Question about Health & Beauty
Battery has full charge - no power any place on scooter -
  • Health & Beauty Master
  • 998 Answers
Hi u don't mention name or model of scooter ? .example on a pride scooter they an overload switch if tripped it will kill the power .I might have to ring a service center to find out if you're scooter has an overload switch.cheers.
Posted on May 16, 2017
I charge the battery and mark it's full charge,but on the scooter the indicator don't mark is full charge and when you drive,the speed just suddenly will drop and come back ok.
Charging batteries to full means leave on charge for 12 -16 hours as it may show charged but the charger goes into what is called a battery conditioning mode where a small trickle charge takes place to fully charge batteries. Again, how old are batteries and have you had them load tested at all?
Jun 15, 2015 | Drive Medical Health & Beauty
I have a pride ultrax and I have a full charge but no power
Hello,is the charger working properly & has the battery also been tested?.Sometimes the obvious can be the fault,but many people overlook it.I hope this has helped.
Jan 06, 2014 | Electric Mobility Mobility Electric Power...
Scooter won't move
Things to check: Drive/Free wheeling switch, brake release lever (this activates an internal micro-switch that enable power to the drive system, battery box connectors (condition of contacts - corroded, missing, loose. etc.); main control cable (corrosion. lose or missing pins, etc). If all these are OK, could be controller or drive control potentiometers (speed, forward, backward) on the handle-bar (tiller).
Aug 09, 2012 | Electric Mobility Merits Electric...
The scooter charges and shows full charge when started. Scooter will not drive uphill - certainly seems to lack torque - when driving up hill battery indicator drops to red
Either the hill is too steep of a grade/incline, the weight of the rider is more than the scooter is designed to carry, or the battery does not have enough power. If the batteries are old or have not been maintained properly, they may not be getting a deep solid charge that is needed to operate on hilly terrain. This is indicated when the batteries show a full charge, and then drop off quickly after a short period of use. Make sure that you are not exceeding the recommended weight limit for the scooter and that your batteries are less than 2 years old. Inclines of more than 5-6 degrees are typically not recommended for safe operation.
I hope this information is helpful to you, good luck!
Dec 27, 2010 | Electric Strider Mini 4 Wheel Mobility...
After a few seconds cooling fan stops and it doesn't charge.
This usually indicates that the battery is fully charged. Does the indicator light change? Have the batteries been sitting unused for a while? If so, they may have oxidized inside and will no longer take a charge. The charger is indicating they are full, but instead of being full of energy, they are full of crud and need to be replaced.
Nov 06, 2010 | Universal Power Group 24V 5A Universal...
Rascal scooter no forward or reverse or seat rise
Does the scooter have any power to it at all? Have you recently charged the batteries? If the scooter has been sitting unused for a while the batteries may not take a full charge and need to be replaced. If the batteries are good, check the fuses and all of the battery connections to ensure nothing has come lose. Sounds like a power issue.
Oct 17, 2010 | Electric Mobility Mobility Electric Power...
Shoprider cadiz scooter, batteries show full charge when first charged up but when driving scooter battery power runs out after about 3 miles. brakes work fine, no noises from motor or gearbox, what's...
I think your batteries haven`t been charged properly,or they have been left standing so the charge has leaked out.At a minimum your batteries need to be charged for 12 hrs a day for the first month if not they will not build the capacity and will dwindle and die for example it is at only 25% capacity,but looks like a fullcharge, it says it fully charged but will die
quickly this happens because it is charged to its full capacity but that is only 25% of the batteries true potential
resulting in short battery life.
Unfortunately majority of scooter batteries like this have to be newly replaced.
Nov 06, 2009 | Health & Beauty
Batteries are charged, scooter won't move, no power to display
It is impossible to overcharge with the Pride charger. When the battery is full, it will stop charging and check about oncew a miute to maintain the charge.
Now, when you plug in the key (looks like an audio headset jack) does the battery meter indicate a full charge? Also, the scooter will not move if its in free wheel mode, and it will not move if the charger is plugged in. Beyond these first steps, you will need a voltage meter to troubleshoot.
Jan 18, 2009 | Pride Mobility Products Go-Go Elite...
Health & Beauty Logo
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
