Question about Radio Communications
My skullcandy headphones won't pair
I had a more expensive pair, but a wire came off, so i bought the cheaper model, but they just want pair to the same device as before.
SOURCE: Lowrider 360 Skullcandy Headphones don't seem to work on my xbox.
Yeah, I had this same issue, the solution is to go too Settings/System Settings/Console Settings/Audio/Digital Output and select Dolby Digital with WMA Pro.
Also change your Prefrences/Voice to Play through both and crank the volume to 10.
Posted on Sep 26, 2009
  • 5603 Answers
SOURCE: SKullcandy lowrider headphones cut wire
Take it to someone familiar with electronics. SOME of the wire types are very hard to solder. These are kind of "tinsel" wires for flexibility.
They likely can be repaired and some shrinkfit tubing put over the splices.
Posted on Jan 06, 2010
  • 272 Answers
SOURCE: my skullcandy earphones are busted
could be caused by the way you wrap them up the cords should never be wound tightly it causes a short and it just so happens that earphones are made of light weight wiring to make them seem to disapear when wearing them so what to do is instead of winding them when your done simply fold them loosely so to speak
Posted on Feb 25, 2010
SOURCE: Cut Skullcandy cord and confusing splicing process.
buy a new cord and replace the old cord then you will not have a splice and it will look better.
Posted on May 09, 2010
SOURCE: wiring diagram for skullcandy headphones
The cat chewed my skullcandy headphone wire in two, how do I splice them. Thank you, Robin
Posted on Jan 06, 2011
Headphone Repair
The cable that is used in the headphones is actually very low quality and very weak so easily broken, You may be able to remove the wiring from another pair of headphones and use it.
Unfortunately Skullcandy are not a high end brand so no spare parts are really available as they are made in china as you can see on the following link.
Link:
Mar 02, 2012 | Skull Candy Lowrider Headphones
I have a pair of skullcandy ind'd headphones and
don't feel alone this happens on lots of head phone set up. What happens sense the wire run through the top over to the other side and head phone are constantly put on , twisted, adjusted and so forth, the small little wires that are normally soldered to the two wires to each side get loose. Only thing you can do to attempt to fix it yourself, is to take off carefully the right side ear piece, and get to the exposed wires, you will then notice most likely it will be smashed or loose. If you or if you have a friend that knows how to solder, than, you would make sure wire is cleaned, stripped and re- solder it. Than problem will work. I am sure that is the problem, nothing else it could be. Thanks Mike ( premium expert from fixya)
Jul 10, 2011 | Audio Players & Recorders
My skullcandy earphones are busted
Feb 25, 2010 | Skull Candy Ink'd Stereo Ear Bud...
No sound
Try messing with the plug. Otherwise your wires might have broken somewhere. This happened to me from using them so much, and it wasn't just these. It happened to a pair of expensive sony earphones. Just happens when you use them a lot.
Sep 20, 2009 | Skull Candy Lowrider Headphones
I can't seem to hear anything from my left ear in my Skullcandy Lowrider headphones. Is there anyway to get them fixed with out needing to get a new pair as they were a present??
If you have used the headphones a lot then your wires probably broke. I had the same thing happen to me, and also on a pair of expensive sony earphones. So it's not the brand. It just happens over time when use headphones/earphones a lot.
Sep 06, 2009 | Skull Candy Lowrider Headphones
Skullcandy Hesh, One ear louder than the other?
So this was happening to me the first day I got these headphones. This might not be the same situation for you but I simply was not pushing the cord into the headphones enough. You have to push the input into the headphones until it pops or clicks into place. Once I did that, the sound was superb.
Jun 26, 2009 | Skull Candy Hesh Stereo DJ Headphones -...
The thing you need to realize is, the headphones are not defective. Headphones cannot choose to individually make voices/game noises/music louder or quieter. Either they play audio or they dont.
What your issue is, is configuration with the xbox (the soucre FEEDING the headphones) Only there can you choose the amount of voice/game noises/music and their respective levels.
Below is a link that headphone company has on their site for the settings you need to change in your xbox.
http://www.skullcandy.com/manuals-and-drivers.html (see the second section, second option doesn "xbox settings for lowriders")
Any further settings will need to be assisted by an xbox support person.
May 16, 2009 | Skull Candy Lowrider Headphones
well i dont know how to repair them but you can get the warranty for 50% off another pair. http://www.skullcandy.com/warranty-information.html does that help?
Dec 18, 2008 | Skull Candy KB Electronics Skullcandy (...
Only One Ear Works!?!?!?
get on there site and warranty them. they will replace them for you. www.skullcandy.com/warranty
Jul 08, 2008 | Skull Candy Ink'd Stereo Ear Bud...
Radio Communications Logo
32 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
