Question about Garden
I got a Huskee (MDT) riding Lawn mower. I tried it out before loading it on a trailer to move it about 75 miles. I had a couple of men unload and I didn't watch them to see if maybe they did someting wrong. NOW once it is unloaded and let sit overnight I can't get the tracktor to move forward or backward.
  • curtis_rothe Jul 25, 2009
    I have a Huskee (MDT) riding Lawn mower. I tried it out before loading it on a trailer to move it about 75 miles. I had a couple of men unload and I didn't watch them to see if maybe they did someting wrong. NOW once it is unloaded and let sit overnight, I can't get the mower to move forward. I don't have a manual.
    President:
  • 2,559 Answers
Raise the seat and slide the freewheel engagement back to the correct position
Posted on Jul 25, 2009
  • 3,037 Answers
I am assuming that the lawnmower will start and run but that you are just not moving since you didn't indicate differently. As long as the parking brake is off (I'd bet it is if they were moving it, but get a quick look anyway) .You then probably need to reengage the drivetrain. They disengaged it while moving it most likely to be able to push it around easier to where you wanted it put. Look for a small lever on the lawnmower or look in your manual real quick as I don't know exactly what model you have and reengage it. Let me know how this turns out.
Benjamin
DIAGRAM OD DRIVE BELT ON 46 INCH CUT HUSKEE MOWER
You will need the model number to find this info. Usually on a plate or sticker under the seat. The use a parts site like jackssmallengines.com or simply Google your make and model followed by "deck belt"
Oct 07, 2016 | Huskee Tractor Replacement Riding Lawn...
Trying to locate a 1997 huskee carburetor and inlet manifold
on the front of the engine under a cover should be a fuel line going to it may have to take the left fender of to get in there
Oct 31, 2013 | Huskee Tractor Replacement Riding Lawn...
HUSKEE SHIFT ON THE GO LAWN MOWER WONT MOVE
Sounds like a pulley key is missing. That will cause the pulley to spin on the shaft without the shaft turning.
Jun 19, 2013 | Garden
Huskee LT 4200 Won't Turn Over
Remove spark plug. Then try it. Sometimes filled with gas.
May 28, 2013 | Garden
Huskee Riding Mower wont start
Try rotating the engine manually to check for any binding. I would also check the amp draw on the starter.
May 21, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Huskee 42 inch drive belt
does anybody know what kind of drive belt a huskee 24 horse 42 deck takes?
Aug 15, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Can't get riding mower to move
try this site it is called manuals online.
Jul 25, 2009 | Garden
Wont go and screeches when letting off clutch/brake
Take off the shift plate between you legs, put it in nuetral, crank up the engine, put speed lever in high gear and slowly let off on the clutch. Everything will work as if in gear, it just won't move. you should be able to see what the problem is. Which belt did you replace and why? Watch the varible speed pulley (the one both belts go around). The bearings may be bad in it and not letting it turn, thus, smoking the front belt.
Jun 29, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Dies when clutch disengaged
It sounds like the seat switch is disconnected or failed. Check it out. If it thinks there is no **** on the seat it will cause your symptoms.
May 25, 2009 | John Deere Garden
Garden Logo
51 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
