I replaced the control module in the rear duo-therm 600 series roof top ducted unit. Now the thermostat does not see the rear unit.
  • Heating & Co... Master
  • 1,098 Answers
Does the board have some type of personality module that needs to be transferred to the new board? Refresh the tstat to find new board.
Posted on May 15, 2017
bobotfel
  • 236 Answers
SOURCE: Duo Therm Air Conditioner Mod. 59136.331/ Control box E 6360360
Something wrong with your thermostat, but if you are using a electronic thermostat and have the indication of supply like light in your control then you can replace the miniature relay that triggers the cool mode of the unit. But no indication of supply try to check the fuse, then if not works you to replace new thermostat.
Posted on Jan 03, 2008
SOURCE: thermostat wiring for second ac unit
I replaced one unite with another and the wires are differance colors the old unites wires are red,purple,yellow,bleck and white the new one have orange,brown,cream,darkpurple,and white
Posted on Aug 02, 2008
  • 10 Answers
SOURCE: I have a Duo Therm Roof top Camper air conditioner
how old is unit and does it have refrigerant in it
Posted on May 31, 2009
motor1258
  • 6674 Answers
SOURCE: I have a dometic duo therm roof ac unit that is
It is a closed system, (ends are soldered) that said, a heating and cooling guy may be able to install fill valves and re-charge for you, but make sure you get a quote ahead of time. How old is the unit? Not normal for them to need re-charge, and I've seen them work good for 15 years, if maintained properly. Has it been completely cleaned recently?
Posted on May 27, 2010
  • 266 Answers
SOURCE: RV Dometic Duo Therm roof top AC w/heat pump Model
If the Air comeing out is the same as the temp inside the RV make sure the compressor is running and not just the fans. It could be low on freon. If freon is ok then you would need to ck the wiring to the selector switch for a short. It would be obviouse because there will be melted wires. I am leaning toword low on freon since you have already been inside the wiring/control unit.
Posted on Aug 08, 2010
Duo Therm 3109228.001
sounds like thermostat issue not communicating with relay modeule
Aug 01, 2014 | Dometic 3109228.001 Duo Therm Comfort...
Duo therm ac in my rv quit when the converter burned up does the ac need 12v to work?
there is a fuse located under the shroud on the roof AC on a circuit board that controls the thermostat to turn on the power to the Air Conditioner replace it it is marked F-1 or, on some F-2 etc.
the air conditioner works on both DC voltage for the thermostat and AC voltage for the compressor
Sep 08, 2013 | Dometic 3312024.015 Duo Therm Comfort...
RV Dometic Duo Therm roof top AC w/heat pump Model #630515.321El Serial #21631212 Yr. 2003. It is the rear unit, front unit working fine. In AC mode it is blowing hot air as if the heat pump is on. Fan...
Aug 08, 2010 | Dometic Rooftop RV Air Conditioner
Installing rv roof airconditioner heat strip
I see what you see also in the manual. The difference is the Heat Strip package that part is optional and the 600212-001 with the optional heat strips becomes the new 600315-001 I talked to Dometic Duo-Therm and the models are the same but they both are not heat pumps but the new heat strip package comes on when told to go into heat mode when you change the thermostat to heat. The part you purchased will fit both model numbers you listed for your roof top air conditioner. Thanks, Sea Breeze
May 09, 2010 | Heating & Cooling
Dometic duo therm thermostat
Try properly re-soldering the switch connections to the circuit board. Mine had separated and it did the trick for me!
Sep 16, 2009 | Heating & Cooling
I have a duo therm air conditioner think thermostat problem
Google dometic rooftop air conditioning parts!Wouldnt suggest using off brand parts maybe diffrent?if that one is set up for 12v also maybe deffinatley diffrent!!!Try cleaning condensor aluminum fins on roof top if condensor is dirty will throw whole system out of whack!!!use oven cleaner and hose with nozzle be careful not to bend fins throughly rinse off cleaner after soak period spray off completly off roof and sides quickly!!!!!may damage decals etc!!! anyhow try that before replacing parts then use factory or alike parts!!!Good Luck!!!
Jun 24, 2009 | Dometic Rooftop RV Air Conditioner
Duo therm penquin 630215 went out, replace with what??
Actually thats a, Great Idea. And far Less Expensive.
1: The only thing i suggest is, Remember that a "Thermostats" Job is to Sense when the Temperature in the room is satisfied it Kicks off the Compressor, That is its Job.
2: The Front is Desinged to Cool Just the Front Area.
3: You Have 2 options
1: Close the Rear door when just Using the "Front Unit"
2; If you choose to Leave the "Rear Door" Open, Just make sure the "Rear Unit" is on Making the "Front Unit" Work far less.
You will be fine
Please Rate me, Thanks George
Apr 27, 2009 | Dometic Rooftop RV Air Conditioner
RV Dometic AC Comfort Control Double EE Problem
I have a dometic duo-therm. The unit works great and fan blows strong and both high and low work., but air is coming out of the ceiling unit rather than the duct work. The bedroom unit works OK, but the air is strong out of one duct, and not much comes out of the others. The front unit only has air coming out on the A/C unit and none out of the ducts.
Mar 24, 2008 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
