Question about Ryobi Garden
My new ryobi battery powered chainsaw grabs while sawing on limb Limb is 1-2 inches It stops
    Top Expert:
  • Ryobi Master
  • 48,287 Answers
You need to fully recharge the battery for at least 6 hours before using it
Posted on May 15, 2017
  • linda pohl
    linda pohl May 15, 2017
    Thankyou We will try that
How do I find a drive gear for a wen electric limb trimmer model 6110.
Have you tried yet? I ask because they sell parts to their products there.
If this is like some of the other branded electric chainsaw type pole saws the same small gear is used on many electric scooters and that is available on many scooter part sites.
I tried to get a look at the wen limb trimmer but did not find pics. If you add an image I can give you better info.
Oct 26, 2014 | Garden
How can you buy just the saw for the 8" 2 in 1 pole saw.
after looking at reviews written on
Tried chain saw. Working on limbs about 12 ft above ground.
First limb about 3 inches diameter, Oak. Worked fine.
Second limb same size. Cutter slip off branch could not stop the saw from hitting ground. Broke case where it attaches to pole.
No parts, and no way to repair it as company had no idea what kind of cement/glue I could use. So one branch cost me $120.00.
Sent To Customer Service
Like Robert my saw hit the ground and busted in the same spot (this will happen to you sooner or later) and you can not get repair parts, its now a door stop.
Pros: Easy To Use, Light Weight
Cons: Can Not Get Repair Parts
I am guessing you mean the entire cutting end of the saw too, I would get a new one either same model so you have a spare pole or find a another brand that definatly sells spare parts.
Ive never used a electric polesaw but have done alot of work with with longer petrol and shorter hydrolic polesaws, even top of the range they can be broken easily always keep the chain sharp, cut one branch at a time or small clumps on a hedge.
Commonly they get dropped cause they get really heavy extended a shoulder belt helps alot as do coffee breaks.
Or they get jammed in the branch being cut which can be really dangerous with a half cut branch, be ready to run.
Also never use from a ladder
Jul 07, 2014 | Earthwise CVPS41008 - 8" 6.5-Amp Electric...
Husqvarna Chainsaw 350 has a piece of the plastic that around the handle broke, what kind of glue can i use?
Replace the handle. You can order the parts from and it should be less than $30.00. If your saw runs fine its worth it.
Mar 24, 2013 | Husqvarna Garden
Husqvarna Chainsaw Chain stopped turning
Have you take the chain brake off..? This is a band which grips the clutch drum and must be disengaged before use.
Check chain tension, this shouldn't be too tight.
Did you also put chain oil in the oil tank.?
Mar 09, 2013 | Husqvarna Garden
I have a remington 16 inch electric saw the chain keeps coming off when I saw a small limb
Your chainsaw bar is moving back into the housing which makes it reduce the tension on the chain. You might have a bad fitting to the housing or too much grease on it. The tension screw might be missing it's spring that keeps it from changing the setting.
Mar 14, 2011 | Garden
Chain stopped working whilst sawing log on my new ryobi electric chainsaw. Can't find a way of rectifying, help please
As it is a new machine, you should return it for warranty repair or exchange. Make sure that the electricity source will power a working lamp. Good luck!
Dec 04, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
Saw works but stops when I begin cutting a limb. Model # 104316-04 Thank you in advance. Joe Alcamo
Hi, make sure the chain is not on too tight, It should lift from the bar about a quarter inch. Also if there is a chain brake make sure that it is disengaged. If the chain stops but the saw is revving high then there may be a worn out clutch that needs to be replaced. Finally make sure the limb that you are cutting is not binding the chain under its' own weight.
Nov 16, 2010 | Remington Electric Pole Saw
What's the best way to use my 16 in electric saw to cut off tree limbs?
This is somewhat subjective. Eveybody does it a little different.If you are cutting limbs from a tree, start an undercut about where you want the limb to fall free of the tree. Use the upper edge of the chain to cut it about a fourth of the way through. Then start from the top of the limb over where you made the undercut.
Sep 25, 2010 | Remington 16" Electric Chain Saw
I have a reminton 14inc limb and trimb. What kind
Use regular bar and chain oil available from home centers, hardware stores, and saw dealers.
Jun 08, 2010 | Remington Electric Chain Saw
Craftsman 16 inch cain saw sprocket wont turn
Sounds like the sprocket could be stripped. If so, then you would need to replace the sproket. I suggest you contact Master Parts at 800-466-1446 or online at They may be able to help you.
Jun 09, 2009 | Remington Electric Chain Saw
Garden Logo
32 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
