Question about Kitchen Ranges
The code UP appears where the temperature shows. What does this mean?
I have an error code of E94 on my intex portable spa what does it mean?
If alarm code E94 is displayed on the control panel, it means the water temperature is too low. If alarm code E94 appears, unplug and plug back in the GFCI/RCD and test the GFCI/RCD to restart the system when the spa water temperature is higher than 39?F (4?C).
Jan 25, 2016 | Intex Pool & Spa
Front load washer LG wm2140cw with error code up side down FE. Any ideas what this means? Will start to run then error code shows up and it stops.
A tE error code on the display of the washer indicates a heating error, usually caused by a faulty thermistor.
  1. Unplug the washer from the power outlet for 10 seconds.
  2. Plug the washer back in and press the POWER button and then the SPIN SPEED button until No Spin is selected. Press the START/PAUSE button.
  3. Once the washer has drained, restart the wash cycle.
  4. If the tE error code appears again, close the water taps and unplug the washer. The washer will require repair service.
Apr 06, 2015 | LG Washing Machines
My air conditioner want turn on or anthing and it shows e1, whats this mean
The E1 code is an error code that appears on the LED temperature display of some digital air conditioners. The error code could mean anything from dirty air filters to a damaged room thermistor, a safety connected to your thermostat that detects room temperature. Troubleshooting the cause of this error code may improve your air conditioner's performance
Sep 15, 2013 | Haier HWR06XC7 Air Conditioner
Need obd trouble codes & meanings
here r your trouble code meanings:
1) p0123-throttle position sensor circuit, high input.
2)p0117-engine coolant temperature circuit, low input.
3)p0118-engine coolant temperature ciurcuit , high input.
Jun 18, 2012 | 1997 Plymouth Breeze
It appear an C0511 code error on the display, I want to now how it mean, what's the problem hapen exactly in my machine (KONICA MINOLTA Di3510)
It means you have a low temperature in your fuser. This could be due to a faulty fuser or could just need settings adjusted to regulate the fuser temperature
May 02, 2011 | Office Equipment & Supplies
Error code on keypad EE L before screen went out. What does it mean.
Error code EE means temperature sensor issue. This error appears when the oven temperature turns bad or when a high temperature is detected by the sensor. Try and unplug the range for 1-2 hours and check if this clears the error. Hope this helps... Please post back if you need more information.
Apr 10, 2011 | Sharp Insight KB3425LK KB3425LW Electric...
My macbook air hardware test shows error code 4HDD/11/40000004: internal. What does that mean and how do i resolve the problem?
The meaning of Apple Hardware Test results is Apple proprietary.
That having been said, it appears that AHT is reporting a problem with a hardware component associated with your hard drive (the drive itself, a drive temperature sensor, or something else). An Apple Authorized Service Facility will be able to give you more information.
Jul 06, 2010 | Apple MacBook Air Mac Notebook
Kitchen aid wall oven Model YKEBS2780B1 SHOWS
Hello,4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock(ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock(ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3
May 26, 2010 | Ovens
My check engine light is on and I can't pass inspection because of this problem. The code that appears is po128. What exactly does that mean?
The generic code stands for Coolant Thermostat (the Coolant Temperature is below the thermostat regulating temperature) Need to replace thermostat according to that it is opening too soon.
May 06, 2010 | 2004 GMC Envoy
JENN-AIR MODEL D156B Electric oven
code f 0 means what?
Feb 11, 2008 | Cooktops
Kitchen Ranges Logo
22 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
