Question about Garden
Sprinkler sensor present in program as if the rain sensor is active but we don't have one. I switched back and forth the bypass button but it does solve it. cannot get manual active. solution??
  • Brad Brown May 15, 2017
    Hi peter ian, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Make and model number
  • 377 Answers
SOURCE: The manual in Utilitech self
You might find the correct information at this URL:
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/in-wall%20timers/st01c.aspx
Do a copy and paste in your browser and review for the information you are looking for.
Paul
Posted on Sep 18, 2010
jim4984
  • 797 Answers
SOURCE: ICC - 800 PL
Hi Greg,
It sounds like a wiring problem but ....... that is yet to be determined. I would check the output of the controller panel to the valve at the panel and then confirm that you also have voltage at the valve itself.
Good luck, Jim
Posted on Jul 20, 2011
cardenderek
  • 783 Answers
SOURCE: 2008 Chevrolet Crew Cab LTZ
Hello. I am sorry you are having this problem. This is an article that i have about rain sensors it is pretty neat.
http://static.howstuffworks.com/pdf/rain-sensor.pdf
Basically. The sensor sends out an infrared light that then detects YES how hard the rain is falling, and YES how much "condensation" , (rain) is on the windshield.. By its thickness the sensor can read... so if you have a tinted windshield, i do believe the sensor could have issues pushing the infrared light throught it and getting an accurate reading. I would say the factory is right in the case.. and that If the new winshield you have is not EXACTLY like the one you had before... It is the windshield repair guys that are responsible.
Note: even though they have tried to acquiese to your need by replacing sensors.. it has obviously not worked. and i would tell them they need to replace your windshield with the same kiind they took off. or give you your money back.
GOOD LUCK!
Please accept the add comments to reply or press accept solution. Please rate1-4 thumbs up and leave pos. feedback!
FixYa Premium Support
Posted on Aug 05, 2011
tayjoejoe
  • 2217 Answers
SOURCE: bypass security system
Yes, for your vehicle you will need to go to this link and look under PERMANENT FIX.
http://vatspasslockpasskeysecurityhelp.yolasite.com/
Posted on Dec 20, 2011
jsort01
  • 3 Answers
SOURCE: remote sensor on tv not responding
Have you checked your remote to see if its working? If you have a digital camera or camera phone, point the remote at the lense and see if it shows up on camera screen. If it is working then the IR sensor on the tv could be bad.
Posted on Jul 17, 2012
Testimonial: "Learned how to check remote -- Thanks much Jsort01 "
I need to disconnect the rain sensor from my sprinkler system. Can someone tell me how?
Without the make/model of your timer, it's hard to be specific. On my two systems, there are two screws clearly labeled for the rain sensor. Loosen those, pull the wires out. Done.
Jun 02, 2015 | Garden
Wiring new sprinkler timer one wire on my old
Just cut the common wire and put one end in each of the 2 pins. The rain sensor just interrupts the signal to the valves when wet.
Nov 04, 2013 | Orbit Underground 57896 6 Station In/Out...
Model# 57874
Copy following links to identify timer manual and general wiring illustration:
http://waterheatertimer.org/Woods-timers-and-manuals.html#sprinkler
http://waterheatertimer.org/images/orbit-connections.jpg
Do not connect voltage directly to COM and Pump terminals... these terminals have their own 24Volt AC output when timer turns ON. When timer turns on, the 24V flows to Relay. This action will cause electro-magnet to pull two points together, and that will turn on the pump.
Same with the sensor terminals. Do not connect power to rain sensor terminals. The rain sensor plugs into outlet, and produces it's own 24V ac output. So when rain sensor activates, this cuts power to timer, and then timer will automatically bypass the watering schedule until rain sensor again resumes power output to timer.
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jul 25, 2013 | Orbit Hardware & Accessories
What does COM. mean
Copy following links to identify timer manual:
Do not connect voltage to COM and Pump terminals... these terminals have 24Volt AC output when timer turns ON. When timer turns on, then 24V flows to Relay. This action causes electro-magnet to turn on the pump.
Also do not connect power to rain sensor terminals. The rain sensor plugs into outlet, and produces 24V ac output. When rain sensor activates, then timer will automatically bypass the watering schedule until rain sensor resumes power output to timer.
