Question about Garden
How to remove wheel seal from z810a 0 turn - Garden
How to replace front wheel bearing on 2003 kia sedona
Disassembly 1. Remove oil seal from front wheel hub. 2. Remove front wheel hub assembly with suitable tool.
bi6c021a.gif 3. Remove retaining ring. note_icon_eng.gif If the bearing inner race remains on wheel hub, grind a section of inner race until approximately 0.020 in (0.5 mm) remains. Remove race with a chisel.
bi6c021b.gif 4. Remove wheel bearing with suitable tool.
bi6c021c.gif note_icon_eng.gif Do not remove dust cover unless necessary. Do not reuse dust cover if removed. 5. Mark relative positions of dust cover and knuckle for proper reassembly. 6. Remove dust cover with a chisel.
ai2a023c.gif note_icon_eng.gif Do not remove wheel hub bolt unless necessary. Do not reuse wheel hub bolt if removed. 7. Remove wheel hub bolt with a press.
bi6c021d.gif Assembly 1. Press in new wheel studs. note_icon_eng.gif Front wheel hub press in either bolt turning or loosening by the torque of 108.5 lb•ft (147 N•m, 15 kg•m) shall not be premissible.
bi6c022a.gif 2. Mark new dust cover to match the removed dust cover. 3. Align mark on new dust cover with knuckle. 4. Install new dust cover with suitable tool.
bi6c022b.gif 5. Install new wheel bearing with suitable tool. 6. Install front wheel hub assembly with suitable tool.
bi6c022c.gif note_icon_eng.gif Use a new oil seal, and apply grease to seal. Install oil seal so that it is flush with knuckle. 7. Install new oil seal with SST(0K993 331 016).
Jan 12, 2013 | 2003 Kia Sedona
1998 ford explorer 2 wheel drive rear wheel bearing replacement
what about it?
conventional axle or limited slip? Get axle code off door sticker.
SECTION 205-02: Rear Drive Axle/Differential - Ford 8.8-Inch Ring Gear 1998 Explorer/Mountaineer Workshop Manual
IN-VEHICLE REPAIR Rear Wheel Bearing and Axle Shaft Oil Seal -4.0L SOHC and 4.0L EI, Conventional
Special Tool(s) swn~us~en~file=st1514a.gif~gen~ref.gif Axle Seal Replacer
T83T-1175-A swn~us~en~file=st1283a.gif~gen~ref.gif Axle Wheel Bearing Puller
T83T-1225-A swn~us~en~file=st1322a.gif~gen~ref.gif Axle Wheel Bearing Replacer
T83T-1225-B swn~us~en~file=st1326a.gif~gen~ref.gif Driver Handle
T80T-4000-W swn~us~en~file=st1185a.gif~gen~ref.gif Impact Slide Hammer
T50T-100-A
Removal
  1. Remove the axle shaft; refer to Axle Shaft in this section.
Axle Shaft Removal
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not use heat to loosen a seized lug nut. Heat can damage the wheel (1007) and the rear wheel bearings (1225).
    Loosen the lug nuts (1012).
    1. Remove the center cap.
    1. With the weight of the vehicle on the wheels, loosen the lug nuts.
  1. Raise and support the vehicle.
  1. Remove the wheel and tire assembly.
    1. Remove the lug nuts.
  1. Remove the axle housing cover (4033).
    1. Loosen the axle housing cover bolts (4346) and drain the rear axle (4001).
    1. Remove the axle housing cover bolts.
    1. Remove the axle housing cover.
  1. Remove the rear disc brake rotors (2C026); refer to Section 206-04 .
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Once the differential pinion shaft (4211) has been removed, turning the differential case (4204) or an axle shaft (4234) will cause the differential pinion gears (4215) to fall out of the assembly. This could result in chipped or damaged components.
    Remove the differential pinion shaft.
    1. Remove the differential pinion shaft lock bolt.
    1. Remove the differential pinion shaft.
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the rubber O-rings in the U-washer grooves.
    Remove the U-washers (4N237).
    1. Push the axle shafts inboard.
    1. Remove the U-washers.
  1. Reinstall the differential pinion shaft.
    1. Install the differential pinion shaft.
    1. Install the differential pinion shaft lock bolt finger-tight.
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the inner wheel bearing oil seal (1177).
    Remove the two axle shafts.
