Question about Water Dispensing & Filtration
Want to know what is a default setting for degree of hardness for my Kenmore water softener?
2 Suggested Answers
  • 306 Answers
SOURCE: I need to know how to set the program on an elite water softener
You can find your owners manual here.
Your system is a fleck 5600SE
Posted on May 08, 2011
Bypassing softener when watering the lawn. Uses too much salt..can we turn off the water softener when we are watering the lawn and how do we do this.
leave the setting on the water softener alone as it will become a tiresome exercise
place a "t" joiner in the water line before the softener with a tap on the outlet side to the softener and a tap on the outlet side to the lawn hose and fix your lawn hose to that
That way when you want to water the lawn adjust the taps so that the water softener is cut off and the hose is turned on
or when using the softener the tap is turned on and the hose is turned off
use ball valves ( 90 degree action)with a handle and the direction of the handle will determine the direction of water flow
Jun 19, 2016 | Dishwashers
Water Softener is 1 month old. Salt water up to the 4 mark after recharge cycle. How much brine (volume, please) is supposed to be drawn out of the salt tank upon recharging?
it depends on the concentration you have set in the controls if you set it to a high percentage ( hard water) it will draw out about 40 lirs of salt water
That is to say , if you have the reservoir filled to the overflow hole before , then it will empty the reservoir and may require you to fill it so that it keeps sucking until it finishes the setting time
there will be volumes setting in the user hand book that you adjust to for the hardness of the water
Feb 01, 2016 | Kenmore Ultra High-Efficiency Water...
I replaced old non working culligan system with whirlpool 48000 softner three months ago. In the mornings water from faucet has orange tint until run off for about ten minutes. Water feels soft in the...
Cabinet style water softeners (GE, Whirlpoool, Kenmore, Sears) are very inefficient at removing iron. They are not designed for water with high iron content such as yours. I might suggest setting the hardness level up as high as it can go (100gpg). Indications that water softener resin is getting fouled with iron are exactly as you described. Rusty water the day after a regeneration. You may need an iron filtration system before the softener so all the water softener has to do is remove the hardness.
Here is a link for an iron filtration system that works with air. Very simple, works very well.
Jun 19, 2014 | Whirlpool Water Dispensing & Filtration
Water softener
You have SWR which would mean soft water, Then there is reg which mean regenerate, the other is bach wash and off. The thing about water softeners is that you should know how hard the water is first. There is a setting inside that determines how many grains of hardness the softener treats. It appears this unit is home made and therefore is all on and not adjustable. There needs to be a brine tank that contains salt water in order to REG the system, then you back wash it to get all the salt out. So it is anyones guess what the times and amounts are.
Jun 12, 2013 | Water Dispensing & Filtration
Culligan medallist softener will not regenerate unless done manually, not sure how to set different locations. 1 set to present time, 2-2:00 am, 3-10, 4-10, 5-10, 6 is set to 71 degrees, 9 is set to U, 10...
How do you know it is not regenerating? When hard water occurs through system it may still be regenerating but not drawing brine or refilling the salt tank properly. First check to see if it is metering the gallons. Run water and check for the flashing icon. If it is not metering the gallons, the meter is bad, dirty (iron buildup) or the board is bad. Clean the eductor assembly on top of valve (under chrome plate) this may be plugged.
Here is a link to the manual for your medallist softener.
Aug 14, 2011 | NRS Fleck 5600 - 64,000 Grain Timer Water...
Have ge model 268/760 need to know the right settings to set it on
The right settings depend on the capacity of your softener and the hardness of your water before softening. If you know these, then you can program your softener with the right values. If you do not have a manual for the 268/760 you can download one from here:
Best of luck,
Jan 07, 2011 | House Brand Aqua-Pure AP102T Whole House...
Apr 12, 2010 | NRS Fleck 5600 - 64,000 Grain Timer Water...
Glassware comes out cloudy and not clean
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner. There are a few out there.
Dishwasher magic is a very good Dishwasher cleaner.
I would also recommend checking the water temp. it should be about a
120 degrees Fahrenheit when entering the dishwasher.
There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
Jun 16, 2009 | Maytag MDB9600A Jetclean II Built-in...
Dishwasher is not washing dishes.
Make sure your water is at least 120 degrees and change to a dishwasher detergent with a water softener and a rinse aid in it.
Jan 31, 2009 | Kenmore 24 in. 17032 Built-in Dishwasher
Water Dispensing & Filtration Logo
1,877 people viewed this question
Top Water Dispensing & Filtration Experts
ray gallant
Tom Chichester
Dwain Schmidt
Dwain Schmidt
Level 1 Expert
Are you a Water Dispensing and Filtration Expert? Answer questions, earn points and help others
