Replacing JD 5105 manifold heater - Computers & Internet
I AM TRYING TO FIND AN EXHAUST INTAKE MANIFOLD FOR A JOHN DEERE 1020 GAS ENGINE EXHAUST EXITS FROM BOTTOM OF MANIFOLD SERIAL # 41TR026126T PLEASE HELP ME
you will need to look for second hand areas -ebay ,local classified -web searches- JD parts for those series are very hard to find but their out there look on ebay under john deere 1020 tractor and also tractor boneyards like marshall machinery in pa or steiner parts -if the exhaust is cracked look for a machine shop they may be able to do repair until replacement is available
Aug 31, 2016 | John Deere Tractor 1020, 1520, 1530,...
I my JD 757 developed hole in muffler. Replaced this spring. Is still pretty loud. What else could be wrong. Gasket? I did tighten two muffler attachments at the engine
Check everything from the exhaust manifold back, Use water pump channel locks to squeeze the pipe every few inches to see if it is weak,
Apr 14, 2016 | Cars & Trucks
I need reset bios. I can´t boot any way. toshiba satellite 5105-s501
Tear it down to the bios battery and remove then replace it. This will reset the bios to factory and wipe all preboot passwords out.
Aug 13, 2010 | Toshiba Satellite 5105-S501 Notebook
Reseting bios password in 5105-S105
try these default passwords
  • AMI
  • Award
  • bios
  • setup
  • cmos
  • concat
  • AMI_SW (case sensitive)
  • AMI!SW/
  • AMI?SW/
  • j262
Apr 01, 2010 | Toshiba Satellite 5105-S501 Notebook
Replace gas control valve
Yes the gas valve can be replaced. You need to be careful and use two wrenches so that you do not hurt the manifold or the piping. But yes, it is possible to replace it.
Heatman101
Mar 19, 2010 | Rheem Tank Water Heater G100-200, 100...
Toshiba satellite 5005-S504 boots over and over and over non stop
It sounds like the hard drive is dying. I had a computer do the same thing and it turned out to be the hard drive. You should still be able to access the bios though. Try hittind either delete or F1 as soon as your toshiba screen appears.
Jul 10, 2009 | Toshiba Satellite 5005-S504 Notebook
Bypass Bios password on Toshiba Satllite 5105-S501
ruhh row...The only option I know of is to remove the cmos battery for about an hour. toshiba support may have a "generic password" that can be used.
Mar 20, 2009 | Toshiba Satellite 5105-S501 Notebook
How to entrer in setup of toshiba 5105 satellite?
There is no BIOS setup on that (or most for matter) Toshiba laptop. If you need to tell it what drive to boot from hit the F12 key when you see the Toshiba Logo then use the left and right arrow keys to pick what device you want.
Dec 21, 2007 | Toshiba Satellite 5105-S501 Notebook
Toshiba Satellite 5105-s501 Restarts Windows then shuts down intermittently
Yes it could be, the notorius GeForce2Go is a replaceable card on that model. I have seen, lines, blurry text, and Boot loop issue caused by it. Be warned, the replacement card is expensive.
Cheaper & better finding a complete laptop with busted screen.
and removing the card only. Then you will also have other spare parts.
Dec 11, 2007 | Toshiba Satellite 5105-S501 Notebook
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