Installation
  1. Lubricate the lip of the inner wheel bearing oil seal.
    • Use Premium Long-Life Grease XG-1-C or equivalent meeting Ford specification ESA-M1C75-B.
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Once the differential pinion shaft has been removed, turning the differential case or an axle shaft will cause the differential pinion gears to fall out of the assembly. This could result in chipped or damaged components.
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the inner wheel bearing oil seal.
    Install the two axle shafts.
    Install the U-washers.
    1. Position the two U-washers on the button end of the axle shafts.
    1. Pull the axle shafts outward.
    1. Align the hole in the differential pinion shaft with the differential pinion shaft lock bolt hole.
    1. Install the differential pinion shaft lock bolt.
  1. Install the rear disc brake rotors; refer to Section 206-04 .
  1. Install the axle housing cover and fill the rear axle housing (4010) with 2.4 liters (5.5 pints) of specified lubricant; refer to Axle Housing Cover in this section.
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif WARNING: Always remove any corrosion, dirt or foreign material that may be present on the mounting surfaces of the wheel or the surface of the wheel hub or rear disc brake rotor that contacts the wheel. Installing wheels without proper metal-to-metal contact at the wheel mounting surfaces can cause the lug nut to loosen and the wheel to come off while the vehicle is in motion, causing loss of control.
    Clean the wheel hub and mounting surfaces.
  1. Install the tire and wheel assembly.
    1. Position the tire and wheel assembly.
    1. Install the lug nuts and lower the vehicle.
    1. Tighten the lug nuts.
    1. Install the center cap.
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Never remove the axle shaft oil seal by itself. Always remove the rear wheel bearing and the axle shaft oil seal at the same time.
    NOTE: If the axle shaft oil seal is leaking, the axle housing vent may be plugged with debris.
    Use Impact Slide Hammer and Axle Wheel Bearing Puller to remove the rear wheel bearing and the axle shaft oil seal.
Installation
  1. Lubricate the new rear wheel bearing.
    1. Use Thermally Stable Rear Axle Lubricant XY-80W90-QL or equivalent meeting Ford specification WSP-M2C197-A.
  1. Use Axle Wheel Bearing Replacer with Driver Handle to install the rear wheel bearing.
  1. Lubricate the lip of the new axle shaft oil seal.
  1. Use Axle Seal Replacer with Driver Handle to install the axle shaft oil seal.
  1. Install the axle shaft; refer to Axle Shaft in this section.
May 18, 2011 | Ford Explorer Cars & Trucks
What is needed to remedy right hand front wheel bearing play on a 1990 d21 4X4 ute
replace the bearing or wheel hub assembly.
REMOVAL & INSTALLATION 2wd Models NOTE: Refer to wheel bearing service and bearing preload adjustment procedures found in Section 1.
  1. Raise the front of the truck and support it with safety stands. Remove the wheels.
  2. Remove the brake caliper and suspend it with wire, out of the way. Remove the caliper torque plate if equipped.
  3. Remove the dust cap and then remove the cotter pin, lock washer (if equipped) nut lock and nut.
  4. Pull the hub/disc assembly off the spindle with the outer bearing. Don't let the bearing fall out.
  5. Pry the inner oil seal out and remove the inner bearing. To install:
  6. Clean and inspect the bearings and outer races.
  7. Using a brass drift and a hammer, drive out the bearing outer race. Press a new one into position.
  8. Pack the bearings with grease until it oozes out the other side. Coat the inside of the hub and cap with grease.
  9. Position the inner bearing into the hub, coat the oil seal with grease and press it into the hub.
  10. Press the hub assembly onto the spindle and install the outer bearing and thrust washer.
  11. Install the hub nut. Turn the hub a few times to seat the bearings and then loosen the nut until there is 0mm axial play. Using a spring tension gauge, check that the preload (with new grease seal installed) is 2.2–6.4 lbs. (9.8–28.4N)
  12. Install the lock-nut, new cotter pin and hub grease cap.
  13. Install the brake torque plate. Install the brake caliper.
  14. Install the wheels and lower the truck.
4wd Models The hub and bearing service procedures for a 4wd models are basically the same as those for a 2wd version, with the exception of removing the free running hub assembly and the bearing preload adjustment. Refer to Sections 1 and 7 for additional information. Adjust the preload after the wheel bearing is replaced or the front axle assembly is reassembled. BEARING PRELOAD ADJUSTMENT
