Question about Pool & Spa
WHat do I do if the LED code on spa pump says E 90
How to fix e90 code? is there a fuse or reset button?
What does code E90 mean? What should I do if code E90 appears on my air bubble spa control panel?
If alarm code E90 is displayed on the control panel, it means no water is flowing through the system. Check the attached troubleshooting guide.
Apr 04, 2016 | Intex Pool & Spa
Air pump not working and red light stays on reset. Is the pump bad or electrical problem?
It is a toy spa after all, not really meant to last long.
According to Intex, your fault code is due to low or no water flow. Most common problem that we see is bad filter. You either need to clean, soak, or just replace them! Because they are so small, I wouldn't even bother with cleaning them, just have a few handy, and just install new ones.
Apr 12, 2015 | Pool & Spa
Code 90 on portable intex 200 gal spa
Sensing problem with sufficient water flow!
• Ensure the unit is plugged and switch on.• Ensure the outlet cover grid is clean and free
from obstructions.• Clean or replace the cartridge, see
Maintenance and Storage section.
• Ensure the in/outlet connections on the spa tub and filter pump are not blocked.
• If problem persists, contact Intex Service Center.
Feb 28, 2015 | Intex Pool & Spa
We have a LED code showing on the new Intex pure spa. E97 Dry-fire Protection. What does it mean
Aug 03, 2013 | Pool & Spa
What is code 90
Code 90 is low flow indicator
you have air in the system or a blockadge
open bleeders while pump is running for about a minute to release air
If that does not work check your hoses
Usually there is a build up right at the motor where the water goes in
Jul 25, 2010 | Intex Automatic Salt Water System for ...
What does code 90 mean
code 90 means low water flow
start by cleaning your filter with high pressure from garden hose
check all tubes for blockage
also check where the inlet tube connects to your pump, sometimes hair builds up there and blocks other debris
also check your electro cell for build up
also check your flow sensor this can be removed easily
Aug 12, 2009 | Intex Automatic Salt Water System for ...
Pool & Spa Logo
60 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
