Question about Coffee Makers & Espresso Machines
How do you turn off the auto start. I have tried every option that I can find and have read the manual. Set the auto brew time and let it cycle with just water.
SOURCE: B60 is not operating properly
I had the same problem and it turned out to be the pressure safety kicking in. The bottom hole didn't punch through on the K-cup. Check to make sure that is not the problem.
Posted on Dec 13, 2007
techman
  • 3130 Answers
SOURCE: Lost the Manual & can't tune digital channels, option not available on menu ?
Here is a link where you can down load a free copy of your customer user manual. Good Luck
http://esupport.sony.com/US/perl/model-documents.pl?mdl=KV32FS120&LOC=3
Posted on Feb 03, 2008
SOURCE: Won't brew a full pot.
well I hope this helps some, i was having a similar problem with my brewstation and decided to take it apart ( why not, it's already broken! ) this machine has seen a year of very heavy use and I could not bring myself to just throw it away. It would take forever to brew and I would have to turn it off and on several times to brew a full pot. I unplugged the machine, emptied out the water and turned it on it's back. Remove the 4 phillipshead screws and the two torx screws from the bottom ( if you dont have torx handy like me just gently pry the two halves apart till the screws pull through- after you have removed the phillips heads!) at this point the bottom will just come right off, no special tricks. You will now see a horseshoe shaped aluminum tube with orange silicone tubes at either ends of it, this is the heatime element. slide the small hose clamps back away from the element on the hoses and pull the hoses off both sides of the element end only, this will require a little elbow grease to do. Now carefully remove the two phillips screws securing the heating element to the maker BE OBSERVANT AS TO HOW THE WASHERS AND SPACERS ARE SECURED and remove them. To give yourself a little room for the element to come further out of the machine also remove the wiring clamp from the inside, it is a white half "c" plastic piece with 2 screws holding it, it is securing about 7 wires down with wire nuts on them. Once this is removed it will give you enough play to pull the heating element several inches away from the machine, do so. Now look inside the tubes of the element and you should see one side looks clear and clean and the other end is probably going to be clogged solid with tan colored gunk, the water could not pass through!. I took a piece of metal coat hangar (all i had around at the time) and bent it to the conture of the element and used it to **** out the element, uncloging it. this takes a little time because the buildup is very hard to break up. Once that is done carefully wash out the element getting all the build up that was broken up out, CLEAN IT GOOD!. The next step is to dry the exterior and make sure all the wiring is dry, try not to wet the wires at the wiring nuts or it may short out. Now re assemble the machine, run cleaner through and enjoy a cup of coffee !!
Posted on Oct 13, 2008
cactus bob
  • 267 Answers
SOURCE: delay brew will no longer work.
electronics and steam do not mix mr coffee used to put the control boards under the front where it was warm and dry . now there right where the steam can ruin them ... you might try unpluging it and puting it in the sunlight for a day and see if it drys out another thing go to amazon find your model and make a review , this will help others not to make the same mistake you did BTW just so you know , you dont have a real mr coffee , sunbeam bought them a few years back and now its just china junk .... good luck ......please rate this answer if it helped, 3 or 4 stars .and keep me in the paid department . a 1 or 2 will knock me off the air . thanks
Posted on Mar 01, 2009
SOURCE: 162-System Options Not Set; 163-Time & Date Not Set
I DO IT BUT IT STILL BE THE SAME
Posted on Feb 23, 2010
Breville you brew auto start not working
There is an error in the manual. Following the directions will, as you discovered, start brewing immediately.
To complete the auto-start programming, in step 8 of "Programming Auto-Start" you should NOT "press the PROGRAM button."
Instead, as soon as you have set the desired minute of the Start Time (step 7 in the manual), press the START / CANCEL button.
The LCD screen will then dim and display 'PROGRAM ON' to indicate that the Auto-Start feature has been successfully turned on.
Hope this helps.
- Owen.
Sep 13, 2012 | Breville You Brew - Single and Carafe...
How do I program the stay or go coffee maker to turn on at a certain time, I worked the past few evenings, but the green light will not come on, I did have trouble the other times also
To Program Automatic Brew
1. Make sure clock is set for correct
time of day.
2. Press PROG button and digits will
flash.
3. Press H and M buttons until desired
brewing time is reached.
4. Press PROG button to confirm setting.
Digits will stop flashing and
return to set time of day.
5. Once brewing time has been set,
follow this procedure:
• Follow steps in "How to Make
Coffee."