  1. Thoroughly clean all parts and pack the wheel bearings.
  2. Apply grease to threaded portions of the spindle, grease seal lip and wheel hub.
  3. Tighten the wheel bearing lock-nut with a socket and torque wrench to 58–72 ft. lbs. (78–98 Nm).
  4. Rotate the hub in both directions a few times to seat the bearings. Loosen wheel bearing lock-nut.
  5. Retighten the lock-nut to 0.4–1.1 ft. lbs. (0.5–1.5 Nm).
  6. Turn wheel hub several times in both directions.
  7. Retighten the lock-nut to 0.4–1.1 ft. lbs. (0.5–1.5 Nm). Fig. 1: Exploded view of the front axle assembly — 2wd models 86718030.gif
    Fig. 2: Removing the bearing outer races 86718032.gif
    Fig. 3: Packing the wheel bearing with grease 86718033.gif
    Fig. 4: Pack the lip cavity of grease seal with grease 86718034.gif
    Fig. 5: Exploded view of the front axle assembly — 4wd models 86718031.gif
  8. Measure wheel bearing axial end-play. The wheel bearing end-play specification is 0.
  9. Install lock washer by tightening the lock-nut within 15–30 degrees.
  10. Turn wheel hub several times in both directions. Wheel bearing should be seated correctly.
  11. If necessary, measure wheel bearing preload. NOTE: Measure wheel bearing preload with a spring-type gauge; measure at wheel hub bolt, with tire removed. The hub assembly should rotate with 1.6–4.7 lbs. (0.73–2.13 kg) of pressure.
Jul 28, 2010 | 1991 Nissan Pickup
How do you change a wheel seal on a mercury mountaneer 1998 rear end
Axle Vent
NOTE: If the vent cannot be cleared, it must be installed new.
A plugged vent will cause excessive seal lip wear due to internal pressure buildup. If a leak occurs, check the vent. Make sure the vent hose is not kinked. Remove the hose from the vent nipple and clear the hose of any foreign material. While the hose is removed, pass a length of mechanics wire or a small diameter Allen wrench in and out of the vent to clean it. Connect the hose when done. The vent is located on the drivers side top of axle housing.
If you plan on doing most repairs yourself I would suggest buying a Haynes or Chilton manual for your particular vehicle. Or there are some data disks on e.bay($12-$15) For a cost of under $25, you can almost do any repair yourself with these manuals.Also there are online manuals like the site called ALLDATA where guides can be viewed for a fee. All these solutions will save you time and money, and give peace of mind over correct repairs. I can post you some procedures here also.
  1. CAUTION: Do not use heat to loosen a seized lug nut. Heat can damage the wheel (1007) and the rear wheel bearings (1225).
  2. Loosen the lug nuts (1012).
  3. Remove the center cap.
  4. With the weight of the vehicle on the wheels, loosen the lug nuts Raise and support the vehicle. .Remove the wheel and tire assembly.
  5. Remove the lug nuts.
  6. Remove the wheel and tire assembly. Remove the axle housing cover (4033).
7.Remove the rear disc brake rotors You will have to remove the brake caliper to get rotor off.
8. CAUTION: Once the differential pinion shaft (4211) has been removed, turning the differential case (4204) or an axle shaft (4234) will cause the differential pinion gears (4215) to fall out of the assembly. This could result in chipped or damaged components.
9.
1.Remove the differential pinion shaft lock bolt. 2.Remove the differential pinion shaft. 4fd1df0.gif 10.CAUTION: Do not damage the rubber O-rings in the U-washer grooves. Remove the U-washers (4N237).
  2. Remove the U-washers.
    11.Reinstall the differential pinion shaft.
      12.CAUTION: Do not damage the inner wheel bearing oil seal (1177). Remove the two axle shafts. 1848771.gif
CAUTION: Never remove the axle shaft oil seal by itself. Always remove the rear wheel bearing and the axle shaft oil seal at the same time. NOTE: If the axle shaft oil seal is leaking, the axle housing vent may be plugged with debris. Use Impact Slide Hammer and Axle Wheel Bearing Puller to remove the rear wheel bearing and the axle shaft oil seal.
0ffed5b.gifAxle bearing puller end..
