Question about Cycling
How do I remove the front tire from my Mesa model bicycle? It seems the front brakes are on too tight for it to just slip off?
  • Steven Ford May 11, 2010
    What type of brakes do you have? Caliper? If so then there should be one side that pulls out of the caliper. You can check by holding the break pads closed with one hand then wiggling the cable on both sides and one side should have a 'nub' on it. That hold it in place but will slide out if you push it away from the handle bars (down) while holding the pads to the rim.
    Scholar:
  • 173 Answers
The first thing, that may give you enough, 'slack' on the cable.
Would be to minimize the tension at the hand lever end, by winding the adjustment 'in'.
In other words, tighten it up. * maybe 'unhook' the soldered end from the lever.
Normally, also there is a simple 'hook' mechanism on the calliper end. Et voila!
Have fun with that.
Posted on Jul 26, 2009
Quick release bike tire installation
the pads don't need to be removed. Most brakes have a "quick release" on them. On linear pull brakes, use one hand to squeeze the two lever against the rim and with your other hand you can pull the "L" shaped cable noodle out the bracket and this releases the brakes. (you can also let the air out of the tire and install the wheel then reinflate the tire once you have it back on the bike). On road bikes with side-pull brakes most have a small lever you can flip up that activates a cam mechanism that opens the brakes up to allow the tire to pass through. Canti-lever brakes are similar to linear-pull brakes, just squeeze the brakes together and release the straddle cable. Hope this helps.
Aug 13, 2014 | Cycling
How to install front tire of mongoose bmx
Remove wheels, remove valve stem from innertube. remove tire by getting tire edge over rim. reinstall in opposite direction. If this seems difficult consult local bike shop for assistance
Dec 28, 2012 | Freestyle Mongoose Bmx & Owners Manual -...
On mountain bike the chain or peddles seem to slip or click goning up a hill. Is it the chain slipping or worn gear?
It sounds like your chain is loose. Flip the bike over and loosen up the nuts on the back tire and tighten the nuts as you are pulling the rim back making the chain as tight as you can. You might need someone to help you pull as you tighten the nuts.
Aug 26, 2011 | Cycling
What size seatpost fits the schwinn mesa gsd? what size seat clamP? what size front derailuer? what size bottom bracket?
As this example shows, they don't publish all of those variables...
http://www.bikepedia.com/quickbike/BikeSpecs.aspx?Year=2004&Brand=Schwinn&Model=Mesa+GSD&Type=bike
Ask Schwinn.
http://www.schwinnbikes.com/contacts
1-800-626-2811
The year it was made might affect the answers. Ever seen this before - "*All prices and specifications are subject to change without notice."
Jul 06, 2011 | Schwinn Mesa GSD Men's Mountain Bike
I have a Schwinn Ditch mountain bike with front disc brakes and a quick release front tire. I pooped the tire off using the quick release on the hub and the tire simply slipped off and out of the disc...
You have to bleed the break fluid on your break and press the pads on both sides then insert the disc. When you bleed the break fluid do not press the lever.
Apr 10, 2011 | Schwinn Cycling
I have a Schwinn "95 Mesa GS. Looking for
If these are replaceable than you would you have to look it up by the brand of shocks.
Ex. Rockshocks Duke 1995. The replacement parts are specific to the make/ model and year. All the shock companies have a customer service messaging service so they can you give you advice on your particular shock.
Jan 10, 2011 | Schwinn Mesa Gs Mountain Bike
I would like to service my Schwinn Mesa, Is there a manual? If not what needs to be done for a general service?
Check, clean, and lube all the brake and shifter cables. Check and possibly replace brake pads. Check for any play in the headset ( this is the tube that carries the bearings for the handlebars and front fork ). Clean and lube the chain, gears, and derailers. After all of that just check the torque on all the hardware and make sure nothing is coming loose.
May 31, 2010 | Schwinn Mesa GSD Men's Mountain Bike
Brakes too tight
There are screws/bolts connecting the brake pad to the brake plate. Try moving them out. Also, it works off of cable tension. Extend the length of the cable by lightly unscrewing the cable at the brake mount until it pulls the brake plate open loosely, pull on the cable until your breaks are the desired width apart and screw it back in.
Advice: use locking clamps on the end of the cable so that when you unscrew it, it doesn't go back through the hole. Re-threading it is a pain-in-the-****.
Good luck and please rate my solution accordingly.
V/r,
Coldissickofman
Jan 23, 2010 | Schwinn Mesa Gs Mountain Bike
The left brake is disconnected, how do I reconnect it?
You'll have to remove the mounting bolt from that arm with the proper size allen key. Clean the post and lube it. While you have the arm off have a look at the spring . It may be broken or just disconnected from where it is supposed to be attached. Also check that the brake cable is moving freely in the guide(noodle) and is attached properly to the opposing brake arm.When you have the pivot lubed slide the brake arm back on and make sure it pivots properly. Readjust the brakes and you should be in business. The front brakes and the back brakes work the same so look at the working set and compare to the non working set if you need a guideline to go by. If you have hydraulic brakes you will have to take the bike in to be serviced as it requires specialized tools. Hope this helps.
May 30, 2009 | Schwinn Mesa Gs Mountain Bike
Cycling Logo
43 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
