Question about Viking VGIC485-6G Gas Kitchen Range
Mine doesn't reach temperature either, it starts and gets warm but can barely get to 350 degrees. It make "puff" sounds like it keeps lighting and then relighting.
  • 636 Answers
Sounds like the thermal coupler is shot
Posted on Jul 25, 2009
Oven doesn't reach desired temperature although it reads it on the display.
IT SOUNDS LIKE THE THURMOSTATE SENCER IS NOT WORKING PROPER AND SHOULD BE LOOKED AT BY A PRO.
Mar 30, 2014 | GE Profile Spectra JGBP90 Gas Kitchen...
Frigidaire FPEF3081MF Electric Range - oven doesn't heat up properly
It sounds like the heating coil is bad - find your manual and see how to remove the coil, and take it with you to a real appliance store and ask then to check the coil. If its bad, they should be able to get you a new coil.
Nov 14, 2013 | Kitchen Ranges
Fryer overflows often, turned thermostat down from 350 to approx 340 but food does not cook then. could the thermostat be bad? 10 degrees should not make that much difference.
Does the fryer have a" temperature reached light"? If so switch the fryer on and with the thermostat dial starting at its lowest setting increase the temperature setting in small increments. When the light indicates temperature reached, increase the thermostat dial temperature. Continue until maximum temperature reached.
If (starting from cold) the temerature reached light only shows when high up on the thermostats temperature scale, then unfortunately the thermostat needs replacing.
Hope this helps.
Mar 04, 2011 | Dean D50G-C Deep Fryer
Oven shuts down before reaching correct temperature
You will need to check the oven calibration using a thermocouple based thermometer(the one you stick in the oven is not reliable). Electric ovens should keep a near constant tempature so if you have it set to 350 the oven should stay around 350 once temp is reached. Now gas ovens are a little different. Most use a on/off thermostat and that means the temp can vary from 320 degrees to 370 degrees to keep an average tempature of 350. So if it is a gas oven you will need to let it warm-up for 10 minutes then start taking the lowest and highest 5 consectutive readings. Then add the 5 reads together and then divide the number by 5 and it should be within 10 degrees of the set tempature. If it is off by more than 50 degrees then you might not be able to get it back to proper calibration. The calibration methods are different for each range and depend on the type of thermostat you have digital(push button controls) or manual(knob). The owner's manual for your range might contain the instructions or consult the manufacture's website for the instructions.
Dec 21, 2009 | Whirlpool Ovens
When truck gets warm it will not run over 45 mph
Puffing white smoke is a sign of a blown head gasket. Coolant is getting into the cylinders.
Feb 17, 2009 | 1999 Ford F350 Regular Cab
My Kitchen Aid Supuerba top covection oven will heat to set temp 350-400 then drop over 100 degree's but still read on digital display 350 or 400
how do you know it is dropping 100 degrees ?
If the set temperature is 350-400 the heaters will work untill the thermostat will read that the temperature is reached - after that the heaters will shut down and the temperature will drop...and after few minutes when the temperature goes below thw set point (in this case 350-400) the heaters will turn on again - this will happen for the duration of the timing you have selected (example 45 minutes)
Oct 04, 2008 | KitchenAid Kitchen Ranges
Oven only reaches temp of 220 degrees.
meter the electric-220 metering the positives...110 metering 1 positive & ground at a time...Ohm the element if shows open(10 dollar multimeter doesn't move) then is bad.Can be reached from the back just above where the power attaches,for safety disconect the power
Jul 22, 2008 | Maytag 30 in. Electric Single Wall Oven...
Oven does not maintain temperature. Part 2
sometimes when they get hot that is when they fail
Sep 18, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Spectra XL Oven does not maintain oven temperature
I have the exact problem. We had the ignitor replaced 2 already and it works for 18 months and stops. Occasionally, it the oven won't even start to heat. I am ready to throw it out.
Sep 14, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Viking VGIC485-6G Gas Kitchen Range Logo
248 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
paulcarew
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
