Question about Garden
Torque for head bolts on 1035 MF tractor - Garden
  • 4 Answers
SOURCE: head bolts torque settings
According to my haynes manual for G-S reg, 1989-1998 it goes as follows,
Stage 1:- Tighten all bolts by hand until bolt heads just contact cyl. head.
Stage 2:-Tighten all bolts to 40Nm or 30lb ft.
Stage 3:-Angle tighten all bolts a further 60 degrees.
Stage 4:-Angle tighten all bolts again a further 60 degrees.
Stage 5:- M12 x 140mm bolts ONLY angle tighten a further 20 degrees.
Hope this helps everyone, sorry it seems longwinded but that is how it's written in the manual.
Posted on Feb 07, 2009
chuck943
  • 783 Answers
SOURCE: Head bolt torque specs needed for 96 tbird 3.8
Head bolts are torque to yeild so you MUST use new bolts.
Tighten cylinder head retaining bolts in numerical sequence in three steps as follows:
  1. 20 Nm (15 lb-ft).
  1. 40 Nm (30 lb-ft).
  1. 50 Nm (37 lb-ft)
Loosen retaining bolts one at a time two to three revolutions and retighten as follows:
Long bolts:
  • Tighten to 40-50 Nm (30-37 lb-ft).
  • Rotate an additional 175-185 degrees.
  • Go to next bolt in sequence.
Short Bolts:
  • Tighten to 20-30 Nm (15-22 lb-ft).
Here is a pic of the sequence
http://i253.photobucket.com/albums/hh43/chuck943/Headboltsequence38L.gif
Posted on Mar 19, 2009
darrencasey0
SOURCE: head bolt torque for a 1996 ford ranger 2.3liter
it is in the haynes repair manuel and chad is right
Posted on Apr 05, 2009
polarcycle
  • 1392 Answers
SOURCE: head bolt torque spec
Always use new head bolts.
1)tighten to 40ft/lbs
2)back off 1/2 turn
3)tighten back to 40ft/lbs
4)tighten an additional 90 degrees
5)tighten an additional 90 degrees.
Posted on Aug 16, 2009
  • 12 Answers
SOURCE: head bolt torque specs for 200 honda accord 3.0
its a three step process 1st 29ft/lbs 2nd 51ft/lbs 3rd 72.3ft/lbs
Posted on Apr 25, 2010
I have a vintage tractor with a Peugeot 203 engine in it and I am trying to find the torque for the bolts for head. I am repreplacing the gaske
engine code HFY
HFZ KFX
K6C engine type TU1JP TU3JP TU5JP special features without without without type of cylinder head gasket fibre fibre fibre theoretical thickness (mm) UNK. UNK. UNK. repair dimensions (mm) UNK. UNK. UNK. bolt length (mm) (mm) (X)
nominal bolt length (mm) (mm) (X)
max. maximum cylinder head bow (mm) section-galfg0ghfxzejvpfxmdxkujx-1-0.gif
Jul 10, 2016 | Peugeot Cars & Trucks
Torque on head bolts
Torque on head bolts Robert, Head bolt torque for what? RE POST make model # and your complete question, so we at Fixya can answer your question effectively.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Mar 31, 2016 | Garden
What is the torque settings for an mf 390 flywheel?
Massey Furgeson mf 390 flywheel bolts should be torqued to 100 newton-metres.
Feb 20, 2015 | Siku Massey Furgeson Mf 8480 Farm Tractor
What is the main bearing bolts torque.the connecting bearing bolts torque and cylinder head bolts totque for E3CD engine in 1540 massey ferguson tractor
I don't have your answer but if you google torque specs for your engine I'm sure you will find your answer. When I'm not sure I will call a dealer and they will most likely help out with the info
Dec 05, 2014 | Cover My Tractor Tractor Cab-Enclosure for...
Why is my 2012 21hp sears 42" lawn tractor blowing smoke
If it is a V twin Kohler engine, you may have a blown head gasket. It is a common issue. Great engine but has this one issue. Kohler has a head gasket kit with improved head bolts. Torque specs are included. You will need a inch pound torque wrench and common hand tools.
Jun 14, 2014 | Craftsman 20 hp 42 in. Deck Yard Tractor
What is the proper sequence for the head bolts on a deisel 3020
the head bolt torque is 130 +or- 5ftlbs and as far as sequence if not sure start in the middle of the head and work your way out alternating side to side and in an X. Step up to 130 by starting at 80-100-115-130.
Nov 09, 2013 | John Deere 3010,3020 Tractor Basic...
Torque specs...
The standard specs for grade 5 head bolts are:
5/16" bolt with 1/2" head is 26nm or 19 ft lbs.
3/8" bolt with 9/19 head is 45nm or 33 ft lbs.
junkl
Aug 23, 2013 | Murray Garden
Hi we are rebuilding a ford 4600. Can anyone tell me the torque settings for the bigend, main and head bolts please? Any help would be great, Thanks bb
On the head, first tighten the bolts following the sequence to 40-50 ft-lbs, run through the sequence again and tighten to 70-80 ft-lbs, and again at 95-105 ft-lbs. The intake valve clearance to .017; exhaust is .021. Connecting rods torque 60-65 ft-lbs. Main caps torque to 115-125 ft-lbs.
Randy - TMS Stoller Tractor
Jul 05, 2011 | Ford Tractor Grill 2600 3600 4600 5600...
What do i need to torque ford 4000 cyl head bolts down to
my ford 3600 head bolt torque settings are a 3 step tensioning sequence. 90 ft lbs then 100 ft lbs then 110 ft lbs final torque value.
Mar 22, 2010 | RTO Ford Tractor 2000 3000 4000 5000 Water...
Need head bolt torque for Brigges Stratton 18 Hp
210 to 230 inch pounds. Torque in a crisscross pattern upper left lower right upper right or left or right.
Jul 10, 2009 | Garden
Garden Logo
63 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
