Frigidaire FGGF3054KFH
SOURCE: My large burner will not shut off on my frigidaire stove.
You need to have the temp regulator replaced.
SOURCE: Oven flame too high.
Take a 1/2 inch open end wrench and tighten the orifice on the oven gas valve. Then adjust the air shutter on the venturi tube.
SOURCE: The oval burner has only very low flame, even when set on high
Every one of these ranges that I have seen with the oval style burner on them have a smaller flame then the normal round burners. And there is very little difference between the low and high settings. It sounds like what you are experiencing is normal. What the GE repairman was adjusting is called the "simmer stop". There is a small flat head screw inside the burner stem. By turning this screw you can adjust the size of the burner on the low position of the burner knob. This should be adjusted to where the burner still stays on when the knob is at the lowest setting. I do not think that you need the burner repaired. From my experience they are all like that.
SOURCE: Large burner has uneven and too strong a flame
could be the burner cap. possibly not converted proper. or burner assy bad