• Push AUTO-ON-OFF button once
and "Auto" will be shown in display
indicating the brew cycle will begin
at the set time.
NOTE: If AUTO-ON-OFF is pushed
twice, the light will glow and brewing
will begin immediately. Press AUTOON-
OFF once to turn off and once
more to set programming mode.
Jan 13, 2011 | Hamilton Beach Stay or Go 45234 Coffee...
The coffee pot turns itself off immediately after brewing a pot of coffee.
The machine is designed to shut off after the brewing cycle after a period of time which you can manually set anywhere from 0-4 hours. Check your setting to make sure that it is set for a reasonable amount of time for you. We have the user manual at the link provided: DCC-1200 Manual. If you run into more issues with the auto off there might be a problem with the board in your machine. If that is the case you will have to call Cuisinart directly to get a repair auth for the machine.
Nov 01, 2010 | Cuisinart DCC-1200 Coffee Maker
How do you set the clock and program to brew at a specific time?
To program the Auto On
1. Set the desired Brew-Start time.
a. Turn the FUNCTION KNOB to “Prog”.
b. Set the time you want coffee to begin
brewing by using the minute and hour
push-buttons. Follow the same instructions
you used to set the time of day, in
the To set the time section above.
2. Turn the FUNCTION knob to the “Auto On”
position. LCD will display the current time.
3. Lift and release the FLIP SWITCH. The
green indicator light will come on to remind
you that the programming function is in use.
At the programmed time, the red light will
come on as well, indicating that the brew
cycle is starting. Both lights will go off when
keep warm cycle ends.
NOTE: To reactivate the auto-on feature to
start brew cycle at the same time another day,
simply lift and release the FLIP SWITCH. The
green “auto-on” light will illuminate.
Aug 16, 2010 | Cuisinart DCC-1200 Coffee Maker
Coffee too weak what are normal knob settings
Function Knob For setting time of day, and auto on and auto off times. a. Auto On The Auto On feature is used to program the start time of the brew cycle. The auto on time can be set for any time, day or night. The “PM” indicator is displayed on the LCD for nighttime program times. b. Auto Off The Auto Off feature is used to shut off the coffeemaker at a preset time, anywhere from 0 to 4 hours. c. Program Set The Program Set function is used to set the time for the Auto On function. d. Brew The brew function is used to start the brew cycle directly. e. Clock Set Used to program the time of day. f. Audible Tone (not shown) The Brew Central™ Coffeemaker is equipped with an audible tone which will sound 5 times when the coffee has completed brewing (coffee will continue to stream from the filter for a few seconds after tone).
If yours is a Vienna Digital Coffee Maker please click the link below. it is manual of Coffee Maker, it would be helpful to in the future.. http://www.cerinicoffee.com/Saeco_User_manuals_free.asp
Jan 20, 2010 | Saeco Vienna Digital Coffee Maker,...
Need assistance on how to program the timer for my cuisanart 12 cup coffee maker
The manual can be found here:
http://www.cuisinart.com/share/man/25_man.pdf
Mar 24, 2009 | Cuisinart Brew Central 12-cup Coffee Maker
Menu cycles through the options non-stop
Have you tried unplugging the unit? Sometimes the machine will get caught in a repetitive "cycle" and needs to be re-set. If this does't work, let me know
Feb 21, 2009 | Keurig B50 Coffee Maker
Coffee maker shuts off too quickly
It seems this coffeemaker insists on shutting itself off after 4 hours,
or whatever "auto-off" time you've programmed in. The only work-around I've found is to switch it to "Brew" and cycle the power switch off and on every time you pour a cup. That will start a new
4-hour timer cycle. Since the pot's still hot, it will go quickly to the
"brewing done" state and render 5 beeps.
Jan 08, 2008 | Cuisinart DCC-1200 Coffee Maker
Black and decker coffee maker
what type of coffee maker? does it have a model number?
Dec 11, 2007 | Coffee Makers & Espresso Machines
Coffee brews and then immediately shuts off Cuisinart DCC-1200
To program the Variable Auto Off: 1. Turn the FUNCTION KNOB to the ?Auto Off? position. Press and hold the ?Hour? button for 2 seconds. The clock display will start blinking. 2. Program the coffeemaker to shut off from zero to four hours after brew cycle is finished by using the ?Hour? and ?Minute? push-buttons. (see ?To set the time?)
May 20, 2007 | Cuisinart DCC-1200 Coffee Maker
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
