We have another tv that is connected to the antenna also and it works on that tv. Just the true tech with dis won't recieve a signal
SOURCE: acquiring signal only on display
I have had my Sportster 1 for over 3.5 years with never a problem About Mid May 2008, I saw the "aquiring signal" notice in the middle of my screen. Everything wlese was fine. I saw the channel #, the time, the 3 signal bars, the name of the channel, etc. Everything EXCEPT actually hearing it.
I called sirius and they say they didnt know what could be causing this. I am really surprised to see this many people having the same problem.
Anyway, I boughrt another Sportster 1 on E-bay for $49.99 and am waitingfor it to arrive. Hope it works.
Posted on Jun 07, 2008
Mike258
  • 1498 Answers
SOURCE: I have a dmr ez28
No, you are not obligated to pay for services not rendered or in this case no longer needed.
You will need to contact FixYa administration for the details about canceling the charges. They can be reached at:
premium.support@fixya.com
There may be continued responses to your posted problem until Monday morning when the offices are once again populated. Bear with them, the experts answering do not initially see what has transpired previous to their posts. When they do see, it's only the comments made by you that are visible.
Normally the responses stop when you accept an answer. In this case, that may complicate things. So, be patient and send them a message explaining the situation.
There will be no problem,
Best regards,
Mike
Posted on Dec 27, 2009
SOURCE: Lost video signal to monitor (TV)
I had the same problem - Onkyo had me reset the unit by holding down VCR and pushing the power button. Make sure you record your settings before doing this - as the unit will be fully reset. This solved the video problem for me.
Posted on Oct 04, 2010
BElectric
  • 1140 Answers
SOURCE: I am having trouble recieving over the air digital
I believe you have probably selected the wrong TV mode. It seems that you have set the TV to analog mode. It is common for the digital tuning option to be greyed out in analog mode and only becomes available in digital mode. Look for a button on your Sharp remote labelled "DTV" or "DIGITAL" and press this, then open the menu and try the digital setup again. If you don't have one of these buttons, look for a button labelled "INPUT" or "SOURCE" and look for an input or mode called digital or DTV.
I will check on the exact method for your TV and post back with the details shortly.
Regards,
BElectric.
Posted on Feb 10, 2011
  • 879 Answers
SOURCE: Why does my Trutech say NO SIGNAL no matter what I do?
Video processor section should be checked. Contact any technician.
Posted on Jun 14, 2012
Why is the TV not connecting to wifi?
BECAUSE WIFI IS FOR COMPUTER SIGNAL FOR INTERNET ONLY TV IS FOR MONITOR VIDEO SIGNAL AUDIO SIGNAL FROM ANTENNA CABLE SATELLITE BOX THROUGH TUNER TV TUNER CAN NOT RECIEVE WIFI
Oct 18, 2015 | Televison & Video
Jun 13, 2012 | Televison & Video
I have color on all but 1 TV station. That staion has color on other TV's in my house. Any sugestions?
Ur tvs in ur house it is getting a paid tvs incomming broadcasting tv signals like a cables or a satalites dishes companies?Yes,than that incomming broadcasting wire that plug into ur tv Ant. input port hole might have some kind of signals interference at that channel frequencies,call ur cables tvs or satalites tvs companies providers for an answers and get their field Tech. to come out and check it out.If all ur tvs in the house are analoge tvs and u are using a DTV signal through a DTV converter box to getting a Free over the air DTV air to recieving tv broadcasting tv channels stations only than tries it with another antenna signals sources like a better antenna design like a portable digital antena or good roof antenna should solved this problems.
Oct 03, 2011 | Philips Magnavox 20MS3442 20" TV
FM antenna is not providing reception, despite cable connected to powered antenna amplifier. TV also connected to powered antenna amplifier (splitter) works fine. FM mode produces only static. I purchased...
If I understand your setup, you've connected the receiver antenna terminal to the output of the antenna amplifier. If this is true, I'd suggest trying the receiver using a plain old FM dipole antenna (available at Radio Shack and other stores) or even just a piece of wire hooked to the antenna terminal. You should be able to pick up some local FM stations then.
What might be happening is that the FM is being filtered out by the amplifier. Some amps made mainly as a TV signal booster have an FM trap designed to block the FM broadcast band. In the analog broadcast days, the FM band was right near the sound part of a TV signal, and the trap was there to prevent interference. It may be filtering out your FM band.It may also be possible that you're just overloading the FM antenna input with the amplified signal. Sometimes a signal can be too strong. Using a simple wire antenna will let you test the receiver by itself.
Other than connecting an antenna you shouldn't have to do any setup for FM reception. If you still get no stations at all when using a simple antenna, then the receiver may need service. But I doubt Circuit City would have sold a floor model that was defective, even at the very end, unless it was clearly marked as such and sold "as-is". I'm pretty sure you'll find that the receiver works with an antenna made for FM.
Sep 14, 2011 | Denon DRA-37
I have a Sony KDL-V32XBR1. The turner seems to be having issues. If I scan for channels I only find a few but my other flat panel receives a full range of channel.
U are using a antenna to do a recieving for a Free AIR DTV incomming braoadcasting tv signal channels siganal?Yes.U are using two different tv antennas signals wright?The Sony one just require a stronger and a better antenna signal,not all flat LCD or Plama tvs recieve the same strenghth signals.Some tvs design require a strong or a very strong signals strenght to get all the tv Free AIR DTV braoadcasting tv channels.Buy a better tv antenna design like a Digital amtenna will solved this problems for the Sony tv.
Sep 11, 2011 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Just bought a house and moved in. I have plug the TV into the wall antenna socket and the TV comes up with the message 'weak or no signal' what could be the problem?
Hi, congratulation on your new house!
The problem is obviously from your antenna. The TV is not recieving any reception from the antenna and that is why it is displaying 'weak or no signal'.
Cross check your antenna connection and make sure the antenna wire is intact.
Also, most antenna's come with a booster. The booster makes reception from the antenna very strong and the TV would be clear.
Lastly, is this a new antenna or were you using it in your old house?
Please give me a feed back.
Yours sincerely.
Elect_Comp.
May 12, 2011 | Televison & Video
Do i need a converter box for my rca true flat 27 in? if not how do i connect a digatal antenna i have lost my manual
Your TV will require a Digital Converter Box to recieve over the air Digital Television Signals. You will need to hook up the antenna to the converter box and then hook your converter box to the TV. Hooking your television directly to a digital antenna will not get you Digital signals...only analog signals.
Jun 25, 2010 | RCA TruFlat 27F520T 27" TV
I have a message that says no signal o signal
your tv is working but your antenna or recieving device is not sending a strong signal to your set, try using a hd antenna or a dvd device maybe a cable reciever or similar, to see if your able to see a picture but usually its a signal problem not something wrong with your set.. hope this helps
Jun 03, 2010 | JVC LT-42X788 42 in. LCD HDTV
IS MY TV DIGITAL?
yes you will. either install an outside antenna or get a good amplified indoor antenna. try your old antenna first, but when your picture freezes or it says something like " weak signal " you will need that new antenna
Jan 24, 2009 | Sony KLV-S32A10 32 in. HD-Ready LCD...
No satellite
probably fried the lnb on the dish or the receiver itself
May 07, 2008 | TruTech PVS2119 19 in. LCD Television
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
