Question about Kenwood Car Audio & Video
Where is the remote power switch on a kenwood 1000 watt amp?
SOURCE: sony xplode 1000 watt amp
just make sure that your wiring is for 1000w or more
and check the + and - even at the speakers.
Posted on Nov 10, 2007
SOURCE: 1000 watt amp sony xplod
how do you have your system hooked? What speakers do you have? There is a lot more too it then just wattage.
Posted on Mar 22, 2008
Hazardsneon
  • 100 Answers
SOURCE: my amp overheats..
Do you mean that it actually over heats and shuts down? If it does then make sure you aren't trying to over drive it or underdrive the impedence. A good suggestion for cooling is get some 1/4" spacers and space the amp up off of the surface you mounted it too. I did it when I had my 2 Memphis M-Class 500Ws and just doing that they were cooler. Also make sure it is not mounted in a restricted air flow spot. If it is put some cooling fans by it to circulate some of the air. Let me know if you need some more help. Good luck.
-Andrew Hawkins
Posted on May 01, 2008
  • 323 Answers
SOURCE: the amp is only putting out on 1 channel
I do believe this is caused by one of your amp fuses. Depending on which + on the amp is being used. That channel has a blown fuse. have you tried running + and -, + and - to both channels to see if both subs worked? If one sub doesn't then it's a blown fuse or scarred fuse and needs to be changed.
Posted on Feb 10, 2009
soloxilu
  • 65 Answers
SOURCE: 920 Watt Kenwood Amp wont power on
Connect the remote wire to an accessory wire on your stereo.
Posted on Jul 08, 2009
What watt amp would i need to power 2 Kenwood KFC-WS253 10 inch subwoofer
get a nice 600 to 1000 watts Rockford and turn it down or upgrade speakers and turn it up it is usually better to have more than you need but control it
Aug 25, 2014 | Car Audio & Video
I have one 10in. Kicker L7. and a Kenwood KAC-929 1000 watt amp. What are all the wires i should buy that can make this setup run?
Need an amp kit up to 1000 watts, speaker wire. Amp kits have most of the wires needed such as, power, ground, and remote wire. As well as all the connectors needed.
Sep 22, 2010 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Car audio
If you are asking if you can have a kenwood amp hooked up to your Sony Head unit then yes it would be compatable.
Jun 02, 2010 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
Can i run just 2 subs on this 1200 watt kenwood 5-4-3 and if so what way will i get the most power, i mean do i bridge it or pute the speaker wires in other ports
you can run 2 subs given that you dont go over 2 ohms of resistance and that the subs are rated at 1000 watt max each around 4 or 500 watt rms. if your not sure about ohms dont bridge it and get single voice coil subs. this amp is capable of about 700watts constant power 1200 max spike if the voltage stays at 12 or higher.
Feb 05, 2010 | Kenwood KAC-X650D Car Audio Amplifier
How well will a 1000 watt kenwood amp pump with 2 1200 watt suns
2 will push more air but be careful how they are wired so you dont go to low on the ohms your amp sees.That amp should be 2 ohm stable so read up on how to wire in series or parallel.
Sep 06, 2009 | Kenwood KAC-9152D Car Audio Amplifier
I have 2 kicker l7 12s 4ohm speakers and was
Hello gonenutz14,
It depends on how you define the "best way". Driving each sub with a separate 750 watt amp will result in about 50 percent more power than having them share the output from a single 1000 watt amp. But with 2 amps, there's more wiring issues to contend with and the adjustments are more complex. The 2 750 watt amps will cost more than a single 1000. Plus if the 1000 watt amp is stable to 1 ohm, the power difference will actually be less than 50 percent because of the lower impedance. But if the 750 watt amps are also stable to 1 ohm and their outputs can be combined, we're back to 2 being better than 1.
I'd say that the simplest, most economical way is to use a single amp. If maximum power to the subs is the highest priority, and cost and wiring is not an issue, then 2 is better.
Hope this helps.
Jul 12, 2009 | Car Audio & Video
Jul 08, 2009 | Kenwood KAC-9152D Car Audio Amplifier
I have 3500 watts of subs total of 1100 rms what size amp should
Make shure your running thick guage wire like 2-0 guage wire to get correct power to it also and check on amp the ohm's it can handle to make shure your not running to makny ohms.
Jan 12, 2009 | Car Audio & Video
My kenwood amp
you need to check your wiring and check your rca wires to see if they are giving your amp a signal to put out
Mar 11, 2008 | Kenwood KAC-9152D Car Audio Amplifier
Car Audio & Video Logo
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
