Question about Tower Dryers
Hawaiian Breeze tower fan model FZ10-10N. How do I disassemble and clean?
3 Suggested Answers
  • 8 Answers
SOURCE: How do I clean a
All Equipments has a provisions for servicing even for cleaning only.
Posted on Jun 19, 2011
SOURCE: How do I clean a Hawaiian Breeze tower fan?
Unplug fan. Lay the fan face down. Remove the four screws holding the stand to the base. Slide the stand all the way off the cord. Look at bottom of fan and find the small half circle indent just to left of center. There is a screw there, remove it. Go to the hand grip at the top of the back and pry out the two white rubber plugs to reveal two more screws, remove them. Back cover can now slide downward. May take a little squeezing at the center of the grille where internal clip is. Remove two screws at top of squirrel cage. Turn squirrel cage and loosen screw at bottom collar on motor shaft. Tilt the top of the squirrel cage outward slightly and slide upward to remove the squirrel cage. You can slip upper metal bracket off and set aside. Motor is held in by two screws, remove them and flip motor out of the way. There are two screws below where motor sat that hold in base of front grille, remove. Front grille has a series of clips along edges, carefully pry them inward from bottom to top and push grille gently outwards. You can now clean the rear grille, front grille and squirrel cage in warm soapy water and allow to dry. While they are drying, use a vacuum and dust rags to clean interior. When parts are dry, reinstall front grille and reinstall 2 screws. Reinstall motor with two screws. Turn motor shaft so flat notch is pointing up. Recommend to spray a tiny bit of WD-40 or a tiny dab of moly grease on shaft at top of squirrel cage, then replace upper bearing bracket on top shaft. Slide collar end of squirrel cage onto motor shaft and align screw with shaft flat and tighten. Reinstall two screws at bracket at top of squirrel cage. Align back cover just a bit toward bottom, then slide upward and clips will snap into place. Reinstall two screws in hand hold area, then reinstall screw at bottom of cover at half circle notch. You'll need either a magnetic tip screwdriver or a pair of long needle-nosed pliers to get screw in hole before tightening. Feed cord back through base and reinstall 4 screws. It took me about half an hour to do this whole process on each of my two Hawaiian Breeze fans, but they now look brand new and run very quiet.
Posted on Jul 04, 2011
I have this fan and unfortunately don't have a legend for the 5 buttons on top and what they do. is there a manual somewhere that tells me what each button does?
Hello, Chris -
I believe the Hawaiian Breeze tower oscillating fan operates much like the Aloha Breeze oscillating tower fan. I found an image for Aloha Breeze oscillating tower fan buttons, along with descriptions of what each button does.
I am not sure if the buttons on your fan are in a horizontal curve or a vertical alignment. However the attached image should help you figure out what the buttons on your fan represent.
Tower Oscillating Fan Buttons
1. Power - On / Off
2. Speed: slow, medium, fast
3. Timer: May be 15 levels; 1 / 2 hour setting for each timer level; Each touch of the button adds 1 / 2 hour of running time
4. Oscillation: Stop / Start fan oscillation
5. "Wind": Normal, Natural, Sleeping
http://www.fixya.com/support/t10019057-fan_will_not_start_lost
May 01, 2018 | Tower Dryers
Where can I find replacement mister nozzles for a Hawaiian Breeze misting fan
They are not available Debbie. What is wrong with the ones in yours? If they are clogged you can clean them with CLR or white vinegar. Or set up a patio misting nozzle in front of it.
Patio misting nozzles are readily available. Your fan is discontinued.
http://www.bing.com/search?q=+Hawaiian+Breeze+misting+fan+nozzles&qs=n&form=QBRE&pq=hawaiian+breeze+misting+fan&sc=0-27&sp=-1&sk=&cvid=EBB007E7ED6D49A6BD8E6A22CCCC31E0
Jul 09, 2016 | Dryers
My hawaiian breeze 16" fan isn't working properly.
try wedging a paper clip in between to hold the gaurd in place.
Jun 17, 2013 | Cars & Trucks
Jun 18, 2011 | Tower Aloha Breeze Fan
Aug 05, 2010 | Tower Aloha Breeze Fan
How to dissamble to clean aloha breeze tower fan model 87001
I just used an air air compressor with a soft rubber tip and went at my two tower fans outside. It took maybe 10 minutes shooting air in from many different points but both fans now work as good as new. If it's been a couple of seasons like mine you'll be amazed at how much blows out.
May 14, 2010 | Tower Aloha Breeze Fan
Opening tower fan to allow cleaning
how do you disassemble it to be able to clean it
Sep 22, 2008 | Dryers
Aloha breeze tower fan model fz25-50d (84001)
How to take apart the MODEL FZ25-50D[84001] INSTRUCTIONS ARE NEEDED
PLEASE EMAIL BACK WITH INSTRUCTIONS
TO val_bella49@yahoo.ca
Jul 14, 2008 | Tower Aloha Breeze Fan
Dryers Logo
75 people viewed this question
Top Tower Dryers Experts
Jay Finke
Jay Finke
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Tower Dryer Expert? Answer questions, earn points and help others
