Why do i have a large line at the top and bottom of the tv
    Master:
  • 595 Answers
This is caused by aspect ratio. To change you have to go into set up and alter the ratio shown as 9:16 , not sure what ratio you will have . Note som tv's have an auto chaning aspect ration for films ect.
Posted on May 14, 2017
Replaced primer bulb and fuel lines, now it won't stay running
The smaller line is the supply to the carb. and should have the filter in the tank, with sufficient length to allow fuel pickup from the bottom of the tank.The larger line returns excess fuel and pressure to the top of the tank.By squeezing the bulb and watching the fuel lines you will be able to determine if you have them right on the carb.
Sep 27, 2009 | Poulan Featherlite Gas Blower, with Low...
Projection HDTV Pansonic 47" Curving blue and green colors on top and bottom of screen.
You will need to replace your two convergence I.C.s.They are two large IC mounted on a large aluminum heat sink.Replace both,look for any burned resistors near them,replace those if needed,and readjust your convergence. Good Luck
Let me know if you need any further help
Mar 29, 2008 | Panasonic PT-47WX42 47" Rear Projection...
Black vertical line on p42w34p plasma
The plasma display screen is made of a matrix of elements connected to cables along the side and top. On your unit, some of these many, tiny connections are making contact intermittantly thus losing the elements in that area. These contacts are held in place with just pressure and if that is disturbed, you lose that line of elements. Try squeezing the cabinet of the TV on the outside at the top in the area of the loss and see if that makes a difference. May have to go inside and see if the contact assembly is disturbed or warped or something.
Dec 31, 2007 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
My large screen projector type tv has a picture but there is groups of lined running across the screen from top to bottom. audio fine.
Sounds like hum bars if there white bars.Try disconnecting the ground outside at your cable hookups or sat etc.
Sep 17, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Vertical black line on PPM50M5HBX firmware version SA01
You will not like the answer which is likely caused by one of two things - either something internal that drives that line in the display has gone bad, or somehow, someone hit the display and that has caused the line to appear.
Had this happen on one of the wards in a hospital I work at - patient backed into the TV and hit the screen with his elbow - nothing visibly wrong until you turned on the TV
-this one had a bright red line top to bottom
- There is a product out there that may be a potential consideration called TV Armour or TV Armor and it is meant to cover the face of the TV with a large totally viewable through plastic sheet that belts onto the TV
Oct 14, 2017 | Samsung PPM50M5H 50 in. Plasma Television
Poulan 2150 fuel line routing wt324 carb
the large hose from the tank goes to the suction side of the primer bulb. The large line from the out put side of the bulb goes to the bottom inlet of the carb.
the small line goes from the top outlet tube on the carb back into the tank near the primer bulb.
Mar 25, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
60PW9363 60" philips tv
Convergence issue = IC's need to be replaced.....
If you are doing this repair yourself = remove back...locate
large heatsinks with STK392-110 or 120 IC's..let me know.T.
Dec 13, 2007 | Philips 32PW9308 32" TV
Black line
Dec 11, 2007 | Samsung HP-R4262 42 in. Plasma Television
Large black line top to bottom
Oct 26, 2007 | Samsung HP-R4262 42 in. Plasma Television
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
