Question about Home Security
My 6150 keypad says pi not ready - Home Security
My 6150 keypad says 16 Why
If it also shows not ready, zone 16 could be open. If the word "bat" is on the display at the same time as 16, zone 16 could have a low battery.
Jun 04, 2017 | Home Security
I need to replace my Honeywell ademco keypad M6674 Rev A. I have a vista 10 control panel. What model do I replace it with?
I am not familiar with this keypad, but if it were me, I would look to upgrade the control panel to a Vista 20P, although it's a bit involved...which keypad to use as a replacement depends on whether the current unit is wired or wireless. For wired, a 6150 or 6160 is appropriate, wireless perhaps a 5828 would be suitable...you might get a better answer by contacting Honeywell directly.
Jan 23, 2015 | Honeywell Home Security
How to get rid of FC on keypad
FC is for faliure to communicate. Need to check systems connection to monitoring station. Did anyone work on your phone line(s) or did you change your phone company or service? GL.
Mar 25, 2012 | Ademco 1 Ademco 6150 6150pl3 6150pl2...
How to get rid of FC on keyboard
FC is failure to communicate, to clear the keypad you need to get a signal to the central station where your being monitored, it will clear when the receiver acknowledges the signal
Mar 25, 2012 | Ademco 10) Ademco 6148 Keypad Fixed...
Security code program for ademco alarm 6150
6150 is the type of keypad you have the alarm system itself. The 6150 works on a number of different Honeywell panels. You need to locate the main metal box and open it. There should be a white sticker on the board with the panel type. (Ex. v10,v20, Vista...)
Oct 21, 2011 | Honeywell 5804 Ademco Wireless Security...
How to reset ademco after chanhing battery
You have to run a system test. enter your code then press 5. If that does not work try entering your code then press 5 then 0. it all depends on system type. let system test run for about 2-5 minutes it sould reset. Ademco 6150 6150pl3 6150pl2 these identify your keypad model not system type.check your control box to identify your panel. Sould be like Ademco vista 10, 20, 20p
Feb 18, 2011 | Ademco 1 Ademco 6150 6150pl3 6150pl2...
Display showing open circuit, how do i fix this?
One of the wires that connect to the same location as the Ademco 6150 Alarm Keypad + 5881enm Wireless are damaged. locate the bad wire and repair. Error will go away. GL.
Feb 17, 2011 | Honeywell Ademco 6150 Alarm Keypad +...
My lcd screen is blank and system doesn't respond to commands... Says ''not ready'' but that's it! There is power to the units but no response except a single beep after the pin and command is entered. It...
FYI 6150 is keypad model not alarm model. See if yhis helps. try pressing the " * " key bottom leftit thould then indicate zone trouble or fault. that sould give you at least some place to start.
Feb 07, 2010 | Honeywell 5804 Ademco Wireless Security...
Home Security Logo
29 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
