small area on your bobbin case that has been damaged
May 22, 2009 | Baby Lock Esante
Not picking up the Bobbin thread
Sounds like you have to take off the throat plate and clean out threads under it.  Sometime they ball up and prevent the needle from going down and catching the bobbin thread. You can't see themuntil you take off the plate.  Follow the directions.  It is easy.
Dec 28, 2008 | Baby Lock Ellure
Sewing Machines Logo
27 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Jon Piercy
Jim Goldsmith
Jim Goldsmith
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
