Question about Mitsubishi Televison & Video
My Mitsubishi has a black line rolling down and the screen looks like it's rolling sideways.
SOURCE: ROLLING TV SCREEN
After 2 days of problems with it, I finally fixed it by unplugging it and plugging back in! Works like new.
Posted on Apr 04, 2008
MNfisherman
  • 11896 Answers
SOURCE: Mitsubishi TV had horizontal lines across the screen and rolls up
Answer
ONE: Yes, the speaker mounted close/near to the set can be a cause of mischief; please move it further away and see if that helps clear up the problem. But, you must keep it away for several days before you will know for sure because it takes some time to degauss all the internal parts that may have become corrupted by the magnets in the speaker.
TWO: Yes, any set can be repaired the question is cost and wisdom. Old sets are sometimes not worthy of the repair simply because of the likelyhood that another failure will follow soon after. A big screen always invokes a repair charge of $200 and up. After a few of these you will wish you had put all the money into a new set!
THREE: The lines are most likely a problem in the vertical blanking circuits of the set. These are horizontal retrace lines that are supposed to be blanked out during vertical retrace of the raster. Think of it as a paintbrush that scans across the screen painting thin lines and when you get to the bottom of the screen it goes quickly back to the top, but during that time the horizontal, which is many times faster, has made several sweeps; so it must be blanked out during the retrace. The repair involves finding the guilty parts and replacing them. Usually this repair runs over the $200 somewhat.
FOUR: Prior to calling in a service tech try a hard reset to see if that will recover any of the circuit degradations. Merely unplug the power cord and leave unplugged for 4 hours or more. It may help. Or, it may not help; but worth a try since is won't cost you anything.
If the set is over 5 or 6 years of age it probably is not a condidate for any expensive repair. On the other hand, it is a Toshiba - and they make a fine set.
Hope this helps. Let me know if you have further thoughts.
Posted on May 09, 2009
nicknovikov
  • 100 Answers
SOURCE: my WS-55613 mitsubishi projection tv has a rolling
check 9v reg.on the signal board.
Posted on Jan 29, 2010
demonicsaint
  • 160 Answers
SOURCE: We have a Mitsubishi Diamond big screen
Press your menu button on the tv if the picture is fine with the menu, then try a dvd player or a gaming system. If the picture is fine with all 3 then yes it is the cable. If there is an issue with the dvd and/or gaming system also then it is the tv and a board will need to be replaced.
Posted on May 06, 2010
  • 46 Answers
SOURCE: drivers side window stuck, but motor still works,
Do you mean it tilts foward when you roll it down? If so, Go to chevy dealer and get some new window run channel guides/clips. Very easy to replce if you have some mechanical skills. You can pull the window out on that model without pulling the door panel to replace those guides.
Posted on May 30, 2010
Thick black line rolling up the recorded video of the TV
That is the camera not being in sync with the refresh rate of the TV. With consumer gear, there is really not much you can do about it.
Sep 08, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi mod. vs-5072 rolls how fix?
check for swollen capacitors- bad capacitors will cause the screen to roll. If the top of a capacitor even looks SLIGHTLY puffed up, replace it!
Dec 19, 2008 | Mitsubishi VS-60611 60" Rear Projection...
Rolling screen
my screen on my mitsubishi won't stop rolling
Aug 22, 2008 | Mitsubishi VS-50607 50" Rear Projection...
ROLLING TV SCREEN
Apr 03, 2008 | Westinghouse LTV-27W2 27 in. HD-Ready LCD...
Thin vertical line
What you have described is definitely some form of Electrical Interference. Interference can come from a variety of causes. Is the Cable Inputting the Cable Box close to some High Voltage Electrical Lines? Or Are you located near some Electrical Power Station? Or A Police station, where the Radio Transmitter of the Police Station causing the Interference? As I said, there are a variety of reasons. Also, Try to check if the connector is loose at the rear of the Cable Box, or at the rear of the TV. You will have to eliminate every possibility reason. Wish i could help further.
Jan 21, 2007 | Mitsubishi CS-35405 TV
Horizontal roll on mitusbishi 35" tv
is this a horizontal black line going up or down? if yes, this sympton is caused by a trouble in the integrated circuit or in the vertical oscillator circuit. this symptons has 2 variations. one is the intermittent rolling of the picture. this referred to as the "loose vertical hold" the other variations is the continuous upward or downward rolling of the picture
Jan 15, 2007 | Mitsubishi CS-36509 TV
Open Questions:
Televison & Video Logo
27 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
