Question about Pool & Spa
My marquis 2006 rendezvous hot tub will not run unless we bypass. Is it the control panel or circuit board first to replace? How do you remove the control panel?
the dr
  • 447 Answers
SOURCE: Whirlpool Oven Control Panel Thermal Fuse
If the display is totally out it is likely the thermal fuse this is located where the wire connectors plug into the board it looks like a small resistor in a platic shrinkwrap type sleeve. test it with a continuity meter.
Posted on Oct 27, 2008
tjt3
  • 44 Answers
SOURCE: gfci breaker for spa
gfci's are designed to trip if they receive voltage on there ground/neutral side, therefore my vote is for Smithbrother I would say there is probably a partial short somewhere in you system.
Posted on Mar 24, 2009
  • 4 Answers
SOURCE: Can't unlock the control panel
Usually in sequence... Program-Mode-Temp Down... Or temp Up to lock
Posted on Aug 29, 2009
SOURCE: Heat pump defrost board
Does anyone know the location on a heil heap pump/a/c.of the dfrost board
Posted on Feb 24, 2010
Ian  Hot Tub
  • 77 Answers
SOURCE: Dream Maker spa - does my dream maker spa 4 person
Depending upon the age, the Dream Maker has a digital thermostat which is easy to change but to be honest I don't think that is the cause of your problem.
Check the keypad connection on the PCB (circuit board).
t could be either the keypad or PCB at fault and withou trying one or the other you'll not be able to determine the problem. My advise would be for you to contact your local parts supplier and ask them whether or not they can supply you a keypad to try with the option to send it back for a refund if it doesn't cure the problem.
A keypad can be trial fitted to the PCB, just unplug the old one, plug the new one in and turn on the power. There's no need to install the keypad to the spa, therefore you wont damage it in anyway.
If the keypad doesn't cure the problem, change the PCB.
Regards,
Ian.
http://hottub.synthasite.com
Posted on Apr 01, 2010
How to replace pump relay hot tub
If you are experiencing a relay problem on the circuit board of the hot tub, then it is best replace the complete circuit board. There are relays that you can solder on but unless you are very familiar with this process we would not recommend it.
US Parts Center
Jun 28, 2014 | Qca Spas Paradise Series Paradise Ultra...
I have a Sta Rite 400 btu heater. Replaced the manifold with tall the sensors. Replace the circuit board as well. Heater runs and keeps running just fine. After about an hour the temp in the hot tub...
This is a curious situation. Where is all that heat going if not into the water? If the heater is firing normally, the water temp should be rising much faster, unless the bypass is stuck open. However in that situation the high limits should sense that the water is too hot in the exchanger and shut the heater off. Verify that your gas supply is sufficient, because after running for an hour that heat should show up somewhere. It's possible there may be blockage in the gas supply resulting in a low flame.
Mar 07, 2014 | Sta Rite Pool & Spa
I have just replaced my circuit board (balboa 53247) for my eclipse hot tub and as soon as I plugged the unit in, I got an OH reading from the top-side control. Then I noticed that if I pulled the temp....
Unfortunately, I would have started with the sensors and then escalated from there. A hot tub is one of those items that I generally recommend hiring a technician to sort out, it's just flat not worth the headache of troubleshooting without the know-how.
As for your particular problem, the OH code on a Balboa control pack is "O.ver H.eating" it means that the heat sensor detected high temp and shut down to prevent damage to the system (as well as cooking you like a pink lobster) The sensor could be bad or the control board could be malfunctioning. A new sensor is $75-85 if memory serves me and is relatively easy to replace. one sensor is in the heating tube and the other is screwed into the tub shell to monitor tub temp. I would suggest new sensors, both of them because when one goes out the other usually isn't far behind. Make sure you shut the power to the tub off at the breaker box before doing any kind of tub repair. If you have shutoff valves on your tub you can replace the internal one without draining the tub. the one in the shell you need to drain to replace (at least to the sensor hole level) I hope this helps you to get your tub working properly again, if you still experience issues after this, I suggest biting the bullet and calling in a tech. Thanks for your question =)
Oct 28, 2013 | Dream Maker Spas Dream Maker Ez Spa Hot...
Our 880 Marin hot tub is constantly running the jets on 1/2 of the tub as if the circulation pump is running. The icon on the control panel does not show the jets are on. When we push the button to turn...
sounds to me with a power surge you could have a relay on the circuit board not working properly.
You will most likely need to change the circuit board to correct the problem.
US Parts Center
Sep 22, 2013 | Pool & Spa
Now that I have replaced the thermister on my Frigidaire Gallery Series 2004 electric dryer not only does it not produce any heat, though the blower works, the motor which turns the drum is not working...
Do not replace the control board unless the necessary troubleshooting is done to eliminate the other possible causes of the problem. The dryer will not heat if the motor doesn't run because the heating circuit is completed by the motor centrifugal switch which the motor activates. The problem with the motor not running must be determined and addressed first.
Disconnect power and with the top panel removed, locate the thermal limiter, a non-resettable fuse, mounted on the rear wall of the dryer.
Bypass the thermal limiter by disconnecting and joining the wires together. Reconnect power and start the dryer. Replace the thermal limiter along with the high-limit thermostat if the dryer starts and the problem with the motor not running is solved.
Let us know if the dryer still doesn't start and/or the drum lamp doesn't turn on when the door is opened with the thermal limiter bypassed for further advice.
Jan 29, 2011 | Dryers
My hot tub is getting power but I cannot get anything to run
you may have a circuit board error that is not allowing you to operate the controls or the top side may need replacing.
try locating the back up battery on circuit board and resetting it to restart your memory, does not always work but worth a try.
normally a J45 jumper, is marked on circuit board
Adam Miller, Canadian Spa Company, UK
Jun 21, 2010 | Balboa Instruments Duplex Digital Panel 2...
My Hot Tub, Hot Springs Model SQ, keeps shutting off. Under the black panel on hot tub wall, the lights LIM OK (green) and HTR ON (red) shuts off after being on for 2 min. Help!
It could be two things, first is the flow sensor, if it is bad the tub will shut off as it does not detect water flow and is protecting the pump(s). The other thing is the temp sensor, if it is bad, it senses the tub is to hot and shuts down so to protect the bathers from being burned. Both are are to check without the proper training and tools, find a good hot tub technician, it will run in the hundreds for testing and parts.
Mar 20, 2010 | Home
Froze the jacuzzi.
You'll need to start electrical troubleshooting from a point where you have power and then keep testing further into the unit to find out where the power stops. Is there a local 'ground fault' reset button inside the hot tub control area (under the tub?)
Jul 11, 2009 | Home
Jacuzzi hot tub will not shut off
I take it for granted that you know when the tub is in cycle mode for water circulation, ( the tub will do this every 4 to 8 hours unless programed otherwise). If it is truly going into the low speed on the pump, the problem lies in the circuit board. The double click you hear is the relay for the pump turning off and then on again. This is a costly problem to diagnose as circuit boards start at 200.00 and go up. If it is the relay, the only way to replace one is to replace the circuit board.
Jul 03, 2009 | Jacuzzi EH0 / EH1 / EG9 Fuzion 6666 Corner...
Gfci breaker for spa
Mar 15, 2009 | Spa Parts Plus GFCI, Circuit Breaker, 30...
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
