Code 0e comes up , checked filter, water discharge
2 Suggested Answers
BIKER T
  • 909 Answers
SOURCE: Getting error code 0E on
To little info, but looks like pipe is much to low. Not getting the opportunity to fill up properly.Raise it higher.(Im asuming that you can hear the drain pump run and water is being pumped out as wall.
Posted on Aug 09, 2010
WHAT DOES IT NEED DONE WHEN ERROR MESSAGE SAYS 0E
An OE error code indicates that the washer was unable to drain the water. The main causes for this error code are a kinked drain hose, a clogged drain pump filter, or a problem with the drain pump itself.
Oct 24, 2015 | LG WM2301HW Front Load Washer
Error code 0E on LG WM1290 FHB ?
The error code 0E stands for obstruction error, meaning that the drain line is obstructed. This is why the spin fails as all the water is not being drained. Check the drain hose for kinks and clean the drain filter. If they are not the problem, there could still be an obstruction in the drain hose in or about the drain pump.
Dec 28, 2014 | LG Washing Machines
Water pump runs constantly but no water pressure or water comes out of hose.
Lots of possibilities. Inlet filter might be clogged. I once had a lizard crawl into a water feed line, totally blocked the feed. Check valves might be stuck closed. Discharge hose might be plugged. Pump might be trashed ( if it is a vertical engine it is probably a throw away pump) Nozzle might be plugged.
Disconnect the hose at the discharge and turn on the water supply. It should have a stream of water even without the motor running. That will check the inlet filter, feed pipe and check valves.
Oct 07, 2014 | Garden
LG washing machine error code 0e....filter clean and machine level but still have error code
The drain pump on the machine could be faulty. This pump cannot be repaired it will have to be replaced if found to be faulty.
Sep 08, 2014 | LG Washing Machines
LG WM2277H front load washer isn't draining.
there is a clog somewhere in the drain for sure see the link below
if you think it has been cleared unplugg for 10 minutes and see what happens LG Front Load Washing Machine Error Code OE How To Clear
steer clear of LG as a repairman for a living they have weird problems like this all the time
over computerized with lo grade parts inside from my experiences
Feb 03, 2018 | LG WM2277H Front Load Washer
0E error code.
Open the access door at the lower left on the front of the washer. Drain remaining water using the small hose. Unscrew and remove the large knob. Clean out filter. If filter was clean, you may need a new pump motor, or something may have made it past the filter and is jamming the pump impeller. Check for a kink too if all is clear then you will probably need a drain pump. Make sure that the connections on the pump motor are on securely.
Here is your manual: http://www.4shared.com/document/aRIRumw9/WM1832xx_Service_Manual.html
Feb 27, 2011 | LG WM-2277HW Front Load Washer
Code 0E
That is actually a "DE" code, which stands for Drain Error. Open the access door at the bottom left on front of the machine. Use the small hose there to drain the last of the water out of the machine. Open the bigger knob in there and pull out the attached filter and clean out the filter. If there was nothing in the filter, replace the pump motor.
Feb 19, 2011 | LG WM0642H Front Load
Hi my washing mashine wont spin, and code 0E comes up on sreen and start button starts flashing PLEASE HELP THANKS
That is actually DE. (Drain Error) Open the small access door at the bottom left corner of the front panel. Use the small hose to drain the remaining water out of machine. Unscrew the big knob and pull it out to clean out filter. (If filter was clear, replace pump motor.)
Jan 01, 2011 | LG Washing Machines
LG tromm error code 0E
That's not OE, that's DE as in Drain Error. Open the access panel on the lower left front of the machine, use the small hose to drain out the remaining water, then unscrew the large plug and clean out the filter attached to the plug. If there is nothing in the filter, you may have a blocked pump impeller (not very likely as the filter stops most objects) or the pump impeller may have come off the pump motor shaft. If the later, replace the pump motor, as just popping the impeller back on will only result in repeat of your problem.
Oct 30, 2008 | Washing Machines
Washing Machines Logo
13 people viewed this question
Top Washing Machines Experts
