Question about Garden
Have a tc 25 tracto which mid pto runs in reverse ccw which will not operate my mower
  • 61 Answers
SOURCE: I have a scotts (made
sounds like safety switch
Posted on Sep 06, 2009
huffman49
  • 235 Answers
SOURCE: Riding mower stalls when PTO is engaged.
check the kill switch and the wire it could be that a small piece of the covering came off and is grounding to the deck or frame there by killing the engine the jerkink of the mower maybe whats causing the wire to come into contact with metal..good luck
Posted on Apr 03, 2010
SOURCE: My Cub cadet pto cluch bearing is froze up on my 2518 lawn tracto
A medium length extension (stuck through the grill), a swivel and an impact is all you need to remove the pulley with the frozen bearing. It's just a bolt, a washer, and a lock washer holding it on. You just need to remove the pulley to see if the bearing is stuck. Take the pulley to your local shop that can press bearings and you can be up and running for $20 dollars instead of $300. Here's a diagram I found on partstree:
http://www.partstree.com/parts/?lc=cub_cadet&mn=2518-48+Tractor&dn=0043700012
Posted on Apr 11, 2010
  • 13 Answers
SOURCE: the engine start running rough when pto in engaged.
An air filter can look clean and not be. Remover the air filter and pre filter and try again. If engine smooths out, you need a new air filter.
Posted on May 12, 2010
g5edhmlm
SOURCE: PTO red light switch is on when PTO isn't, so engine won't start
unplug the reverse safety switch from behing the console next to the ignition switch
Posted on Apr 09, 2012
I have a LT1042, cub cadet. PTO clutch burnt up. I replaced it and the solenoid, fuse, and relay. Thinking that when PTO clutch burnt out that something else like a wire or sensor went out also.
Check all the safety switches u have a bad one look under the seat first that one is a common problem so I take it your PTO won't engage I bet your old PTO is still good the safety junk they put on these mowers fails a lot causing problems running your mower also look under the back side by the tire there is another safety switch that gets corroded that's switch is the one that will not let you mow in reverse if you want to bypass it u can just put the wires together then beware your mower will work in reverse also I hope this helps you have a great day Regards Chris
Aug 03, 2016 | Cub Cadet Garden
Why does my oto shut off when engaged and motor shuts off but motor will keep running if pto is turned off
You have a bad safety somewhere, heres a few places to check, your seat switch if thats bad it thinks theres no one on the the mower and it wont let you cut grass, reverse switch some mowers wont let you cut in reverse in case kids are around, brake switch which should be working since your able to turn on the mower, check your pto switch as well could be bad but my guess is the seat switch let us what you find
May 17, 2016 | Garden
Engine runs, but when I engage the electric PTO why does it go dead?
Newer mowers have a safety interlock that prevents the mower running when going in reverse. My guess is that the reverse switch is on and when the PTO is activated the engine dies like you shut off the key.
Second idea is that the device the PTO drives is frozen up. Test this by trying to see if it turns with the engine off. When you engage the PTO the engine chokes down because it can't turn the PTO.
Mar 29, 2016 | Garden
Ihavert42.zero turn pto will not work
Check PTO switch
check fuses
check safety switches on the mower.
Mid all good then you will probably need to replace the PTO clutch.
Check switches using a voltmeter
Jul 11, 2015 | Cub Cadet RZT L42 42" 22HP Zero Turn Mower...
How come I can't start my John Deere LA115 after
The Reverse Interrupt Override switch is supposed to let you keep the blades engaged while using reverse. Be sure PTO is off and brake pedal is depressed and try to start engine. If it wont start/ wont crank then a switch is stuck or failed or there is a broken wire. Switches that are involved with PTO operation are the seat switch, reverse switch, PTO switch, and RIO switch. The starting system requires neutral ( no reverse activated), brake switch and PTO switch off.
Sep 02, 2014 | Garden
X595 john deere pto wont kick in
These John Deere Garden Tractors have a RIO (Reverse Implement Option) on the PTO. If your PTO is engaged and you back up, the PTO will automatically stop. To reset it, depress your PTO engagement switch to the OFF position. Take your foot off the reverse pedal. Pull up on the PTO engagement switch. The PTO should restart. To use the RIO feature, pull up on the PTO switch for a second or two just before you step on the reverse hydrostatic pedal. The yellow RIO indicator light should come on your dashboard and you can now back up with the PTO still running. Works great for snow blowing when I don't want to keep resetting my electric PTO clutch to keep restarting my snow blower.
If your PTO will not restart, you may have a PTO switch starting to fail, or a likely logic problem in your electric PTO control module, or one of your forward/reverse indicator switches, which is linked to your PTO control module along with the overtemp circuit, is stuck/faulty.
Feb 20, 2013 | John Deere 26HP Hydrostatic 54" Riding...
Huysky 25 horse honda gt belw a 30A fuse replaced now pto wont engage. suggestions?
unplug the clutch and see if it blows a new fuse if not pull the clutch off and check for bare wires that may have rubbed against metal
May 18, 2012 | Garden
I have a Briggs & Stratton ride on mower model TC 200 V-2. It starts and runs fine but the electro magnetic clutch does not engage. Could you please help
check to see that the switch is good,just cross the wires and it will tell ya
check the length of the wire down to the elect pto and also if need be the pto its self
Jul 22, 2011 | Garden
I have a cub cadet RZT 54 that was purchased in the spring of 2009. The mower cranks and runs fine but the blades will not engage. Have looked at electrical connections and everything looks fine.
Do you hear a "clunk" when you engage the PTO switch, but the blades don't turn? If so, then check the mower deck belt - is it properly threaded, and tensioned by the idler pulley? If there's absolutely no sound when you engage the PTO switch, the problem is likely electrical (even though everything looks OK). The PTO switch, PTO clutch, and the reverse lockout switches (near the bottom of the fwd/reverse control arms) should be checked. I don't think there's a separate fuse for the PTO on your mower, but there may be a relay. Even though these parts and connections look OK, they can fail internally. Best bet is to get a multitester and check each of them with the ohmmeter function.
Jul 02, 2010 | Cub Cadet Garden
Apr 08, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
