Question about Mercury Boating
Looking for Operating/Maintenance Manual for Mercury 75 HP Outboard Engine Serial No. OG099146 where can I find the correct manual for this specific outboard model?
  • Mercury Master
  • 917 Answers
Visit mercurymarine.com
Posted on May 25, 2017
Editor925
  • 285 Answers
SOURCE: Missing operators manual for Evinrude 2 hp outboard motor
Your best bet is ebay for a replacement user manual. Take a look around, you will come across one... For the meantime, gas oil ratio should be 50 parts gas to 1 part oil, i.e. 50:1. General care: Dont go full throttle for any length of time. Cruise of 3/4 throttle... Always flush engine after use in saltwater, including washing down exterior. Keep spark plugs in good order and check prop for fishing line wrapped around in near the prop hub. Otherwise, get a yearly service and have them check the water pump and replace as needed, get it tuned etc and gearbox oil changed.
Posted on Jun 20, 2009
finish line
  • 207 Answers
SOURCE: 1999 Mercury Mariner 9.9hp outboard motor
should be on the side with a lever but could you give me more info please
Posted on Jun 27, 2009
SOURCE: Boat engine 1995 Johnson Outboard 70 HP
Ihave a 1991 70 hp Johnson outboard thats hard to start the first time but starts good after that. Seems to be flooded. Starting rpm seems to be low.
Posted on Jul 25, 2009
SOURCE: Free wiring diagram for 1978 Mercury Outboard 115 HP boat motor
I have a maintainance manual for this engine (I have the same one) with pages of wiring diagrams. What specific system/area are you interested in, I could scan in the page(s) and email them to you.
Mark
Posted on Sep 20, 2009
muffteck
  • 202 Answers
SOURCE: wiring diagram for 1982 Mercury 6cyl outboard tilt
go to ebay and buy a manual
Posted on Mar 27, 2010
Looking for a 2016 tracker targa V 18 combo with a 150 HP murcury 4 stroke outboard engine owners manual
Manual is in the first link
Mercury 150 FourStroke Manual
https://dmna.ny.gov/nynm/manuals/Mercury_150_FourStroke_Manual.pdf
RCD-H-2 Rev 4. 150 HP 4-stroke (3.0L) hp. OP401000 or. 1B227000. RCD-H-2 Rev 4. Essential requirements. Standards. Other normative document/ method ... Owner's manual. This declaration of conformity is issued under the sole responsibility of the manufacturer. I declare on behalf of the engine manufacturer that the ...
Owner's Resources ' Mercury Marine
https://www.mercurymarine.com/en/au/service-and-support/owners-resources/ The major consideration in preparing your outboard for storage is to protect it from rust, corrosion and damage caused by freezing of trapped water. Outboard Storage tips ... Mercury Authorised Dealers have the expertise and training to handle all of your engine maintenance service and needs. Engine Maintenance.
FourStroke 150 hp ' Mercury Marine
https://www.mercurymarine.com/en/ca/engines/outboard/fourstroke/150-hp/ The specifications displayed here may not be indicative of the entire engine family; click on the "See All Models and Specs" link to view the specs in detail. ... Perfect for Repower. The compact, lightweight design of the Mercury® 150hp FourStroke engine fits most transoms, including those with narrow engine wells and tight ...
Outboard Care ' Mercury Marine
https://www.mercurymarine.com/en/ca/landing/outboard-care/ Step-by-step videos to help you maintain your 150 hp FourStroke. Flushing; Oil change ... This helpful how-to video shows you how ensure your outboard motor is maintained for peak performance. Here are step-by-step ... FourStroke engine. For more information, please consult your Mercury Marine owner's manual.
150 HP Mercury 4 stroke outboard engine owners manual Google Search
Dec 06, 2017 | HP Boating
1976 mercury v-6 1750 hp outboard igot the motor and the lower end was already taken off and there isa part I never seen besides the impeller its a little housing wioth a plunger typ thing on one in
Hey Mark,
Find your engine from this list.. then continue until you find the correct parts diagram that corresponds to what you are looking for...More info would help.. serial number, ID number. any numbers on any plate..
Find Mercury Marine Outboard Motor Parts by Engine Model
Jun 09, 2017 | Mercury Boating
Mercury 1989 60 HP Outboard Motor manual to find gas to oil ratio
50:1 But if your doing mostly low rpm cruising (trolling) then you could reduce that a bit to 75:1 to help reduce smoke. If you do mostly mid to higher rpm cruising, then 50:1 (1 pint to 6 gallons. )
Or 200mls in 20 liters if your Canadian.
Feb 26, 2016 | Seloc Mercury Outboard Repair Manual, 1965...
What year is serial #od272328 on the above listed mariner eight outboard motor
http://forums.iboats.com/forum/engine-repair-and-maintenance/mercury-mariner-outboards/270818-mercury-serial-year-hp?t=264118
Dec 16, 2015 | Boating
Serial number decode0B142498
Go to boats.net - Mercury parts - search under hp/serial range - select 20hp 2 cylinder - it will be under the first selection 0A730007 and up.
Aug 24, 2014 | Seloc Mercury Outboard Engine Repair...
Hi,I am looking for an online manual for an 85 hp mercury outboard engine,I need to replace the water pump
i have service manual for MERCURY IN LINE 75-150 HP-it covers all however my scanner printer down at present so unable to scan to lappy to be able to email at prez-hopefully this week-waiting on my computer man!
Oct 03, 2009 | Light Outboard Motor Boat Bass Fishing...
Downloadable free repair manual
you can download this manual from here.
htttp://freedownloadbook.blogspot.com
Aug 14, 2009 | Light Outboard Motor Boat Bass Fishing...
Boating Logo
44 people viewed this question
Top Mercury Boating Experts
Colin Stickland
Colin Stickland
Mike
Joseph Hoffmann
Are you a Mercury Boating Expert? Answer questions, earn points and help others
