Question about Oster Refrigerators
Where would I find the float switch for my portable ice maker? Ice full light is on and unable to make ice. I have an oster ice maker Thanks Paul
  • 878 Answers
SOURCE: Ice Maker
Sassy, the red led should flash 2x followed by a pause, repeatedly with the door open. If you hold the left side flap down, it should stay on steady. If it does this you know the optics are ok. Sounds like you just hooked it up to water. The ice maker thermostat has to be at least at 17 degrees before it will call for water and then it will have to prime the lines to the ice maker first before filling the mold. The easiest way to reset the icemaker is to unplug the refer for 30 seconds. Other things you want to check are that the ejector blades (blades that push the ice out) are in the 2:00 position. Check to see that the fill tube that fills the mold is not frozen over. I have a feeling that your lines just needed to be primed. Hope this helps you understand this unit a little back.
Posted on Apr 05, 2007
  • 2651 Answers
SOURCE: Ice maker quit working
good sign its flashing , woth door open depress the left side flap oppiste the blinkin light. does the light then go solid red??? i fso its an indication that the electricl eye is operating ok .
theres a screw 1/4 in. along the right side underneath the icemaker itself, youll need to removeit and the cover its holding down. you can then slide the ice maker assy foward and out of machine,There will be another litle tab along loeft side uder ice maker youll need to depress to ppulll unit out. pry off the white cover from front of the ice maker assy itself and have a look at the main gear 2 in. round, is it broken off, or on its way top breaking( sometimes the tabs that hold it on to the ice maker module itself break preventing operation, if this is the case youll need to repalce the ice maker assy.
Posted on Oct 31, 2008
SOURCE: Polar Ice Maker Portable
there is a little sensor inside on the top right, it is a little wire if there is anything on it it will not work, i took at small pair of pliers and gently cleaned it
Posted on Mar 06, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Whirlpool Gold Ice maker doesn't work
You definitely have something wrong with the ice maker if the water has turned to ice Schmerold. And the IM is not harvesting. The way it works is the IM needs 28 degrees F to harvest. If the coils below in the condenser are dirty the IM won't try to harvest. The Ice Mold thermostat is mounted on the firewall of the Ice mold in its own little cubby whole. To access it you will need to remove the head. Then remove the shell separating the Ice mold from the heads housing. There you will find the ice mold thermostat. It's only function is to get it on. If the temperature is right in the freezer. To test this precious thermostat one needs only to stick it into a freezer and let it hang out for an hour or so. Then grab it and check it for continuity. If it is open it has failed and belongs in the file 13. It is easily replaced and inexpensive.
On your model, ice maker operation is controlled by an optical sensor mounted on both sides of the freezer liner. The usual failure of this model is a bad emitter board, located in one of these recesses. You may view the service instructions for checking this sensor.
Visit my site, I offer free help and model and parts number search feature. Movies and instruction manuals for most brands. click on link below, Thanks, Sea Breeze
I will also send free manual for you through email. And Rate my assistance.
Posted on Apr 04, 2009
  • 1606 Answers
SOURCE: KitchenAid Fridge, Ice maker not working - red light blinking
Replace the icemaker . The laser receiver (on right side ) is supposed to blink twice then pause then twice repeatedly .Normal. Also clean the coils under fridge .
Posted on Aug 02, 2009
Ice full light on
There is a float switch or sensor in the basket. Have you got a manual?
Apr 13, 2014 | Sunpentown SPT IM-100 Portable Ice Maker,...
Ice full light stays on, so no ice
check for the sensor/ float switch that tells the machine it's full
Feb 22, 2014 | Oster Osim22sv 27-lb Portable Ice Maker
Ice full when no ice portable ice maker
There is some sort of arm that fits into the ice tray; when the ice fills up the tray the arm is pushed up and a switch connected to it will open the circuit and prevent any future ice maker operation(s). That switch has to be closed for unit to work!
Nov 12, 2013 | Igloo Cooler Igloo Portable Countertop Ice...
Zb01 ice maker
Hi need help my ice maker red light keeps flashing , it a platinum portable counter top zb01 maker what can be wrong
Jun 02, 2013 | Refrigerators
Portable emerson ice machine
The sensor in the bin that detects the ice to tell if its full could be bad. That or the control board.
May 12, 2013 | Kitchen Appliances - Others
It suddenly quit working - it is not cold and is saying it is full
open the back panel and the white box with all the wires and find the wire that leads to the silver instrument that senses when it is full and unplug it
Dec 05, 2009 | Sunpentown SPT IM-100 Portable Ice Maker,...
Refrigerators Logo
35 people viewed this question
Top Oster Refrigerators Experts
Charles T Nevin
Charles T Nevin
JC Garza
JC Garza
Are you an Oster Refrigerator Expert? Answer questions, earn points and help others
