Question about Radio Communications
How to print instruction manual for model ote15 jaba blue tooth
5 Suggested Answers
IrishDruid
  • 2712 Answers
SOURCE: need instructions to set up blue tooth in my phone
Yes, it would help if you gave the model number. However, if you do a google search for LG Rumor user manual, you should be able to find a download.
Posted on Jun 16, 2008
Tech Jenkins
  • 359 Answers
SOURCE: Blue-Tooth set-up
usually you press and hold the button on the bluetooth headset device for 10 secs, the led will change color, then you pick up your phone get into the bluetooth part of the settings and tell the phone to look for it. Then after that when it finds it, the pin will probably be 00000.
Look it up on google the model of your headset you should be able to find the pin.
Posted on Aug 12, 2008
phoenix chi
  • 389 Answers
SOURCE: instructions for using WEP18 Blue Tooth device
just press and hold the power button for 5 seconds and u will see a solid blue light, once u see that you need to turn on the bluetooth on ur phone, search for the bluetooth then if it is asking for a pass word just enter 0000.
Posted on Jul 03, 2009
samanthaj08
  • 570 Answers
SOURCE: Blue Tooth Connection instructions for a MT Max 4X Headset
Go to http://demos.blackberry.com/8300/na/us/gen/ >
Select "Menu" on the top left > Select "Start Using Your Device" > Select "Connect with Bluetooth Enabled Device"
Hope this helps :)
Posted on Oct 02, 2009
Where do I find the pairing code number pls.
No where from the specs of this model it does not have Blue Tooth capabilities. From the user manual there is no Blue Tooth capabilities. Pairing code would be for Blue Tooth.
You could use a 802.11N WI FI ethernet device and connect the TV to it but no blue tooth .
Mar 02, 2015 | Samsung Televison & Video
Bluetooth user manual
If you are using Windows 8.1 .please follow the following instructions.
1.go to the PC settings
2. In Accounts goto PC and Devices
3. In pc and Devices click on Blue tooth
4. In blue tooth Switch on the blue tooth button and wait till your device will appear in the list. Click on the device and click on the pair . A code will appear on both device just click yes on the code windows. you will be able to connect the Devices and now it is ready to share the data.
Sep 13, 2013 | HP Pavilion Computers & Internet
I have HP Pavilion DV6 model no WW146AV.How to activate bluetooth in this model
If your particular model of HP has the blue tooth installed from the factory, turning on the wireless switch on the front left edge of the laptop enables the blue tooth, as well as the wireless LAN. A blue tooth icon should appear in your task bar near the clock when blue tooth is turned on. ELSE
You have to go into start, then all programs, then look for the blue tooth connection setting. Hope this helps.
Go into start, then all programs, then look for accessories, the find blue tooth wizard. You can switch it on via that.
NOTE : BE SURE THAT YOU HAVE A BLUE TOOTH IN YOUR MODEL BECAUSE SOME OF THE MODELS DON'T HAVE IT.
Mar 21, 2011 | HEWLETT-PACKARD Hewlett Packard Hp...
Have HP printer C-5280. Keep getting paper jam message (no jam) and loud clicking sound as print cartridge moves back and stays in regular position. Is this something that is fixable, or is it time for...
I have same problem as Jchouinard1... same loud grinding (klicking) skipping lines, dbl printing.. and no HP repairshop here in Las Paknas de gran Canaria except for lacer printers... I just don´t need a lot of jaba jaba jaba abd I´m not going to ship the bloody beast all the way to Madrid... I want it fixed here and preferably in some dinky shop around the corner.. Not by somebody who doesn´t know Sam from Eva but some dude with some brains in his knuckles or toes... Those claiming having brains (for money) don´t even fit my own standard which is 2 masters in engineering... At 90 minus a nut or 2 I can still handle most handtools.. so what the **** is going on in HP printerland... Anyone nearby (or else) can reach me at
Feb 17, 2011 | HP Photosmart C5280 InkJet Printer
Can i use my plantronics 230 bluetooth for my blackberry phone?
Hi, yes you can use plantronics 230 blue tooth for your blackberry phone.All you would need to do is to pair the device with your phone.that will do.
How to pair a phone to a blue tooth device?
Instructions
Pair Your Blackberry with a Blue-tooth Headset
Turn on Blue-tooth headset and Blackberry hand-held.
Enable the Blue-tooth radio by going to the options window and clicking on Blue-tooth. Click on Enable Blue-tooth in that window.
Add your Blue-tooth headset to your Blackberry by clicking on Add Device in the Blue-tooth window.
Find and select the name of your Blue-tooth headset from the list that appears. The Blackberry will search for all Blue-tooth devices within range, so other devices might show up on the list.
Click Activate Blue-tooth device if you receive a call and the Blue-tooth headset does not pick up automatically.
Use your Blue-tooth Headset with your Blackberry
Make sure the Blue-tooth radio on your Blackberry is turned on before you try to use your Blue-tooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the hand held.
Tips & Warnings
Pair your Blackberry with any Blue-tooth-enabled device using the same steps as those for connecting a Blue-tooth headset.
Remove your Blue-tooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Jan 06, 2011 | Plantronics Explorer 230 Bluetooth Headset
Does explorer 230 pair with nokia 2600
the explorer 230 blue tooth can be paired with the Nokia phone if only the blue tooth tooth device is a universal blue tooth.
Universal blue tooth can work with any phone no matter the model.So check the blue tooth if it is a universal blue tooth, try it with the phone and see if it will work.
Have a nice day
Mar 16, 2010 | Plantronics Explorer 220 Bluetooth Headset...
Blue-Tooth set-up
Aug 12, 2008 | Motorola Mobility RAZR V3c Cellular Phone
Need instructions to set up blue tooth in my phone
Jun 16, 2008 | Cell Phones
Radio Communications Logo
27 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
