Question about Health & Beauty
Changing temperature scale - Health & Beauty
How to change from Celsius to fehrenheit
On the Celsius scale, the freezing and boiling points of water are exactly 100 degrees apart, thus the unit of the Fahrenheit scale, a degree Fahrenheit, is 5/9 of a degree Celsius. The Fahrenheit scale coincides with the Celsius scale at -40 °F, which is the same temperature as -40 °C.
Sep 11, 2017 | Cars & Trucks
Explain the different unit of temperature and give the relation between them
You have the Celsius Scale characterized by
Freezing Point of water :0 deg C
Boiling point of water : 100 deg C
The Fahrenheit Scale characterized by
Freezing Point of water :32 deg F
Boiling point of water : 212 deg F
If F is the value of a temperature on the Fahrenheit scale, the corresponding temperature on the Celsius scale is given by
C= (5/9)*(F-32)
If C is the value of a temperature on the Celsius scale, the corresponding temperature on the Fahrenheit scale is given by
F= 32 +(9/5)* C
Nov 25, 2013 | Computers & Internet
I would like to change my ThermoScan from Celsius to Fahrenheit but I am not sure what buttons to push to achieve this
Changing the temperature scale from F to C: - - Turn on the thermometer - If the unit is already on, make sure it is not in the memory mode - Press the ?/MEM button and keep it pressed. Then press and release the activation button to switch over to the "change temperature scale" mode. - By pressing the activation button again, the opposite scale will be activated. Each further pressing of the activation button rotates the measuring scale
May 06, 2011 | Braun IRT3020 Thermoscan Ear Thermometer
How do I change my Braun ear thermometer back to F from C
You did not provide a model number however the Instruction Manuals for the various Braun Thermometers can be found here:
http://braun.kaz.com/kaz/service/prodResult/
Not sure if this procedure is common to all but this may work otherwise find the manual specific to your model number.
This thermometer is shipped with the Celsius temperature scale activated. If you wish to switch to Fahrenheit ( °F), proceed as follows:
Turn on the thermometer. ( If it is already turned on, make sure it is not in memory mode.)
Press the /mem button and keep it pressed. Then press and release the activation button to switch over to the «change temperature scale» mode.
By pressing the activation button again, the Fahrenheit scale is activated, «°F» is displayed on the LCD. Each further pressing of the activation button toggles the scale between °C and °F.
Release the /mem button to return to the ready symbol . The temperature stored in memory will automatically be converted to the selected scale when displayed on the LCD.
Apr 24, 2011 | Braun Thermoscan Pro 4000 Ear Thermometer
Need to change the farenheit
Here is a link to the manual:
http://braun.kaz.com/files/IRT3020GB,%20F,%20E%20%28USA,%20CDN,%20MEX%29.pdf
Or just follow these steps:
• Turn on the thermometer.
(If it is already turned on, make sure it is not in memory mode.)
• Press the /mem button and keep it pressed. Then press and
• By pressing the activation button again, the Celsius scale is
activated, «°C» is displayed on the LCD. Each further pressing
• Release the /mem button to return to the ready symbol .
All temperatures stored in memory will automatically be converted
Mar 16, 2011 | Braun IRT3020 Thermoscan Ear Thermometer
How fo I change the degrees from C to F degree ?
Changing the temperature scale Your Braun ThermoScan is shipped with the Fahrenheit (°F) temperature scale activated. If you whish to switch to Celsius (°C) and/or back from Celsius to Fahrenheit, proceed as follows: (1) Make sure the thermometer is turned off. (2) Press and hold down the Start button (IRT 4020) or the «I/O» button (IRT 4520). After about 3 seconds the display will show this sequence: «°F» / «SET» / «°C» / «SET» ... (3) Release the Start button / «I/O» button when the desired temperature scale is shown. There will be a short beep to confirm the new setting, then the thermometer is turned off automatically.
Feb 10, 2011 | Braun IRT3020 Thermoscan Ear Thermometer
What are the parts of thermometer
glass tube, mercury or alcohol, and calibrated scale9k=
Nov 22, 2010 | Health & Beauty
Have a braun thermoscan and want to change it from F to C degrees lost manual
From the manual of the thermometer:
This thermometer is shipped with the Fahrenheit temperature scale activated. If you wish to switch to Celsius (°C), proceed as follows:
• Turn on the thermometer. (If it is already turned on, make sure it is not in memory mode.)
• Press the /mem button and keep it pressed. Then press and release the activation button to switch over to the «change temperature scale» mode.
• By pressing the activation button again, the Celsius scale is activated, «°C» is displayed on the LCD. Each further pressing of the activation button toggles the scale between °C and °F.
If this isn't the right manual, go to: http://braun.kaz.com/kaz/service and select your country from there.
May 16, 2010 | Health & Beauty
I just changed the battery and I keep getting the temperatures in Celsius instead of Fahren. How do I change it to F?
You need to discinnect the battery and reinstall it. When you reconnect the battery press the 'SET' button within 15 seconds. The temperature reading will now be set to Degrees F.
See below.
Setting/Changing ºC and ºF Temperature Scales
The food safety thermometer can display temperature in either the °C
(Celsius) or °F (Fahrenheit) scales. The desired scale is selected at the time
the battery is installed:
Selecting the °C Scale:
When the battery is connected to the battery leads the °C scale indicator
shows on the display for approximately 15 seconds. If the SET button is
not pressed the unit will time out and default to the °C or Celsius scale.
Selecting the °F Scale:
If the SET button is pressed within 15 seconds of connecting the battery to
the battery leads, the temperature scale display will toggle to the °F scale
indicator and the unit will now default to the °F or Fahrenheit scale
Feb 28, 2010 | Fluke Networks Fluke/Raytek FoodPro Plus...
Wash temperature scale
TEMPERATURE - CELSIUS OR FARENHEIT
If you want to change the temperature indication from Celsius (C) to Farenheit (F), proceed as follows:
Turn the main switch, off and turn it on again. Press the Enter button five times, then press the P2 button five times. These ten times must be completed within fifteen seconds. Within three seconds after pressing P2 the last time, use the < > buttons to select temperature indication.
Sep 22, 2008 | Asko W640
Health & Beauty Logo
24 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
