Question about Car Audio & Video
Getting an ER MESSAGE on a KAC 811 D amplifier what does this mean
5 Suggested Answers
SOURCE: lg fridge bottom freezer
freezer fan failed
Posted on Dec 08, 2007
  • 72 Answers
SOURCE: What does message: Er FF mean?
That means the freezer fan is blocked, you need to order a new High voltage board, the ice has built up enough from not defrosting that it is interfering with the operation of the evaporator fan.
Posted on Jun 22, 2009
blueextc3221
  • 15935 Answers
SOURCE: Help....kenmore trio refrigerator, error message "er co"
The Er Co error code signifies a communication error between the display control board on the freezer door and the main power board on the outer back panel of the refrigerator.
Check the wiring and connections between the low voltage interface and the main high voltage board.
If you are able to unplug the refrigerator and remove the cover over the control board on the back of the refrigerator,
you can check the wiring connection on the main control board.
If this wiring connection is okay, check the wire harness connection under the hinge cover on the top of the left hand refrigerator door.
If these connections are okay, then you will need access the wire harness connection in the dispenser.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 25, 2010
  • 230 Answers
SOURCE: I'M GETTING ERROR MESSAGE "ER IF"
Form what I have read up on it appears that the only fix is the mother board. It is not communicating properley and needs to be replaced. Good luck
Posted on Sep 09, 2012
If my long blue flashes on my amp when my subs hit what does that mean?
It;s not getting enough power. Seriously consider getting at least a 1 farad capacitor. It stores power for when the sub hits and recharges in between. I posted a tip explaining it in layman's terms if you look at my tips for more clarification. Please rate my assistance and leave a testimonial.
Jan 06, 2011 | Kenwood KAC-7204 Car Audio Amplifier
What size amp is the kenwood KAC-9103d amp
im not sure what you mean by what size amp....whether you mean physical size or wattage (power) so I have provided a website link for all the specifications that you require..........
http://my.kenwood.com/Car_Entertainment/Power_Amplifiers/KAC-9103D
PLease vote if you liked this response....
Aug 20, 2010 | Kenwood KAC-9103D Car Audio Amplifier
KAC-8104D Car Audio Amplifier: Fuse keeps blowing why...
Most likely a bad ground connection, clean up where the ground is connected to the vehicle, check the power wire connections too, if that doesn't help route the ground wire to either the chassis or the battery to get a lot better connection, also possibly if you have the amp on full gain (max power) it may be getting a surge from your vehicle which means turn to down a little or get a capacitor.
May 16, 2010 | Kenwood KAC-8104D Car Audio Amplifier
My subs/amp are not working
when you car is running, it charges the battery somewhat. So the voltage problem is not a problem. The red light means the amp is going into ''Protect Mode". This usually happens when something is wrong with the amp. Usually the amp is getting hot. Check all of you connectiong and check the final impedance of the subs. Make sure the amp can handle the impedance of the subs. If you need anymore help, message me.
Feb 12, 2010 | Kenwood Excelon KAC-X621 Car Audio...
My kac-x811d shows a message "E-03" upon connecting the remote wire.
According to the Manual for the KAC-X811D, E-03 indicates that there is a short curcuit in the speaker wires.
Check that you dont have a short on the wires and also check your speakers.
Try disconnecting the speakers and the wires and then swith it on.
If it comes on without showing the error then connect the wires and speakers 1 at a time
Oct 20, 2009 | Kenwood Excelon KAC-X811D Car Audio...
Red Light
that means you probably have a shorted speaker wire, a bad speaker or the amp itself is bad, try disconnecting the speakers one at a time and see if it turns on or not. if the red light stays on with no speakers hooked up it means the amp is bad
May 30, 2009 | Kenwood KAC-7252 Car Audio Amplifier
Kenwood Excelon KAC-X521
According to page 7 of the radio's manual, E-02 means the amp has failed and DC is being applied to the speakers. It also says "Turn the POWER switch "OFF" and release the protection."
Feb 09, 2008 | Kenwood Excelon KAC-X521 Car Audio...
Kenwood KAC-PS201T
The first thing you must do is to confirm that you have voltage at the amp. Just because the fuses look good, that doesn't mean you're getting power to the amp.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Jan 21, 2008 | Kenwood KAC-X201T Car Audio Amplifier
Kenwood KAC-6202 power
check all of your connections . Make sure you have a good solid ground
Apr 20, 2007 | Kenwood KAC-6202 Car Audio Amplifier
Car Audio & Video Logo
26 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
