Question about Toys
I bought a used Wild Child motorcyle and it came with everything except the charger. Where can I purchase a replacement charger?
I bought this item a year ago, the battery does not charge anymore, do you sell a replacement battery? how much is it?
there will be a number on said battery just ebay that number and it will give you alternatives but they will be the same battery
example yb250rm
Mar 23, 2017 | Lil' Rider tm Harley Style Wild Child...
Our Lil' Rider Harley Style Wild Child Motorcycle battery appears to be cracked.
If the battery has the voltage and amps on it, you can buy any battery from here. I use them a lot.
Battery Buyer Batterybuyer com
Jan 13, 2017 | Lil' Rider tm Harley Style Wild Child...
Will not charge first time
If the battery will not charge on a motorcycle the problem is usually caused by a faulty regulator/rectifier
Dec 23, 2015 | Lil' Rider tm Harley Style Wild Child...
Where the charger outlet located
The input is on the right hand side of the bike look on the side of the chrome engine cover above the gas pedal. ours has a sticker that says " INPUT" above the connection.
Oct 09, 2014 | Lil' Rider tm Harley Style Wild Child...
Can't find where to change batteries for sirens and lights on Lil' rider Harley Style Wild Child Motorcycle
The one main battery that powers the bike powers everything. There are not separate batteries.
Apr 02, 2014 | Lil' Rider tm Harley Style Wild Child...
Where can I purchase a charger and manuel for a EZ Rider Wild Child Motorcycle
you could try the original supplier or ebay and failing that you could try searching online for a pdf manual and just buy any charger that is the correct type voltage and most importantly polarity, having looked at the bike its a childs harley type bike and is 6v 4ah and likely a sealed lead acid type so i would buy a 6v 500ma lead acid charger, if there is a charge port you will need a plug to match and you will need to check the polarity is correct or if there is easy access to the battery terminals you could just use the crocodile clips to the corresponding terminals on the battery itself there is a selection of chargers here 6V Lead Acid Battery Charger eBay a 500ma charger will charge the bike in 8hrs the higher the ah the faster it will charge but i wouldnt go much higher than 500ma without checking with the vendor that it is suitable for a 4ah battery hope this helps
Feb 22, 2014 | Toys
I need the bed frame for my Child Craft Legacy covertable crib. modle # F37101.53 color golden oak. Child Craft was bought out and now I can't find anyone who will get me the frame to make this a full...
I purchased (and subsequently threw away) the side pieces that turn the crib into a bed. I purchased them from Childcraft Industries. Extremely poor design. So I went ahead and purchased a bed frame and just used the header of the crib. Works great. Don
Aug 12, 2010 | Child Craft Legacy 21031 Crib
Kyocera Wild Card Data Cable
you get a bluetooth Dong and data kit. Look on the net or radio shack has it.
Oct 06, 2008 | Kyocera wild card Cellular Phone
Toys Logo
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
