Question about Sharp Heating & Cooling
I have to replace my sharp ac filter model AF-80DX. Where can I buy it? Thanks.
4 Suggested Answers
bobotfel
  • 236 Answers
SOURCE: Sharp Air Conditioner. Model
If you set you r AC to FAN mode the unit will not cool, it only runs in the indoor but the outdoor will off. If you set to AUTO the unit will cool but the indoor blower will automatically run slower when the room is cool or attain the room temp. setting. If you set it to COOL the fan speed is fix depending on your setting and it also operate in cool.
Posted on Apr 24, 2008
  • 1033 Answers
SOURCE: RECEIVED SHARP AC MODEL AF-R509X,
Hello, the filter should be in the front of the unit as you mentioned, and there is only one. One thing you can do is measure the inlet air and the outlet air and find the differance between the two numbers. It should be between 15 and 20 degrees, if it is less than 15 then you have a low refrigerant charge or the evaporator coil is dirty and should be cleaned.
Posted on Apr 29, 2011
  • 4736 Answers
SOURCE: We need a replacement filter
Karen, even though your model has been discontinued, you can still get a washable filter replacement for you AC Unit. Most hardware stores and home improvement stores sell a washable, mesh filter kit, that can be cut to size to fit your unit and hundreds of others. You'll probably have enough left over to make two filters, if necessary
I hope this helped you and thanks for choosing FixYa.
Posted on Aug 01, 2011
How much Sharp AF-S120FX Air Conditioner?
The model number you listed has been discontinued by Sharp. So, getting an accurate retail price is difficult. I did see one online marked Clearance for $269.00. But be careful buying discontinued models, as the warranty may only for a short period of time. Also, customer ratings/opinions on this model, dating back to 2005, were not good.
Hope this helps you and thanks for choosing FixYa.
Aug 24, 2011 | Sharp AF-S120FX Air Conditioner
We need a replacement filter for our Sharp Air Conditioner Model AF - S60DX.
Aug 01, 2011 | Sharp AF-S60DX Air Conditioner
I have a Sharp Comfot Touch AC - AF-121208W that I inherited from my brother years ago. I do not see a "drain" but can see water inside the unit. How would I get the water out? I do not see...
The unit will have a small amoount of water in it just make certain that it is tilted tot he ouside to help it drain. check the filter and clean it while your at it . let me know
Jul 23, 2011 | Sharp Comfort Touch AF-R120EX Air...
We have an E1 code on our Sharp energy star model AF-S100FX air conditioner and the unit will shut off. What does the E1 code mean?
Display Codes:
E1-Automatic filter clean reminder.
Turn the air conditioner OFF and unplug it. NOTE: The air conditioner must be unplugged for the automatic filter clean timer to reset.
Clean the filter. See the Care and Cleaning section in your use&care manual. After cleaning, replace the filter and plug the air conditioner back in.
Jul 22, 2011 | Sharp AF-S100FX Comfort Touch Air...
Ac shuts off E1 error message
E1 Error Code -->> Clean Filter
Owners of Sharp air conditioner models AF-S60FX, AF-S80FX, AF-S85FX, and AF-R80FX may experience the following (highly annoying) issue. After 720 hours of fan operation, the error code E1 will appear on the seven segment LED temperature display. This error code is intended as a reminder for the user to clean the air filter. However, because the procedure outlined in the user manual does not clear this error code as indicated, and the appliance has a nonvolatile memory that cannot be reset by simply unplugging it, the user of the appliance will become mightily frustrated, standing in potentially sweltering heat watching the appliance repeatedly shut down in the midst of operation with the "E1" display flashing.
Believe it or not, that is what it does: if you unplug it to remove the "E1" code from the display, and plug it back in and re-start it, it will simply run for anywhere from a few minutes to a few hours, and then merrily shut down again with the same flashing "E1" code.
Many people at this point, having put the manual under the canary or some such, will simply return the unit and never buy another Sharp air conditioner. But for the tech-savvy and search-adept, I offer the following procedure to clear the nefarious E1 indication, and obtain another 720 hours of cooling bliss:
1. Power down the air conditioner using the "power" button on the front panel.
2. Unplug the air conditioner from the wall socket.
3. Hold the front panel "power" button down and plug the air conditioner in. Continue to hold the power button down as the machine goes through a brief test sequence (fan & compressor each come on briefly, etc). There is a "beep" sound at the end of the test sequence, and the machine will be off. At this point, you can release the power button.
4. Unplug the air conditioner.
5. Plug the air conditioner back in.
6. Congratulations! You should now be able to operate the air conditioner normally for another 720 hours, but only if you followed the instructions above exactly.
If you doubt the veracity of this information, or it does not work as expected, you can get it directly from the source at: 1-800-237-4277 (Sharp customer service line). You'll need to call between 7 AM and 7 PM US Central time, and have your model number and serial number ready.
May 28, 2011 | Sharp AF-S120FX Air Conditioner
RECEIVED SHARP AC MODEL AF-R509X, FEW YEARS AGO FROM FRIEND, NO MANUAL, LAST SUMMER IT SAID TO CHANGE FILTER, I THOUGHT THIS WAS IN THE FRONT BUT IT WAS CLEAN, HOW MANY FILTERS ARE NEEDED OR IS THERE...
Apr 28, 2011 | Sharp AF-R509X Air Conditioner
We have had our 12000 BTU sharp ac for about 10 years now. The unit seems to be working but is not cooling the room that well. How do I know if its the compressor or it just needs coolant? If it isn't...
Remove the unit and clean the evaporator coils and the condenser coils with a good coil cleaner chemical.
Oil the fan motor bearings.
Replace the capacitor.
Jun 27, 2010 | Sharp Comfort Touch AF-R120EX Air...
Heating & Cooling Logo
22 people viewed this question
Top Sharp Heating & Cooling Experts
AJMAL KHAN
Tim Whalen
Brandon Berry
Brandon Berry
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
