Question about Eureka Luxury Family 8-Person 2-Room Titan Tent
Beater will no turn on the carpet
When the sweeper is off the floor beater bar turns. when it is lowered the bar stopes
  • 636 Answers
Replace the drive belt in the head
Posted on Jul 25, 2009
I was told by a previous repair man that there is a fuse in the beater bar that needed to be replaced.
Up to my experience in my Panasonic vacuum cleaner, if the beater bar is not working this could be because the 'Carpet/Floor' selector switch is in the 'OFF' or 'FLOOR' position. In both of these positions the beater bar will not rotate. Move the selector switch to the 'CARPET' position. When in this position the beater bar will rotate once the foot pedal is pressed.
If the selector switch is in the 'CARPET' position and the beater bar is still not rotating it could be that there is something entangled in the beater bar, or the belt is worn or broken.
To check this first unplug the vacuum cleaner
Inspect the beater bar and belts to ensure that there is nothing entangled in the beater bar and that the belts are intact and are not excessively worn. If the belts are excessively worn they may slip resulting in the beater bar not rotating.
The vacuum cleaners often have an overload protection system inside the nozzle, which stops the nozzle motor when the beater bar jams to prevent belt breakage. After clearing any lint build up or jamming you may need to reset the overload protection, by pressing the reset button on the top of the floor nozzle.
May 04, 2015 | Vacuums
Fault finding
Have you accidentally switched off the beater bar via the dial on the head? Some models have a 'hard floors' and a 'carpets' setting (which disengages/engages the beater bar).
Jul 06, 2014 | Dyson Vacuums
I was running my vac when it caught the fringe on a throw. I turned it off and carefully pulled it out but now I don't have any suction and it's not cleaning the carpet.
Don't know the model too well but the beater bar is what goes when that happens(the brush that goes around right there on the intake of the sweeper) it has a belt that makes it turn and you probably broke the belt or burnt it up or it came off so it is the belt that is the problem. That will give you those symptoms because the beater bar (rotating brush) is what lifts the dirt up so it can be sucked in.
Mar 28, 2011 | Dyson Ball DC24 Bagless Upright Vacuum
Bissell all-rounder vacuum motor smells like burning and black exhaust marks on carpet.little use
Your beater bar is stuck on some object and the belt is rotating against the surface of that same beater bar/brush assembly. This will leave black rubber dust on the carpet and eventually lead to a torn belt.
Turn the Vacuum upside down in an area where dust and dirt will be no problem to clean up. Make sure the Vacuum is unplugged before trying to rotate the beater bar/brush forward and backward to dislodge the foreign object.
Restart the vacuum on a friction free floor and verify that the beater bar is free spinning by dusting a non-carpeted floor with baby powder.
If you see swirl and brush marks as you draw back your vacuum cleaner should be ready to go. If not, you will need to follow your user manuals directions for replacing the belt.
Nov 07, 2010 | Kitchen Ranges
Placing the handle of my Dyson DC07 into its upright and locked position causes the beater bar to stop turning. It will not start turning until the handle is first lowered to the working position and the...
Hi its Darran at Dyson.
The brush control is designed to switch the brush bar off automatically when you stand the machine back into the upright position. It is designed this way to protect any delicate floor surfaces when you have the machine switched on and upright and when you are using the hose.
If the brush control should be in the centre position and move forward to the "on" position when you release the head. If it is not doing this, please contact our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Darran
Dyson Customer Service
Feb 22, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Bought a new sweeper and brush ( beater bar ) does not turn. The large belt is fine and turns. The small thin belt is also fine but does not turn the brush. It is either the wrong belt or is there...
Jim, To put tension on the brush, tilt machine forward when upright, move carpet selector knob to carpet. then turn vac on. Brush will only spin when vac is tilted back to operate. brush stops when upright and on to use hand tools so the er is no danger to carpet or persons with moving roller.
Sep 29, 2009 | Hoover U6630-900 WindTunnel Bagless...
My beater bar will not spin when the handle is lowered? But there's suction thru the hose when the handles upright
The motor that spins the beater bar is connected to a tiny switch, if that switch is not operating that could be the problem. If the motor is not spinning, that could be your problem (seized), or if you have a broken belt that could be your problem.
Hope this helps
Sep 25, 2009 | Dyson DC15 All Floors - The Ball Bagless...
Beater Bar Does not turn
YOU MAY HAVE A POSSIBLE BAD BELT OR THE MOTOR THAT RUNS THE BAR MAY BE BAD, THE OTHER POSSIBILITY IS THE SWITCH THAT TURNS ON THE BAR MAY BE BAD. OR A WIRE COULD HAVE COME OFF THE MOTOR. i THINK YOU DO KNOW THAT THE BEATER BAR DOES NOT RUN WHEN ON WOOD FLOORS.
Dec 03, 2008 | Eureka 5892AVZ Bagless Upright Cyclonic...
Beater bar will not turn
if the beater bar wont turn on when you switch it from floors to carpets ( the knob near the bottom of the machine, and on the right side of it when your facing the machine ) then its probably the clutch mechanism that drives the belt, you will need to take it to a vac shop to have it fixed.
Sep 16, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Eureka Luxury Family 8-Person 2-Room Titan Tent Logo
132 people viewed this question
Top Eureka Sport & Outdoor - Others Experts
Are you an Eureka Sport and Outdoor - Other Expert? Answer questions, earn points and help others
