Question about The Computers & Internet
Hp2009m monitor sometimes will show the "monitor going to sleep" screen faster that normal after the computer turns off,
Usually there a certain amount of time before it displays this screen, how do you fix this?
    New Friend:
  • 17 Answers
Well this question is a bit loaded because there are a number of variables at play. You have to think that its not just the timing that could be the issue.
There is an on board video card, sometimes an added graphics card. These may have certain settings in them.
It could be the monitor is slow to respond and not sure you can change the settings.
It could be the way the pc is responding.
Id advise first that you try a different monitor and see if it responds the same way. Then maybe a different graphics card.
Also if you have a friends desktop, you can see if their machine is responding the same way.
Posted on May 15, 2017
Will my dell tft show anything on screen if no input
Normally you can push the menu button on the monitor to look at menu options. If there is no input it will normally show that on the screen initially and they go into sleep mode.
Nov 06, 2013 | Dell E173FPc 17" TFT LCD Flat Panel...
Battery status incorrect
This recalibrate's the battery.
Charge the battery completely. Monitor the battery indicator, which is usually found that the bottom of your computer screen, to check if the battery is already fully charged.
Plug off the power adapter and use the laptop until the battery is completely drained. To drain the battery faster, run several programs at once and keep the contrast of your screen to its highest levels. Turn off all power-saving features as well. Turn off sleep mode.
Make sure that the battery is totally drained by waiting for your laptop to shut off or go into sleep mode automatically because of very low battery charge.
Plug the power adapter again and charge the battery again completely. Once this is done, restore the power-saving features and adjust the contract settings of your screen to normal.
Apr 08, 2013 | Dell Vostro Computers & Internet
How to fix my monitor when its in sleep mode
I assume this is a Desktop computer:
The Monitor receives, graphics or text from the PC (personal computer) and displays it on the screen.of the Monitor.
If you see a message on the screen that says * NO SIGNAL * in most cases the Monitor is good, and the Monitor is either not connected to the PC or there is a problem with the PC Check the connections and the video card.
The problem could also be related a failure of the motherboard, memory or the processor
Let us know..
Nour Sabre
www.aaatvservice.com
May 21, 2012 | HP W2007 LCD Monitor
Hp2338h monitor goes to sleep all the time. When turned on it displays for a couple of seconds, then message flashes that its going to sleep. Its a not graphics driver board or power saver setting,...
I've seen on a few Windows 7 machines has been the display turning off after only 15 minutes, even though I set the Turn off the Display option to Never. Weird!
You're probably reading this because you've tried changing the power plan settings to Never for everything and your monitor still turns off! This can be very frustrating and usually occurs with new installs of Windows 7, though I've seen it happen on older installs too.
In this article, I'll go through the different ways you can fix this problem. Note that if your computer is on, but the screen is showing No Signal or No Input, you should read my post on fixing blank or black screens. Now let's go through the possible solutions.
Power Options - Control Panel First, we need to make sure everything is set correctly in Power Options. Click on Start and type in power options or go to Control Panel (icon view) and then open Power Options from there.
Click on Start, then Control Panel and then Hardware and Sound, and then click on Power Options.
Click on the Change plan settings link that is next to the plan that is currently selected. In my case, the High Performance plan is selected, so I'll click on the link next to it.
First, make sure that Put the computer to sleep is set to Never. Next, change the Turn off the display setting to whatever value you want it 10,15 min etc.. You don't have to set it to Never if you don't want to. After this, click on the Change advanced power settings link.
Expand Hard disk and then expand Turn off hard disk after. Reduce the value till it gets to Never. Click OK and then click Save Changes on the Edit Plan Settings page.
Screen Saver - Control Panel The second setting you want to check is the screen saver. Go to Control Panel, click on Personalization, and then click on Screen Saver at the bottom right.
Make sure the setting is set to None. Sometimes if the screen saver is set to Blank and the wait time is 15 minutes, it'll look like your screen has turned off.
BIOS, Graphics Card, Monitor The two methods above are the most common reason why your display will turn off after a set amount of time, however, there can be other possible causes.
BIOS - On some computers, the BIOS can have power saving settings that determine how the computer sleeps. These are called sleep modes (S1, S2, S3, S4, and S5). On some computers, you'll see an option called Deep Sleep Control. You may need to disable this in order for the computer to wake up faster.
Graphics Card - If you have a high-end graphics card installed, make sure you have the latest driver and management software installed. If you go through the settings, you may find an option that puts your graphics card into lower power mode or something similar.
Monitor - Lastly, some monitors have power saving features themselves. Usually, the monitor is supposed to go into power saving mode if it doesn't detect any input (HDMI, VGA, DVI, etc), but sometimes it happens unexpectedly.
You'll have to press the buttons on the monitor to get access to the monitor settings. Those are about all the reasons I could think of for your display turning off when it shouldn't. If you have any other questions please post them here ,Best
We Are Here To Help !!
Oct 04, 2017 | HP 22" Widescreen Flat Panel TFT LCD HD...
My hp2009m monitor goes into sleep mode
Monitors are programmed to go to sleep when there is no input. If you shut it down on the other "tower" also it will do the same. You need to physically hit the power button on the monitor to actually shut it off.
Feb 15, 2010 | HP Computers & Internet
I have a hp2009m flat monitor and hp a1473w
everything seems to be working as normal.. that is just a message and it happens with some of the monitors.. you don't have to worry about it..
HP 2338H Monitor Goes into Sleep mode and I have to power comput
you meant w2238w , right, you left off the w?
circa 2006 monitor, 11 years old.?
if the monitor fails on 2 PC, the monitor is bad ! ok, do that...
then
push the monitor menu buttton, connected to a running PC.
if the OSD is dead, , (on screen display , menu button front of monitor)
that means the monitor is dead, CCFL tubes are bad.
cold cathod florescient laml tubes all day this old.
the menu button can be in lock mode, hold the button for 10 seconds, and it unlocks
then go in the OSD screens if they work,. and turn off the sleep timer.
this timer is marked in the OSD as power saver,. turn it off.
it is a time clocked feature, and a pain to use on modern PC.
your PC does sleep modes today and never us this timer,inside monitor (default is on, turn it off)
all that is on page32 in your manual,
https://www.manualslib.com/manual/71500/Hp-W2338h.html?page=32#manual
Sep 21, 2017 | HP Computers & Internet
My monitor goes to sleep after a certain time when I'm in BIOS?
you can only control the pwoer function to your pc or monitor to adjust when the screen to go to sleep mode or even shut off throw control panel power options
Jul 19, 2009 | NEC LCD1735NXM Monitor
Screen comes on briefly then blanks out.
check inverter, memory, and powersupply.
May 31, 2009 | HP w1907 LCD Monitor
Screen shows message "no input signal" and monitor goes to sleep.
monitor show "no input singnal" error masage when not gating any type of video singnal ,
so if u realy check your monitor wires for correctty plugged in .
then:-
Two possibilities:
either the video/mainboard of the monitor is defective; or
the video card/ CPU is the faulty.
A way to verify is to try the PC with another monitor or to try the monitor in another PC.
thanks
Apr 30, 2009 | HP vp17 Monitor
Computers & Internet Logo
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
