How to download the manual
SOURCE: Need manual for Euro-Pro professional Model K5345B combo oven
here is a link to allow you to download the manual. go to this link and choose get manual.
hope that helps:)
SOURCE: russell hobbs microwave will not work, but grill & oven ok.
The magnetron has failed. This is the part of the oven which produces the microwaves and they can fail without warning at any time after they leave the factory. Failures are not as common as they once were, but unless the oven still qualifies for a warranty repair it's always more cost effective to scrap the oven and buy a new or used replacement.
In your case, you may be able to recoup some money by selling your oven purely as an electric fan oven with grill. The magnetron failure does not in any way indicate that the grill or fan oven are about to fail.
If you do decide to replace the magnetron, make sure that a new microwave gasket is fitted as well; this is a small wire mesh doughnut (US= donut) which fits around the neck of the magnetron and is crushed into place when fitted. Once used they cannot safely be re-used.
SOURCE: my ifb microwave oven is getting hot outside while
Normally when u cook food in microwave the fod is cooked by microwaves, which means the heat is generated with in food. The temperature inside is never too hot and all the heat produced is absorbed with in the food.
On the other hand when the grill is switched on, a separate heatting element gets switched on. You can see this red hot element on the top side of inside of microwave. the heat from this element gets transferred to food through air circulation. But partof heat also gets transferred to the walls of microwave oven. This is the reason the wall feel hot during use of grill.
As i see ther is no problem with the microwave itself. Jut kep delicate thngs a bit away from the microwave.
SOURCE: I need a manual for Emerson Microwave mwg9111sl
When replacing the bulb in an Emerson, Microwave. Model mwg9111sl. Can you replace the bulb or the socket and bulb?
SOURCE: I WOULD LIKE TO DOWNLOAD MANUAL FOR ELECTROLUX
I found it! There isn't a direct link from the Electrolux home page (shame on their webmaster!), but I got it with a search engine.
The first 12 pages are important generic information about microwave cooking; after that it gets into details on your model.
Testimonial: "thank you very much, i was struggling to get to a manual as close to this one.I suppose this should solve my issues with the microwave:)"
