My dvd player is the model dvd-NC600. it is broken inside.the little part KT-20.is lose, how iit is emsamble?
    President:
  • 846 Answers
Hello Bagrecatfish,
First things first I need you to post the make and model of the dvd player.
Next the broken part, can you describe it a little bit....will make finding it in the service manual easier. As well as assist me in helping you with a solution.
Post back with those two answer's and I will get back to you promptly. Thank you for choosing Fixya!
Posted on Jul 25, 2009
Dvd player not locking down on disk
The odds are its a defect. If the DVD player is old. (which it sounds like) then it may just have broken. there are three little clips that stick to the disc so when it spins it doesn't go out of place. After a while you can just break it. Normally hard to do but anything can happen. Hope this helps
Jan 31, 2014 | Televison & Video
My DVP-NC600 CD/DVD player will not recognize discs inserted. The carosel just spins freely and won't stop. HELP!
Welcome to fixya!
open up the screws , if you can check the tray if there is something inserted remove it and its ready to be used again ,
the reason is something is struck inside it may be a disk or something .
Check if helps you in any manner
Apr 30, 2011 | Sony DVP-NC600 Multi-disc DVD Player
Dvd player is not working
Put a disc in the player and note it's position. Close and let it start loading. If it doesn't load, eject the DVD and note it's position. If it hasn't moved iit could be either a broken belt or the drive motor I think> _/)***
Feb 16, 2011 | Samsung DVD-V5500 DVD Player/VCR
PROTECT
http://www.usersmanualguide.com/
see if theres a manual here
May 04, 2009 | Sony DVP-NC600 Multi-disc DVD Player
I have a KD-27FS170 FD Trinitron Vega DVD/VHS player. The DVD disk will not eject. What is the solution? Manna
the assembly which moves the dvd door is either got stucked or the gears which moves the assembly needs replacement as they are cracked or worn out.
Mar 02, 2009 | Sony DVP-NC600 Multi-disc DVD Player
Sony DVP-NC600 Multi-disc DVD Player No Disc Error
The only other thing I can suggest, having repaired many Sony CD/DVD players, is to get a can of compressed air and try to blow any dust out from the laser assembly. Since you've already cleaned the lens (the most common problem), you also might have dust down inside the assembly. Try blowing with the air nozzle down inside, around the gap between the lens and the cover surrounding it. Do it from at least a couple of inches away, if the air is too powerful you can damage the wiring inside the assembly.
If this fails to correct the problem, your laser output may have diminished over time and the only repair is to install a new laser assembly. The cost of this part will most likely not be worth it to you since the unit is quite old now.
Sony 5 disc dvd player - discs lock in - spinner needs push to go
You can spray WD-40 contact cleaner but very little amount in spindle motor (you call it spinner) and please take care, DO NOT spray over optical lens which is so close to spindle motor.
If problem still exist, you need to replace optical lens assembly and I will provide you part number if required.
Good Luck.
Jan 15, 2009 | Sony DVP-NC600 Multi-disc DVD Player
Sony DVP-NC600 Powers down during CD playback
The tray won't open. I took top off and dvd top side holder, but the laser mechanism won't disengage so the tray will open, even with no dvd in it. How do
I reset it. I power on, hit open key, it makes hum noise then goes by to
standby mode.
Jan 06, 2008 | Sony DVP-NC600 Multi-disc DVD Player
DVD player not working right
Check your cables between your DVD player and the TV, this play has component video outputs that could possibly cause this issue.
Dec 25, 2006 | Sony DVP-NC600 Multi-disc DVD Player
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
Electro Med Services...
