Question about Technics Audio Players & Recorders
How to connect speaker wires to the receiver's speaker jacks. it's a Technics sa-424 stereo receiver.
  • 169 Answers
SOURCE: probleme with my home theatre...technics..av control stereo receiver- model SA-G76
just an idea maybe check the position of speaker select switch some models have
a or b
or a+b
Posted on Apr 25, 2008
SOURCE: Technics sa 400 Receiver
Checked fuses then sprayed contact cleaner on the fuses and the fuse holders. The speakers began to work correctly.
Posted on May 29, 2009
SOURCE: Max. wattage for speakers w/ Technics Receiver SA-GX100?
I too have a Technics SA-GX100 and it's rated at 2 x 40W @ 8 Ohms. I have the Technics SB-2840 floor model speakers hooked to it, which are rated at 200W Music Input - 8 ohms. It sounds very nice just to be a 40W receiver.
Posted on Jun 12, 2009
SOURCE: Technics sa-g78 no sound from front speakers
Buy yourself a nice Krell amp!!
Posted on Jun 25, 2009
  • 102 Answers
SOURCE: My Technics AV Control Receiver SA AX530 is in overload
An amplifier should never be turn on without speakers, it will overload internally.
make sure speakers work and try again.
Posted on Dec 04, 2009
Cannot play my ipod through my technics amp
You would need a mini jack to stereo rca wire. Insert the mini jack to your Ipod's headphones, then plug the stereo rca to your amp inputs. If it's a receiver, plug into any of the inputs (aux, tape etc) except "phono or turntable", then switch to respected input on the receiver. Be sure all volumes on both units are down during this process, then gradually turn up both volume to normal level.
Apr 04, 2014 | Technics SA-EX500 Receiver
Need help connecting to PC
You need adapter cable 3.5mm mini stereo plug to double RCA plugs (one red, one white). Plug 3.5mm end into headphones/audio out socket on PC, RCA plugs to AUX IN sockets on rear of SA-222, select AUX on front of SA-222 to hear audio from PC through system speakers.
May 03, 2017 | Panasonic Technics Sa-222 Receiver
Need a manual for Technics Receiver SA-160
Go and google it as you can buy it on line ... how tough can it be the hook up speaker wires? The small speakers are front and back, left and right in pairs. red wire to red jack on back , black wire to black jack. big speaker goes to sub wolf. jack in back. Now get those wires and play your Christmas music. note jacks may be marked fr fl rr rl sub
Dec 10, 2009 | Audio Players & Recorders
A and B channels both have left speakers out.
Use a multitester to check the amps then you can find which amp it is.Under the cover youll see two boards on a aluinum plate.
Oct 26, 2009 | Technics SA-EX140 Receiver
How to hookup ipod to technics sb-2840 speakers
quick solution is to go down to radio shack and get a small amp.  They have them for under a $100.00 bucks. The connection is from the mini jack to stereo RCA's for greatest ease and flexibility.  You can also go to a good music shop like Guitar Center and see what they have used.
Aug 03, 2009 | Technics SA-AX720 Receiver
Make sure the output in your tv menu is set to external speakers. Any digital optical cable, or RCA jacks hooked up properly from the TV's out put to the receivers input should work just fine. Take your time, retrace your steps, and make sure each cable is in the correct input/output. And make sure the receiver and TV are on the proper settings. Good Luck, and thanks for using FixYa!
Dec 31, 2008 | Technics SC-DV290 System
I have a SA-203 receiver. I am trying to hook it up to my computer to record my LPs. I have run a stereo cord from the headphone jack to my "line in" on the PC. When I play anything (stereo,...
I did hook up my PC to my SA-203 successfully. I noticed the amplification was weakest when I hooked up through the "phono" connection but in all cases both speakers worked. Be certain you have plugged in the cables completely and the contact points are clean. If you open your Technics SA-203 you will see it is apparently not very complicated so if the connections are the problem you can probably even fix it yourself. Go to Radio Shack online as it is unlikely the sales help knows s**t about there electronics part bins and probably neither will the manager. But once again, I really believe you just need to fiddle with the plug at the "phones" connection on your receiver. Good Luck and sorry I took so long.
Aug 23, 2008 | Technics Audio Players & Recorders
Probleme with my home theatre...technics..av control stereo receiver- model SA-G76
a or b
or a+b
Apr 24, 2008 | Audio Players & Recorders
Top Technics Audio Players & Recorders Experts
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
