Question about Home
What does a Ridgeway curio wall clock model 792 weigh? im trying to find a way to hang it on the wall/what type of nail/screws
3 Suggested Answers
  • 4090 Answers
SOURCE: I'm trying to hang my 55
I am confused here!
if the studs (vertical parts of frams) are 40" apart and the noggins ( spreaders are say every 20" )
Why are you trying to find them at 16 and 24?
Is there some cultural labnguage difference here about what a stud is?
An alternate fix rather than 100 holes in the wall is to use butterfly bolts ( expander bolts) these can hold up to 150Kg in any veneer wall
If nescessary drill extra holes in the frame of the TV haqnging frame4 to add more expande4r bolts into the wall
Posted on Sep 07, 2009
cynthiamason
  • 4 Answers
SOURCE: how can i hang a coat rack with no nails the nails wont go in to wall wear i want it
You my need to use very sticky glue.
Posted on Dec 31, 2014
Tip
Sheet rock on nine foot walls made easier
if you find yourself hanging nine foot walls with fiftyfour inch rock and the walls are
wooden framing, most have two boards running horizontal along the top. tap five
or six drywall nails along the top of the sheet were they will catch that top plate
and forget the screw gun save your back . use both hands get the sheet in place,
stay in tight with the sheet draw your hammer from your belt and tap in the prestarted nails.Three nails is enough to hold it if they are driven properly. But get
some screws in it asap. seems to save on my back hope it helps yours. Also works
well with two people as well.
on May 17, 2015 | PrimeSource Gypsum Board To Wood Stud...
Where can I get information and pendulum for Ridgeway spring driven clock serial number 374221?
You need to determine what type of movement it is first. Ridgeway used movements from Hermle and other manufacturers. Once you have identified the movement we can sort out the pendulum. The following article will show you how to determine the pendulum length: How To Determine Clocks Pendulum Length
Tim
UsedClockParts.com
May 03, 2016 | Home
It wont chime on the hour
Basic assumption... The chimes know what time it is...!!
FORCE NOTHING...!!
From page 10 of owners manual below (MINUTES):
EXAMPLE: Clock chimes at 1:10 but should chime at 1:15.
Step 1: When clock chimes at 1:10 stop the pendulum and record the time of 1:10.
Step 2: Carefully remove the small nut....
(Hour procedure is on the SAME PAGE (10).
WARRANTY INSTRUCTION MANUALS
Apr 19, 2016 | RIDGEWAY GRANDFATHER CLOCKS Ridgeway...
How do I fix the westminster chimes on my grandfather clock
Grandfather Clocks Manual - theclockdepot
www.theclockdepot.com/grandfather_clocks_manual.html
Howard Miller Grandfather Clock Manual by The Clock Depot offering discountGrandfather Clocks. ... The movement controls the hour strike, time keeping, andchime. ..... the hour without the Westminster melody if the other Westminster melody lever is turned to Silent. .... My Grandfather Clock has Stopped, Can I Fix It?
Owner's Manual - Master Clock Repair
www.masterclockrepair.com/ownersmanual.html
Note: The following information will apply to almost all grandfather clocks made after ...(See my article on Clock Myths) It is best if the chains are not pulled so far that the top of .... Some play the Westminster chime only and cannot be changed.
Nov 23, 2015 | RIDGEWAY GRANDFATHER CLOCKS Ridgeway...
How do you properly hang a mirror in a bathroom on a wall?
1. You should determine where you want the mirror to hang.
2. Make a small, light pencil mark on the wall immediately above the top and center of the mirror.
3. Determine if there is a stud at that location - or is close enough to still be an acceptable location for the mirror. If so, check the back of the mirror and got to step 4 - otherwise skip to step 8.
4. Measure from the top of the mirror to the hook, hanger or high spot of a wire if one is provided running from side to side.
5. Make a mark that is the same distance DOWN from the original mark on the wall.
6. Drive a nail or screw into the wall at the lower mark. Be sure that the nail or screw is long enough to get into the wood stud by at least 1-1/2" or more. Heavy mirrors should have heavy duty nails / screws that go deeper into the wooden stud.
7. Hang the mirror, erase visible marks - Done!
If there is no stud near the desired center location on the wall for the mirror,
8. You'll need to stretch and secure a wire between the left and right-most edges of the mirror - but the left and right-most edges should be at least 16" apart for this to work.
9. Project the mark you made in step 2 onto the closest stud to the left and to the right that you can locate These shouldn't be more than 16" from each other. Measure from the floor up or ceiling down to both of these marks to be sure both are the same height.
10. Perform step 4.
11. Perform steps 5 and 6 for each the two new marks you made in step 9.
12. Perform step 7.
Nov 03, 2015 | Home
Glass shelf
http://www.theclockdepot.com/information_request_form.html
email customer service at the clock depot, they can send parts for this grandfather clock
Feb 18, 2013 | Howard Miller Majestic Curio Grandfather...
Trying to mount a heavy piece of flat art on the wall, aproximately 72" x 48" and weighing 200 pounds. Trying to find a compatible hanging system
You need to know what the wall is made of - brick, block, concrete, plaster board, etc? Then go to a DIY store and ask - they'll advise you. If its an internal plaster-board wall then I doubt it will be strong enough. A while ago I hung a 4' x 3'6" mirror on a block wall using two fairly heavy duty rawl bolts and its still hanging.
Mar 06, 2012 | Televison & Video
Microwave installation under cabinet, no rear wall
Your model weighs 41 pounds empty.
That - plus maybe adding another 8-10 pounds for safety - us what your installation needs to be able to handle.
I would think the average cabinet could handle that, but it may be better to add a small steel plate or large washer surrounding the mounting screws to help disperse the weight load.
The owner's manual describes the installation kit you can use to mount it in a cabinet or in the wall, etc. That may be helpful.
If you don't still have your manual you can download it here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 17, 2008 | Sharp R-408HS Microwave Oven
Home Logo
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
