6150 key pad says pi not ready - Office Equipment & Supplies
How can I change pi value to 3.14 on calculator?
I don't think you can change the pi value on your calculator. However, what you can do is store 3.14 in the memory and instead of using the pi key, recall the number from the memory key.
How to use the various memory keys is outlined in the manual.
Good luck,
Apr 07, 2016 | Casio fx-300ES Calculator
How can you find the circumference of a circle using the FX-ES 115 Plus?
Th formula is PI *dia.
Pi is available on this model using Shift key + X10 key at middle bottom.
So enter Pi then key x (multiply) then enter diameter then = key.
Nov 10, 2014 | Office Equipment & Supplies
Finding pi
look for the pi key it should be there or type
sin(180/1000000)*1000000 press enter or equal key to get 3.141592654 for a result it the same value as pj on the pi key times it by 3 to get
9.424777961 for a result.
hope this helps
Apr 18, 2014 | Texas Instruments TI-15 Explorer...
Unresponsible key
Try cleaning the keypad. Reset the calculator. When you press the EXP key or the 2ndF +EXP key try pressing firmly the calculator between your thumb and index (left hand).
To work around this defect (due to the venerable age maybe)
enter the approximate value of PI=3.14159265359 on your calculator and store it in one of the available memory locations. When you need use PI just recall the value to the display.
The EXP key is just a short cut for *10^(exponent). You can explicitly use the general power key.
If you are averse to using this workaround consider acquiring another calculator.
Dec 24, 2013 | Sharp Office Equipment & Supplies
It wont give me the value when i multiply like 6 x pi
Your calculator may be able to use the symbol Pi. If it gives you a result with Pi, you should convert it to a decimal approximation. There must be a key to convert.
Nov 12, 2013 | Canon F-719SG Green Scientific Calculator...
Look for a key marked with the Greek letter PI. The marking may be on the key itself, or on the faceplate of calculator. If marking is on the key, you press the key to enter an approximate value of Pi. If marking is on faceplate you will have to press the SHIFT key first.
Aug 23, 2013 | Casio FX-300MS Calculator
How to use pi button on ti30xIIs
Press the pi key to put the value of pi into the machine. You can then use it as you would any other number.
There's nothing fancy or tricky about it. It's there only to spare you from remembering and typing in the value of pi.
Jul 24, 2012 | Texas Instruments TI-30 XIIS Calculator
Trying to find the surface area of a sphere given the volume: V = 4/3 X pi X r cube problem given vol. find the surface area v = 5000 5000(3/4 pi =r cube the book reads: 3 cube before and the square...
Almost exactly the way it's written in the book.
In the LineIO mode press
3 SHIFT [xth-root] 5 0 0 0 * 3 / ( 4 * SHIFT [pi] ) ) =
In the MathIO mode press
SHIFT [xth-root] 3 right-arrow 5 0 0 0 * 3 / ( 4 * SHIFT [pi]) =
xth-root is the shifted function of the key just below and right of the big round cursor pad.
* is the multiply key
/ is the divide key
pi is the shifted function of the x10^x key in the middle of the bottom row
BTW there's no "square root" in this problem. There's a "cube root" or "third root". Square root is the second root.
May 14, 2011 | Casio fx-300ES Calculator
My lcd screen is blank and system doesn't respond to commands... Says ''not ready'' but that's it! There is power to the units but no response except a single beep after the pin and command is entered. It...
FYI 6150 is keypad model not alarm model. See if yhis helps. try pressing the " * " key bottom leftit thould then indicate zone trouble or fault. that sould give you at least some place to start.
Feb 07, 2010 | Honeywell 5804 Ademco Wireless Security...
How do I enter pi on Casio fx-115es?
Enter your number then press (shift) then (X10x) key. That will enter pi. then press (=) for the answer.
Jul 03, 2009 | Casio FX-115ES Scientific Calculator
18 people viewed this question