Installation
  1. CAUTION: Once the differential pinion shaft has been removed, turning the differential case or an axle shaft will cause the differential pinion gears to fall out of the assembly. This could result in chipped or damaged components.
  2. Remove the differential pinion shaft.
  3. Remove the differential pinion shaft lock bolt.
  4. Remove the differential pinion shaft.
    CAUTION: Do not damage the inner wheel bearing oil seal. Install the two axle shafts. CAUTION: Do not damage the rubber O-rings in the U-washer grooves. Install the U-washers.
                                                            Install the rear disc brake rotors; Install the axle housing cover and fill the rear axle housing (4010) with 2.4 liters (5.5 pints) of specified lubricant
                                                            WARNING: Always remove any corrosion, dirt or foreign material that may be present on the mounting surfaces of the wheel or the surface of the wheel hub or rear disc brake rotor that contacts the wheel. Installing wheels without proper metal-to-metal contact at the wheel mounting surfaces can cause the lug nut to loosen and the wheel to come off while the vehicle is in motion, causing loss of control. Clean the wheel hub and mounting surfaces. Install the tire and wheel assembly.
                                                            Position the tire and wheel assembly. Install the lug nuts and lower the vehicle. Tighten the lug nuts. Install the center cap. 6a78fd6.gif WHEW Hope this can help you
                                                            Mar 21, 2010 | 1998 Mercury Mountaineer
                                                            Need to know how to install wheel bearings on a chevy cavalier
                                                            1) Break the torque on the center wheel nut and remove the nut and washer before jacking up the front end. 2) Jack up the front and remove the tire. 3) Remove the brake caliper and rotor. 4) After removing the rotor you will see the bearing assy. There are 3 torx bolts holding it on. You need to put the transmission in neutral to turn the hub and line up the hole to remove the bolts. 4) Knock it loose with a hammer and install in reverse order. The kit comes with a seal but I don't believe it's needed on a 96. Pretty simple job really... Good Luck.
                                                            Feb 19, 2010 | 1996 Chevrolet Cavalier
                                                            E511 error code
                                                            1. Check of Photoconductor Unit attachment. Re-attach Photoconductor Unit.
                                                            2. Is the Drum of Photoconductor Unit rotating?
                                                            3. Remove Photoconductor Unit. Turn gear of Photoconductor Unit until silver seal attached to Belt can be seen.Is silver seal dirty?
                                                            4. Remove Photoconductor Unit. Is SENSOR TR-0 attached securely?
                                                            5. Remove Photoconductor Unit. Are there any dirt or foreign bodies on the SENSOR TR-0 surface?
                                                            6. Does the error recur when the power is turned ON?
                                                            7. Remove Photoconductor Unit. The voltage of P416-2 ↔ P416-3 on PWBA MCU is 5 VDC when silver paper or other reflective object comes close to the sensing area of SENSOR TR-0, and is 0 VDC when the object is released?
                                                            8. The voltage of P416-1 ↔ P416-3 on PWBA MCU is 5 VDC?
                                                            9. Disconnect the P/J416 from PWBA MCU. Do all of the wiring below have normal continuity?
                                                            10. Replace MOTOR ASSY P/R.
                                                            Jun 19, 2009 | Epson Aculaser C1100 Printer
                                                            Need help replacing front hub
                                                            Here's the steps....getting some pics for you....hang on a minute or two.
                                                            Front Hub Removal & Installation To Remove:
                                                            1. Remove steering knuckle.
                                                            2. Using a suitable slap hammer, remove wheel hub assembly.
                                                            3. Using a suitable bearing press, remove outer bearing, oil seal, outer bearing race and preload spacer.
                                                            4. Remove inner oil seal, inner wheel bearing and inner bearing race.
                                                            NOTE: It is not necessary to remove dust cover (back plate).