Gene
Jul 25, 2013 | Hardware & Accessories
Circuitry from fuse box (220v) to timer and to sprinkler pump 220v
Copy following link:
http://waterheatertimer.org/How-to-wire-Intermatic-sprinkler-timers.html
240Volt requires 2 hot wires, but not additional neutral wire. Just cap the neutral.
http://waterheatertimer.org/images/Inside-Main-Breaker-Box-12.jpg
http://waterheatertimer.org/See-inside-main-breaker-box.html
The rain sensor should have it's own power source (for example plug into outlet, or use 1 Hot and 1 Neutral to supply power to rain sensor), and then wires from rain sensor connect to two rain-sensor terminals located on timer.
Do not connect power directly the the rain sensor terminals.
Add a comment for followup.
Jun 29, 2013 | Hardware & Accessories
Can I connect a rain guage to a intermatic T8805P101C sprinkler clock?
1) Not directly to timer, because the T8805P101C 125Volt sprinkler/irrigation timer does not have additional wiring terminals for rain sensor.
2) Buy R8815P101 125Volt timer has additional terminals for sensor.
3) If you are good at wiring projects: Then you can wire rain sensor to 24Volt 8-pin relay, and have relay open and close power to pump or sprinkler head.
http://www.grainger.com/Grainger/DAYTON-Relay-1EGY5?Pid=search
http://waterheatertimer.org/images/Connect-relay-to-timer.jpg
4) Open following link for sprinkler timer resources:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#sprinkler
Add a comment for more help
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 16, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
How to wire hunter rain clik rain sensor to r8816p101c
1) There are different rain clik model numbers shown in manual
Open 24 volt Rain clik manual:
http://www.hunterindustries.com/resources/pdfs/instructions/domestic/lit358w.pdf
http://waterheatertimer.org/pdf/Hunter-rain-clik-instruction-manual.pdf
2) The rain sensor has two wires.
And two additional wires are needed to run from rain sensor to sprinkler timer. For example, buy thermostat wire from local hardware store if wire is not supplied.
3) The rain sensor has a terminal block where wires are connected. .
Open manual above to identify markings on your terminal block.
For example Figure 1 shows SRC model, and with this model number, the rain sensor wires connect to terminals RS and C, and then two wires going to timer connect to terminals RS and and 1.
4) R8816P101C is 208-240Volt 24-hour irrigation timer.
Timer has two separate terminals for attaching rain sensor.
5) Timer power connections have 4 terminals. Do not connect rain sensor to power terminals.
Connect wires from sensor to the two sensor terminals.
6) Timer slide-switch must be set to ON position for rain sensor operation.
Sensor sends continuous 24Volts to irrigation timer.
When it rains, the rain sensor stops sending 24Volts to timer. Timer responds by not turning on power to irrigation pump.
To by-pass rain sensor, move timer slide-switch to off position.
7) Open following link for Intermatic replacement parts:
8) Take a moment and rate answer:
Sep 05, 2011 | Intermatic R8816P101C -...
I have a intrermatic r8816p101c that some one removed need to put new one back dont know how i have 2 red wires coming from pump and to red wires coming of the wall witch has a on and off switch how do i...
You have Intermatic 240Volt sprinkler timer.
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/r8816p101c%20-%20english.ashx
Timer relay has 4 wiring terminals: from left to right 1 2 3 4
Red wires from switch connect to terminals 1 and 3
Red wires to pump connect to terminals 2 and 4
Since circuit is 240Volt, red wires from switch can be connected in either order. Same with pump.
Rain sensor terminals don't have any wires, unless you but separate rain sensor.
Parts:
Aug 10, 2011 | Intermatic Hardware & Accessories
How do you wire a Toro Rain Sensor 53769 to Intermatic Timer T8845PV
The rain sensor only connects to Intermatic sprinkler timer IF the timer has the rain sensor terminals.
Not all Intermatic sprinkler timers have that connection.
For example R8815P101C and R8816P101C have rain sensor terminals
I think the rain sensor terminals are located to the right of main wiring terminal block.
There are two screw terminals.
The rain sensor plugs into a power source, and then sensor wires connect to the timer.
Apply no voltage to the sprinkler timer terminals.
May 01, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
I have a Rainbird ISA 300/400 sprinkler system. It has a dual A& B program. I would like only program A to water. How do I deactiveate B?
All you have to do is set the program 'A B' switch to the 'A' position. The program that you have set for A will run only. B is not active.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Sep 03, 2009 | Rain Bird Hardware & Accessories
Garden Logo
24 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
