Question about Orbit Hardware & Accessories
I have an Orbit Easy Dial timer. Is there a way to make more than one station go at the same time?
protek480
  • 1723 Answers
SOURCE: Orbit sprinkler system
Have you programmed the new one with all the info for date and time? Did you set the zones for the days you want and watering times?
Posted on Jul 02, 2009
damneddle
  • 1607 Answers
SOURCE: where can i go to
Hi there!
You can find the manual in this link:
http://www.hardwarestore.com/media/pdf-misc/607980.pdf
It is in PDF format so you need an acrobat reader to open it. If you don't have one yet you can download and install it for fre here:
http://get.adobe.com/reader/
Thanks for using fixya!
Posted on Jun 01, 2011
SOURCE: How do I get a
Welcome To FixYa
I was able to locate a manual for your timer. Go to this website
http://www.orbitonline.com/lib/media/57894-24%20rA%2812%291.pdf
Please note that this is in PDF format which means that your computer needs to have adobe reader installed. If you dont have that you can download it here
If you have further questions just reply back and I will be happy to assist you
Hope this Helps
Posted on Jun 04, 2011
SOURCE: i ned to reset the
To reset your timer, you'll need to replace the 3 AA batteries then press the reset button on the back of the housing.
If you'd like to refer to the manual, you can find the manual at orbitonline.com. Just click on the "manual and guides" link under the "Support" heading found on the left hand side of the home page. Enter the model number of your timer "62015" and click the quick search button. Your search will provide a link to the manual in up to 5 different languages in a pdf. file format. Click on the manual of your choice. Once the manual is downloaded (this will take a second or two if you have high speed) onto your computer you can print out the manual for future reference.
Hope this helps.
Posted on Jun 05, 2011
aquaman987
  • 927 Answers
SOURCE: I just got an Orbit
You don't program each station. You only program one start time that begins the cycle that consists of the three stations.
Remove all start times but the first one and make that 5:45.
Set the station times to whatever you want, 12 minutes.
At 5:45, station 1 starts.
at 5:57, station 1 shuts off, station 2 starts.
at 6:09, station 2 shuts and station 3 starts.
at 6:21, station 3 shuts.
Your FixYa Texpert,
Gary
Posted on Aug 26, 2011
Testimonial: "Thanks Gary , you are a lifesaver, the instruction I got has no info about it, only unimportant stuff. U R amazing your instruction simple and great"
Shows station 2 and 3 on screen but watering does not commence. Have reset numerous times same result.
bad solenoids or valves. also check and bleed air out of sysyem. bleed screws are on top of valve
Dec 12, 2015 | Orbit Irrigation 57856 6 Station Easy Dial...
How do I cancel old program and reprogram?
Did you check out the instructions that came with your Orbit? If lost download a set from their web site.
Oct 26, 2015 | Orbit 4 Station Sprinkler Timer With Easy...
How can the orbit mdoel 57894 be progrmed for multiple start times?
The product manual is confusing... how do you set 1-5 am and 2-12 pm and 3-5 pm? The manual says to press program button to choose A B or C programs, but does not give steps for programming or when to press enter to confirm setting... or say which position the dial should be in when programming.
57894 lets you program separately for each station...turn dial to Run Time and use arrow keys to select a station. Press enter or arrow keys to advance to next station.
57894 offers 'select a station', 'pick days of the week or interval between watering for that station', 'duration of watering for that station'. But picking days of the week is not the same as setting exact times 1-5 am and 2-12 pm.
The dial is set to auto for programs to operate..
Don't forget to activate battery located top right on face of timer.
http://waterheatertimer.org/pdf/Orbit-57894.pdf
So the 57894 has more options than a 24-hour analog sprinkler timer that repeats same cycle each day with 14-day-skipper.
http://waterheatertimer.org/How-to-wire-Intermatic-sprinkler-timers.html
Gene
Water Heater Timers Save Money
Mar 12, 2015 | Orbit Hardware & Accessories
Orbit sprinkler timer manual
Contact the manufacturer. They usually will have the manual online for downloading.
Jul 30, 2014 | Orbit Irrigation 57856 6-Station Easy Dial...
"my orbit easy dial 6 station quit working in auto
Does it work manually? If so, which is rare and almost unheard of I would replace the timer. You can't buy a less expensive timer $20 for a 4 station. Which explains why it is not working. If it doesn't work make sure it is plugged in and outlet has power.
Aug 11, 2013 | Orbit Irrigation 57856 6 Station Easy Dial...
Model 57882 9 station timer I did set up station 1 where do I begin in order to set up station 3
Question is not clear.
Do you have programming problem with the timer?
Or problem locating sprinkler heads?
Or a sprinkler valve problem?
Add a comment with detailed information.
Sprinkler timer turns ON-and-OFF.
Timer does not advance the sprinkler to next station. The sprinkler valve advances to next station when timer turns OFF.
For example, when timer turns ON, then station 1 starts watering.
Timer turns off, and then sprinkler valve automatically advances to station 2.
Timer turns on again, and station 2 starts watering.
Orbit resources:
http://www.orbitonline.com/support/
http://www.orbitonline.com/lib/media/InstallationGuide.pdf
http://www.irrigationdirect.com/media/manuals/owners-manuals/orbit/Orbit-WaterMaster-57880-Controller-Owners-Manual.pdf
Aug 02, 2011 | Orbit 57882 9 Station Super Dial...
Hardware & Accessories Logo
Top Orbit Hardware & Accessories Experts
Craig Butler
Craig Butler
appman67
appman67
pawnpower
Are you an Orbit Hardware and Accessory Expert? Answer questions, earn points and help others