                                                            To Install:
                                                            1. Using a suitable bearing press, install bearing races in steering knuckle.
                                                            2. Pack the bearings and hub area with lithium grease.
                                                            3. Install inner bearing in steering knuckle.
                                                            4. Lubricate lip of NEW inner seal and press seal into knuckle.
                                                            5. Install preload spacer into bore.
                                                            6. Install outer bearing into bore.
                                                            7. Lubricate lip of NEW outer seal and press seal into knuckle.
                                                            8. Using an appropriate tool, support inner wheel bearing and press wheel hub into knuckle with a force of 2500kg.
                                                            9. Install NEW inner seal.
                                                            10. Install knuckle assembly.
                                                            May 13, 2009 | 2004 Kia Rio
                                                            Replace left rear axle seal 1999 ford explorer
                                                            Axle Shaft Removal
                                                            1. Raise and support the vehicle. For additional information, refer to Section 100-02 .
                                                            1. Remove the wheel and tire assembly. For additional information, refer to Section 204-04 .
                                                            1. Remove the differential housing cover (4033).
                                                              1. Loosen the bolts and drain the lubricant from the rear axle housing (4010).
                                                              1. Remove the bolts.
                                                              1. Remove the differential housing cover.
                                                            Remove the rear brake disc (2C026). For additional information, refer to Section 206-04 .
                                                            1. sxn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Turning the differential case (4204) or an axle shaft (4234) with the differential pinion shaft (4211) removed will cause the differential pinion gears (4215) to fall out of the assembly and damage the components.
                                                            2. sxn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the rubber O-ring in the U-washer groove.
                                                            3. Remove the U-washer (4N237).
                                                            4. Push the axle shaft inboard.
                                                            5. Remove the U-washer.
                                                            2. Install the differential pinion shaft lock bolt finger-tight.
                                                            3. sxn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the wheel bearing oil seal (1177).
                                                              Remove the axle shaft.
                                                            Seal Removal
                                                            1. Remove the axle shaft (4334). For additional information, refer to Axle Shaft in this section.
                                                            1. sxn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Never remove the wheel bearing oil seal (1177) by itself. Always remove the rear wheel bearing (1225) and the inner wheel bearing oil seal at the same time.
                                                              NOTE: If the wheel bearing oil seal is leaking, the axle housing vent may be plugged with foreign material.
                                                              Using the special tools, remove the rear wheel bearing and wheel bearing oil seal together.
                                                            6c7eb46.gif Installation
                                                              • For 4.0L SOHC and 4.0L EI with limited slip rear axles and 5.0L vehicles, use SAE 75W-140 High Performance Rear Axle Lubricant F1TZ-19580-B or equivalent meeting Ford specification WSL-M2C192-A.
                                                              • For 4.0L SOHC and 4.0L EI with conventional rear axles, use SAE 80W-90 Premium Rear Axle Lubricant XY-80W90-QL or equivalent meeting Ford specification WSP-M2C197-A.
                                                            1. Using the special tools, install the rear wheel bearing.
                                                            1. Lubricate the lip of the new wheel bearing oil seal.
                                                            1. Using the special tools, install the wheel bearing oil seal.
                                                            1. Install the axle shaft. For additional information, refer to Axle Shaft in this section.
                                                            Feb 22, 2009 | 1999 Isuzu Rodeo
                                                            Replacing rear wheel bearings on 1999 hyundai sonata
                                                            1. for drum brakes with sealed hub(all one piece) remove lug nuts and wheel.
                                                            2. spray penetrating oil around studs if there is a big phillips head screw visible remove it with impact driver/if not use big ballpeen hammer ,tap on flat of drum near studs(becareful not to hit them) until drum loosens(your creating a shockwave to loosen rust)
                                                            3. once drum is off there are 4-bolts coming in from behind backing plate, remove them then hub should be able to be removed w/a little persuation from hammer.
                                                            with out sealed hub ,
                                                            1. remove wheel
                                                            2. remove dust cap,cotterpin,star washer(if equipped) do not re use cotter pin
                                                            3. remove nut then washer, wiggle brake drum and front bearing will come out.
                                                            4. put nut on shaft tighten 2-3 turns grab drum by sides and pull towards you this should remove drum leaving inner bearing/seal on shaft
                                                            5. to replace reverse procedure making sure to pack new bearings w/grease(take drum and use long punch to remove bearing races, use race/seal installer to install new races
                                                            with disk brakes
                                                            1. remove wheel
                                                            2. remove caliper/bracket
                                                            3. remove rotor
                                                            4. remove 4-bolts from behind,tap old hub out
                                                            5. reverse procedure
                                                            Jul 19, 2008 | 1999 Hyundai Sonata
                                                            Garden Logo
                                                            Top Garden Experts
                                                            Dennis Key
                                                            Dennis Key
                                                            roeb
                                                            john h
