Question about Pro Computers & Internet
Trying to find Manual for a 2008 MacBook Pro 15" Lap top Still works.
    New Friend:
  • 12 Answers
Here you go buddy, hope this is what you are looking for
Posted on May 14, 2017
  • Dario Hunski
    Dario Hunski May 14, 2017
    https://www.google.hr/url?sa=t&source=we...
    I don't see the link so here it is
Looking for a Manual for about 2008 MacBook Pro lap top. Still works.
https://www.google.hr/url?sa=t&source=web&rct=j&url=https://static.bhphotovideo.com/lit_files/254924.pdf&ved=0ahUKEwis-vH8sPDTAhWjL8AKHX7HDHwQFggZMAA&usg=AFQjCNFkEpWKewrm2jMOYjyUGDh_-XFgdQ&sig2=kLpvXgnVcHI8DjUBKvFDsg
May 14, 2017 | Pro Computers & Internet
15' macboo pro 2008 15' screen problem. Colors turn negatitive when screen is tilted a certain way.
sounds like the video cable is pinched in the hinges. This was really common with first generation macbook air. iFixit.com has guides for disassembling, but you'll quite likely need a new video cable.
Apr 18, 2014 | Apple Customized 15" MacBook Pro Laptop...
I can not update my mac to 10.9
Hard to say without knowing exactly what Mac you have and what specs, but most likely reason would be your system doesn't meet the requirements (From Apple support site) - To install Mavericks, you need one of these Macs:
  • iMac (Mid-2007 or later)
  • MacBook (13-inch Aluminum, Late 2008), (13-inch, Early 2009 or later)
  • MacBook Pro (13-inch, Mid-2009 or later),
  • MacBook Pro (15-inch or 17-inch, Mid/Late 2007 or later)
  • MacBook Air (Late 2008 or later)
  • Mac mini (Early 2009 or later)
  • Mac Pro (Early 2008 or later)
  • Xserve (Early 2009)
Your Mac also needs:
  • OS X Mountain Lion, Lion, or Snow Leopard v10.6.8 already installed
  • 2 GB or more of memory
  • 8 GB or more of available space
Jan 18, 2014 | Apple OS Computers & Internet
My lap top and also the charger adaptor soon after a couple of minutes overheats during windows usage!!!!
Run diags to be sure your heatsink and fans are working. Check for dust clogging air vents. Use PC on a flat surfaces. Check specs for correct amps and voltage
for your PC version.
Nov 28, 2013 | Apple MacBook Pro Summer 2009 Core 2 Duo...
Overheats shuts down
It is tempting to use the Mac on a pillow on your lap. This will "insulate" it and cause heating issues. Or you may be using it where it cannot allow enough airflow to cool it
Sep 12, 2013 | Apple MA610LL A 15Inch MacBook Pro 2.33...
Stuck disc mackbook pro lap top
The MacBook has a dvd slot load design, I recommend a technician who is trained to work on these laptops because they are more complex than the regular computers.
Jul 31, 2012 | Apple MacBook Pro Laptop Computer with...
How to change the hard drive of my Mac Power Book Pro laptop?
This guide is for a 15 inch power book pro. It is for the mid to late 2008. The file is 30 mb and is the service manual for the laptop.
Look in the left pane and click on hard drive, it will explain the location and procedure.
http://tim.id.au/laptops/apple/MacBook%20Pro%20(15-inch%20Early%202008).pdf
Sep 22, 2009 | Computers & Internet
Manaul for Mac Pro 15 lap top - snow leopard
http://manuals.info.apple.com/en/macbook_pro_users_guide.pdf
..there ya go
hope this helps - good luck!
Sep 17, 2009 | Apple MacBook Pro Laptop Computer with...
Macbook goes to sleep and doesn't wake up unless I do a hard reboot.
I have seen this caused by having a mouse plugged into mine. I have removed the mouse and touch the touchpad and it has come up from sleep.
That very well may not be your problem.
Here is the procedure that is recommend from Apple to help with the not waking from sleep problem. I included both methods as it is not clear which macbook you have. I also included the link to the article at the bottom.
The System Management Controller is an integrated circuit (computer chip) that is on the logic board of the computer. As the name implies, it is responsible for power management of the computer. It controls backlighting, hard disk spin down, sleep and wake, some charging aspects, trackpad control, and some input/output as it relates to the computer sleeping.
Over time, the settings in the System Management Controller may become unusable, which can result in operational anomalies with the computer. Examples include not turning on, not waking from sleep, not charging the battery, or not recognizing the AC Adapter, among others.
MacBook (13 inch, Late 2008), MacBook Pro (15-inch, Early 2008), and MacBook Pro (17-inch, Early 2008)
  1. If the computer is on, turn it off.
  2. Disconnect the AC adapter and remove the computer's battery.
  3. Press and hold the power button for 5 seconds and then release the button.
  4. Reconnect the battery and AC Adapter.
  5. Press the power button to restart the computer
Note: Starting with MacBook Pro (Late 2008) and MacBook (Late 2008) models, you may instead use the reset method for MacBook Air (below) to reset the SMC. All earlier models of MacBook and MacBook Pro must use the method described above, which involves removing the battery.
MacBook Air and MacBook Pro (Late 2008 and later)
  1. If the computer is on, turn it off by choosing Shutdown from the Apple () menu.
  2. Connect the power adapter to a working power source.
  3. On the built-in keyboard, press (left) Shift-Control-Option along with the power button once.
  4. Wait 5 seconds and press the power button to start the computer.
Note: You must use the keys on the left side of the built-in keyboard.
Here is the link to the article at the Apple support site.
http://support.apple.com/kb/HT1411
Aug 28, 2009 | Office Equipment & Supplies
Computers & Internet Logo
37 people viewed this question
Top Pro Computers & Internet Experts
k24674
Andrew Taylor
Andrew Taylor
DVL55
Level 1 Expert
Are you a Pro Computer and Internet Expert? Answer questions, earn points and help others
