Question about GPS
Can i get a gpa map for normandy france - GPS
How can I download the update map for my system?
What kind of gpa you have?
Sep 11, 2015 | GPS
Settings to allow address on SD card
have you gone to the map information screen and put a check mark in the box next to the France map? This enables the map.
May 29, 2013 | Garmin Nuvi 350 Car GPS Receiver
How to input an address that is in France?
Many Garmin units have a menu item that shows a list of installed maps. The main map is usually located on the GPS's internal memory. Any additional is likely found on the SD card.
When you access the menu / setup and choose maps, you will see both maps. Make sure that you uncheck the map in the main memory (USA perhaps?) and check the map that holds the area you wish to use (Europe?).
When you view the maps on the GPS next time, you should see the maps for the selected area and be prompted for locations that make sense for that area. Simply reverse the steps above to get back to the main internal maps when you return.
I hope this helps!
The Schoot Ceran top on a Solitaire range has cracked through the left 2 elements. Can this be repaired? If so, where can I find a reapirer in Normandy, France?
You directed this question at me, but unfortunately this isn't my expertise and I am unable to provide you with a real solution at this time.
Hopefully one of other experts will be able to provide you with a real solution.
Thank you for using FixYa.
Jan 08, 2012 | Kitchen Ranges
I have borrowed a nuvi 660 Euro, will it navigate
You can zoom the map out and then use your finger to navigate the map to France. When you are hovering over France zoom into a city and see if there is any detailed coverage.
You can also go into the "Where to?" menu and select A point of interest category. Then click the near button at the bottom of the screen and choose a location in France. Then complete the search and you should see POI's for that area.
If it does not have France you can get it at a good price here. Garmin Europe Mapping
Have fun in France
Jul 14, 2010 | Garmin Nuvi 660 GPS Receiver
I need to update my blaupunkt lucca sat nav map and buy a map of France-Suggestions plz
Hi Iam in the same boat - need to up date uk and maps for France. Down loaded french maps last year on toan SD card but they now appear to have gone! Can buy a pre loaded card from tele maps but it £68!!!!
May 18, 2010 | Blaupunkt GPS
I bought my Tom Tom in Canada and I want to travel to France, I need maps for France try that address, cost you some money but you do have the map.
Mar 13, 2010 | Tomtom ONE 3rd Edition GPS
How to set up a garmin gps for hiking in france......what FORMAT and MAP DATUM should I use
do u have Map for France in ur Garmin system ?
where do u live right now are u going for hiking to france from US
let me know i can help u in this
May 02, 2009 | Garmin GPS
I think I have this crib, but not sure.
This crib isn't meant to convert to a toddler bed. Also, you should contact Delta ASAP because this crib was recalled!
Jan 07, 2008 | Delta Luv Normandy Crib
GPS Logo
21 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
